Ramsey winches
Results 1 to 2 of 2
Thread: Ramsey winches
    Thanked: 982
    Default Ramsey winches
    Can get a ramsey 9000 for R 7335.00
    Are they any good?
    Wanted to get the warn but for R12000 its steep. So deurmekaar soos katkots nou. Suddenly the GEW etc seems well priced even if you have to fix now and then.
    [email protected]
    +27824453301
    Pune
    Thanked: 60
    Default Re: Ramsey winches
    Seker nie te bad vir 'n Ramsey nie. As jy 12000lbs soek, kry die mudcreeper. Soortgelyke specs as die Warn 12000, maar die kabel is 10m korter en die goeie deel, hy het 'n groter motor as die warn, wat hom beter verrigting as die warn gee. Hy is definitief op my inkopie lys!
  1. Hand winches - lever type
    By RudolfD2 in forum 4x4 Recovery & Recovery Gear
    Last Post: 2011/05/27, 01:32 PM
  2. Help With Ramsey Winch
    By cruzer244 in forum 4x4 Recovery & Recovery Gear
    Last Post: 2010/08/16, 01:13 PM
  3. Tabor winches
    By SteveB in forum 4x4 Recovery & Recovery Gear
    Last Post: 2010/07/02, 08:12 PM
