My new off road trailer
Results 1 to 20 of 38
    Bellville
    Default My new off road trailer
    herewith the first fotos of my off road trailer
ID:	636   Click image for larger version.
ID:	637   Click image for larger version.
ID:	638   Click image for larger version.
    Bellville
    Default Re: My new off road trailer
    dirk dankie vir die help om dit te doen
    Mozambique/Cape Town/Other
    Johan where do you get that channel used in the first photo?
    Or is that roof purlin?
    Or is it bent up like that on request?
    * "Wat Spike probeer s in sy min woorde" -Die Skim "
    Bellville
    Quote Originally Posted by Spike
    SPIKE
    it nomal roof purlin from Brackenfell Steel.
    johann
    Adelaide
    Looking good so far!!
    2012 Jeep WK2 Limited CRD
    2" Murchison Lift
    265/65R18 Dick Cepek Trail Country
    TJM sidesteps
    Uneek4x4 Recovery points
    Bellville
    nog fotos
ID:	677   Click image for larger version.
ID:	678   Click image for larger version.
ID:	679   Click image for larger version.
ID:	680   Click image for larger version.
    Pune
    Baie netjies Johann!!!
    Hoveel dink jy sal hy weeg wanneer hy klaar is? Watter grootte tyres gaan jy gebruik?
    As a matter of interest, what material and how have you coated it, have you used for the sides?
    I'm considering mild steel frame, that is galvanized.
    Mild steel frame box that is galvanized.
    Then was thinking 1mm Alu checker plate for the box, but this is going to cost me, and I'm concerned about sealing the Alu, as I won't be in a position to alu weld.
    Maybe mild steel sheeting would be better, but I think it would warp if galvanized. What are my other options?
    Otherwize, looking good, and coming along quickly.
    Good job!
    iHilux
    Wade Bowman
    '07 Land Cruiser 76 SW
    '08 Discovery 3 V6TD HSE
    '11 Conqueror Companion
    Bellville
    Quote Originally Posted by Zantus View Post
    Barto - salseker so tussen 450-550 kg wees as hy klaar is - sal hom so Woensdag gaan weeg - ek gaan 31 10.5 15 op sit - moet nog die brieke doen ( kabel in sit- en voor op sit) Ek wil h hy moet brieke h - hy staan tans by Haniball vir die kant tente wat ek aan die IMPI tent gaan vas sit, wat dan die regter kant en die agter kant sal toe maak.Dit gaan nogal 'n groot tent wees.
    johann
    Glenwood /C.T
    Talking
    Hi
    Have you worked out your cost yet would be interesting to see what figure you come to compare with one of the floor with more or less the same size with extras.
    You take orders
    Fortuner 4x4 3.0 D4d 2013
    Paarl
    I have been doing the cost myself:
    Makro Wilderness - 1.6 ton axle - R 22 080 (excludes registration &plates)
    Venter Bush Baby - 1.4 ton axle - R 23 000 (ex reg & Plate, includes fridge slider)
    Local builder - 2.5 ton axle - R 15 000 (ex spare but includes reg & plates)
    The tent will be the same for all 3 and the Maxi from My Way will be about R15 000.
    Bellville
    Quote Originally Posted by iHilux View Post
    Good job!
    iHilux
    I did use 1.2mm electro galv.sheets and use 2K paint with hardner- with MS primer.
    johann
    Bellville
    Smile
    Quote Originally Posted by Erik View Post
    Hi
    You take orders
    Yes I did -It wil not be more than R7000.00 for the complete trailer.
    johann
    Quote Originally Posted by JOHANN TYRE View Post
    johann
    I see in the one pic, your internal frame on the door is also painted (also 2K I pressume). Is this also galvanized?
    Do you buy the sheets already galvanized, or is this done afterwards, and how does electro galvanizing differ from hotdip? As good, better? Costs?
    Thanks for sharing Johann
    iHilux
    Wade Bowman
    Bellville
    iHilux
    eletro galvanized sheets is beter to weld on and no rust wil be there. I dont like hot dip and very difficult to weld on and not nice to paint. the electro sheets is a bit more expensive.
    johann
    Glenwood /C.T
    Hi Johann
    Would you be intereted in giving me a quote for a trailer i dont expect to pay what it cost you.
    Thanks Erik
    johann
    So you buy the sheets already galvanized. And it does'nt rust where you weld? What about the weld itself? Surely you are using mildsteel rods, and that can rust? How do you treat your welds?
    As for the square tubeing frame, how do you treat this to prevent rust?
    What about you base frame? Any rust preventative measure here?
    Thanks a mil for the feedback....... I've learned something new already, and see my initial ideas changing shape already.
    iHilux
    Wade Bowman
    Bellville
    iHilux
    yes i did buy the electro gal. sheets - it will rust on the welds but all the welds was painted with EDGE primer and then MS primer on all the non galvanized bits and then the 2K paint with hardner - the same what the pannelbeaters use. It works well for me - I dont like HOT dip galvanizing , everything pulls and wabbels and you must dril a lot of holes GA - not for me.
    johann
    Stilbaai
    Hi Johan, where did you buy the gas stove and what make is it? I am not having any luck in finding one with a lid that can clamp shut like that one.
    Bellville
    Quote Originally Posted by IF View Post
    At the Aussie Shop in Bellville
  1. Easter break Lesotho trip 2011
    By stevo in forum Lesotho
    Last Post: 2013/04/02, 07:58 AM
  2. Reversing with a trailer behind your 4x4?
    Last Post: 2013/02/04, 12:51 PM
  3. Buzzard Overlander Off Road Trailer
    By janleroux in forum Camping, Fridges, Accessories
    Last Post: 2012/01/24, 06:46 PM
  4. Build an Off Road Trailer
    By PierredW in forum Camping, Fridges, Accessories
    Last Post: 2011/08/19, 11:50 AM
  5. Where to stay in Maun?
    By piri in forum Botswana
    Last Post: 2010/07/21, 07:23 AM
