In Car PC
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 67
Thread: In Car PC
    Thanked: 1364
    Default In Car PC
    Anybody know where you can get one of these in SA?
    http://www.in-carpc.co.uk/vehiclecomputers.htm
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    The Windy City
    Thanked: 3918
    Yes, but first tell me what your application and budget is, then I can recommend based on that.
    Thanked: 1364
    Application?
    Thanked: 1051
    waarvoor wil jy dit gebruik, Dirk nog leer om afrikaans op die freds te praat!!
    Kry n laptop!
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    COMBAT19: Large scale fogging and decontamination of coronaviruses
    [email protected]
    [email protected]
    +27824453301
    The Windy City
    Thanked: 3918
    What do you want to do with it? Mapping, music?
    There are several options. Pinnacle Micro sells a really small form factor PC, couple that with a 7" touch screen and you have a relatively cheap solution that you can run off and invertor. If you are concerned about the hard drive taking a knock then look at running it with one of the new solid state drives.
    Then Klare Technologies have a proper Car PC, which is rugged etc, but also not cheap (R15k +).
    There are also then double din car radio replacement options that runs Windows, have look at the back of the Leisure Wheels magazines.
    Thanked: 1051
    you have to go solid state on our roads. I still have to find what im looking for
    Angel Construction
    [email protected]
    [email protected]
    +27824453301
    Thanked: 1364
    Following the forum - or wait, that's what Herman wants it for.
    Basically music, downloading photos, GPS, and looking for accomodation, spares, fuel etc.
    Thanked: 112
    http://www.mini-box.co.za/ of probeer 'n Asus EEE mini laptop hulle is solid state, so geen hardeskyf.
    Gaborone, Botswana
    Thanked: 1247
    Thanked: 14
    Screen they use in bank ATM's? There is a place in Pretoria that supplies banks and hospitals etc. with ANY type of screen, PC etc. typically EMBEDDED pc and screen in one unit.
    will try to get info.
    Hilux Dakar & Comfort trailer
    The first 40 years of childhood are the toughest!
    Adelaide
    Thanked: 11
    Ek stem saam met saskia. Kry 'n ASUS EEE. Ons het een en dit werk fantasties!! As mens in die middel van botswana 'n klein grond padjie probeer vind op 'n 3x3 duim skerm dan raak jou humeur nogal kort. Die klein laptop help baie. Plus jy kan elke aand jou fotos download, jy kan die laptop an jou voertuig se speakers koppel en al jou musiek daardeur speel... Dit is baie handig!!
    Adelaide
    Thanked: 11
    Die ASUS EEE werk perfek.
    Thanked: 1364
    Definieer Goedkoop.
    Hoe werk die touch screen - kry mens die sagteware wat daarvoor nodig is saammet die screen?
    Thanked: 112
    Die heel klein 7" skerm Asus EEE kos om en by R2k, en jy kan op die internet 'n touchscreen mod vir hom koop en dit self install. Myne is gekoppel aan 'n 8" touch screen wat met 'n RAM mount teen my venster sit. Die laptop is onder die sitplek en ek beheer die laptop via die touchscreen en gebruik Garmin Mobile PC en T4A as GPS.
    Kyalami
    Quote Originally Posted by saskia View Post
    Sal jy asb 'n foto post?
    Kyk ook hierna.
    http://www.newaye.com/Product/N52/Default.html
    http://www.newaye.com/Product/N899/Default.html
    As jy 'n jap kar ry kan jy ook hierna kyk, hullet verskeie modelle wat in kar spesifieke slots inpas.
    http://www.newaye.com/Product/N573/Default.html
    Koste is omtrent so R8k + invoer tax + DHL.
    Ek glo nie dis nodig om solid state te gaan nie, die laptop drywe is baie robust(seagate), sodra hy vibrasie voel park die heads etc. Het my laptop al baie rond gegooi en hy loop nog mooi. As jy wel kry dat jou dryf probleme gee gaan dan SSD.
    Thanked: 112
    Hieronder is 'n foto van die skerm (Lilliput). Die aspect ratio is 4:3, maar jy kry hom ook in 16:9, ek verkies die 4:3 want dan kan jy meer voor jou sien op die GPS. Die Mobile PC lyk presies soos die NUVI se skerm met dieselfde groot "knoppe" vir die navigasie, so dit werk perfek op die touchscreen.
    Ladysmith
    Thanked: 393
    Uys, unless you need it in the car for things like storing media (music/movies) or as a large screen GPS (though I don't know if more then the few inches of a normal unit is necessary), in which case plenty of options have been given, I'd suggest a netbook like the eeePC. Solid state hard drive means no moving parts, and they run a version of Linux and boot quickly. Battery life is also solid, at least 4 hour from a 6cell battery.
    I have a Samsung NC10 that I use as my only PC, apart from the 15" laptop at work (which stays at work) and it performs flawlessly. I get around 4.5 hours battery, and use a 3G card or wifi for internet, though you can get them with built in 3G capability. A few uses I could think of would be research while on the road or to find help on the forum Maybe even somthing exotic like connecting to one of those stargazers that let you download co-ords to view from the internet...
    Adelaide
    Thanked: 11
    Cool, ek het nie daai deel nie. Waar het jy jou touchscreen gekoop en hoeveel het jy daarvoor bataal? Wat behels die installation? Hoe koppel die screen aan jou pc? Kan jy nogsteeds die gewone skerm ook gebruik?
    Thanked: 1364
    Quote Originally Posted by petermoffat View Post
    Thought about that, but if it doesn't have a dedicated place, it WILL!!!! annoy me endlessly!
    Nov 2006
    Perth, Australia
    Thanked: 360
    As dit al is wat die outjie moet kan doen, dan kan jy mos maar net n Nuvi koop met n groot skerm.
    Ek dag jy wil jou taxes doen terwyl jy bestuur, of dalk prawn van die internet af laai terwyl jy n pirate movie kyk.......
    No more Jeeps for me for a while.
    2009 Ford Ranger PK 3.0
  1. Hacking car remotes
    By Henris in forum General 4x4 Discussion
    Last Post: 2012/02/08, 09:58 PM
  2. Cape Classic Car Show 15th November 2009
    By ZuluCowboy in forum Western Cape
    Last Post: 2009/11/25, 02:33 PM
  3. Has your car Lost HALF its Value ?
    By JeepOnly in forum General 4x4 Discussion
    Last Post: 2007/03/23, 02:31 PM
