Strange noise from sani when in 4 wheel drive
Results 1 to 6 of 6
    Jan 2009
    Pretoria...(closest)
    Default Strange noise from sani when in 4 wheel drive
    Ok this is my dilemma. I will try to explain as best possible.
    In normal two wheel drive with front hubs locked no noise at all.
    In four wheel drive (with front hubs locked of course ) high range or low range there is a noise which resembles a "clack clack clack" coming from the right wheel hub. This noise speeds up or slows down as the car changes speed.
    When still in 4 wheel drive and I move into 2 wheel drive the noise stops immediately.
    So all this happens only in 4 wheel drive high or low range.
    As I lift my foot off the accelerator the noise also subsides .
    I hope one of you can perhaps throw some light on this
    Tried to explain as good as possible
    Thanx
    " IF THE GIANT BEASTS ARE GONE, MAN WILL SURELY DIE FROM A GREAT LONLINESS OF SPIRIT "
    1996 3.0L SANI "EXECUTIVE" S/W
    CAMIL SUSPENSION
    3O/9.5/15 BF GOODRICH A/T
    WILCAT BRANCHES
    REAR SUPER LEAF-SPRINGS
    PORTABLE NL DUAL-BATTERY POWER PACK
    Gaborone, Botswana
    It sounds like a CV.
    I had the same experience. With the hubs locked and TC selector in 2WD, no noise. The front drive-shafts does turn, but there are no load on them. As soon as I select 4WD (Lo or Hi) the noise starts. It was more audible with the steering/wheels turned.
    Kobus
    Nissan
    Pretoria East
    Izzy I second KobusDJ on that. HAppend to a friend at de wildt a while back. Got the CV reconed as far as I can remeber it was cheap. He did it somewhere in voortrekker road pretoria.
    Jan 2009
    Kobus en JcW, Baie dankie.
    Kobus ek sien jy is nog aan lyn, sal dit dan beter wees om altwee maar te laat overhall?
    As jy in gewone 4x2 gery het het joune nog geraas of nie. As dit cv,s is moet dit nie ook in gewone ryery raas nie?
    dankie
    CAMIL SUSPENSION
    WILCAT BRANCHES
    Gaborone, Botswana
    Geen geraas in 4x2 (met hub gesluit) nie. Ek dink dit is omdat daar geen torque op hulle is nie. Dieselfde gebeur in 4WD as jy jou voet van die versneller afhaal..... die geluid hou ook op.
    Ek weetnie presies hoe dit werk om CVs te laat oordoen nie. Ek verstaan hulle weld die metaal op, en dan masjineer hulle dit weer af tot op spesifikasie. (Maar ek mag verkeerd wees)
    Ek het twee kompleet nuwe drive shafts (shafts + CVs + boots) ingesit.
    Kobus
    Nissan
    Jan 2009
    Dankie Kobus, sal daarna laat kyk
    CAMIL SUSPENSION
    WILCAT BRANCHES
  1. Fitting new front wheel bearings Hilux
    By Big Hilux in forum Toyota
    Last Post: 2014/05/28, 02:58 PM
  2. An interesting TJ Jeep Article.
    By Big Hilux in forum Jeep
  3. Noise and Shudder on front suspension
    By Martin in forum Toyota
    Last Post: 2008/03/07, 05:21 PM
  4. New Colt
    By steyn jeep in forum Mitsubishi
    Last Post: 2006/10/31, 08:37 AM
  5. Strange noise when turning
    By Philip in forum Mitsubishi
    Last Post: 2006/10/26, 02:47 PM
