Engel 40lt gas strut mod
Results 1 to 20 of 22
    Pune
    Thanked: 42
    Default Engel 40lt gas strut mod
    My 40lt Engel is mounted behind the seat in my clubcab, but it's a real pain to hold the lid up and scratch in the fridge with the other hand. I'm quite short as well, so that makes things even more difficult. I have jammed it up against the roof lining a few times, but the will eventually damage the roof lining and it can still fall down.
    I thought of a gas strut, but even the small size Gabriel gas struts are quite big for this application. I went to the local Mega to see if Engel has a standard add-on to solve the problem, but no luck. Kurt at Mega PE suggested a gas strut as well or one of those sliding locks as used on some cupboard doors. Before going for the Gabriel gas strut route, I quickly went to Builders Warehouse to see what they have. I was surprised to find a little gas strut in the cupboard accesories section with a few different brackets, already pumped to 100N and all for R70.
    I checked with Kurt if it is ok to drill into the side of the Engel and he said it's fine as the outside is just insulation, the cooling element is on the inside.
    I took a few measurements, drilled the holes and installed the strut. I has some M5 rivnuts and the right drillbit already in the drill, so I used that along with some stainless steel screws to attach the strut.
    My fridge is strapped in at the moment, but I need to put in a floor board and attach it to that as the strap around it makes it difficult to operate the latch.
    The 100N force sounds a bit much, but in the position I put it, it works just perfectly. Holds the lid up in the right position as not to touch the roof lining and almost no force trying to open the lid when it's closed. It's also not in the way of taking stuff out the fridge.
    With the lid open:
    With the lid closed:
    Hardly visible with the cover zipped up:
    The strut itself:
Name:	P1070680 (Large).JPG
ID:	54851   Click image for larger version.
Name:	P1070682 (Large).JPG
ID:	54852   Click image for larger version.
Name:	P1070683 (Large).JPG
ID:	54853   Click image for larger version.
Name:	P1070685 (Large).JPG
    Rangeview Krugersdorp
    Thanked: 827
    Very neat indeed !! Pity about the patent!!!
    Chev Aveo and Atos and Polo.
    Thanked: 240
    Very nice Barto
    I think this will be something I will do soonish.
    Just one question, the lid slides sideways off the hinges for easy removal of the lid. How does this affect the strut, or have you done something to prevent the lid sliding sideways?
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    Pune
    Thanked: 42
    The bit of lid sideways drift won't be a problem as the strut sits on a type of ball joint. The strut can be clipped off if you need to remove the lid for cleaning, etc.
    Engel have a mod to keep the lid from sliding off and I'm going to find out about it when I go to Mega later today. If it costs too much, I will make it myself.
    Craighall Park
    I think I'll pop round Builders this afternoon!
    This would work on a National luna as well....or any fridge for that matter....great idea, now I have two hands to find stuff in my fridge again!
    Thanked: 240
    Quote Originally Posted by Zantus View Post
    Cool - let us know...
    Carpe Diem Scrotum
    Pune
    Thanked: 42
    Just check where the pipes run on the national luna, you don't want to end up destroying your fridge while fitting the strut.
    Thanked: 554
    Very nice Bartho. I would also like to do it but the Waeco has plastic insulation. I'm not sure it will hold the strut without ripping out. Maybe a little steel plate to spread the force more evenly?
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Experience is something you don't get until just after you need it.
    May 2008
    Thanks Barto, I have the same problem in the Ford.
    Will investigate this plan. For the lid coming off, I simply strapped a cable tie tightly over the hinges, no more movement. Cheap and easy to replace when I need to take the lid off.
    Ford Supercab 3.2 Auto 4wd
    The Windy City
    Thanked: 2742
    Brilliant mod. When can I drop mine off?
    Oct 2006
    Boksburg
    Great idea.
    Pune
    Thanked: 42
    I bought the Engel thing to stop the lid from coming off for R19 from Mega PE!
    Dirk, when I saw there are only 2 of these struts on the shelf I almost both, because I just knew you would want it as well.
    Thanked: 240
    OK, have strut, now just need to get me a rivnut tool...
    Have to go to mega tomorrow so will collect the lid mod if they have stock
    Carpe Diem Scrotum
    Pune
    Thanked: 42
    You can use pop rivets as well, I just used the rivnuts because I had them and everything was ready to go.
    Excellent solution.
    (M25)
    LandCruiser 200 V8td,ARB winchbar,Warn 12000lb winch,IPF spots,180W LED bar,180L Longranger aux tank,ARB rear bumper+dual wheel carriers(had-Kaymar carriers),OME suspension,TJM snorkel,raised axle breathers,roofrack,2 way comms,285/70/17 AT tyres,additional fuel filter system, aux battery box.
    Thanked: 240
    Mine is now modded as well. Thanks
    That strut is quite strong - lifts the lid up on it's own!
    Carpe Diem Scrotum
    Craighall Park
    Okay so I did a similar thing to my National Luna, works a charm!
    Thanks for the idea, used the 80N lift though, still strong enough to lift the lid no problem!
ID:	56885   Click image for larger version.
    Pune
    Thanked: 42
    My gas strut has gone soft. I fitted another one I had here to see if it was a dud or not. I will also be contacting the manufacturer to see if this is normal for it to last for about 20 strokes only.
    Nov 2006
    Thanked: 394
    Youre right. Your strut should not go soft after about 20 strokes.
    I was thinking of using the thinner models, like these guys (3rd from the right):
    http://www.batteryandtyreworld.co.za...gas-struts.jpg
    Apr 2012
    Brackenfell
    Default Re: Engel 40lt gas strut mod
    Quote Originally Posted by Barto View Post
    Hi Barto
    do you have fotos of this stopper
    By charlatan in forum Jeep
  2. Hella plug fitted to engel 40lt
    By Kaptein Jack in forum Camping, Fridges, Accessories
    Last Post: 2012/04/05, 12:30 PM
  3. fitting a fridge transit slide lock
    By biltongvreter in forum Camping, Fridges, Accessories
    Last Post: 2009/08/04, 10:10 AM
  4. Engel 40lt Current Draw
    By Jannie Kubu4x4 in forum Camping, Fridges, Accessories
    Last Post: 2008/06/23, 08:25 AM
