Xai Xai Paaie
Results 1 to 5 of 5
Thread: Xai Xai Paaie
    MinantoJ Guest
    Default Xai Xai Paaie
    Hi Almal
    Kan iemand my dalk inlig hoe die pad lyk na Xai Xai oppad Inhambane toe? Ek het gesien daar was baie reen 'n ruk terug?
    Ek vertrek Saterdag Coconut Bay toe, wonder hoe is die weer op die oomblik? Het iemand 'n idee...
    Pretoria East
    Ek het vandag gehoor dat die pad mooi is tot by Xai Xai. Daarna 60km bad patch pad en daars baie padwerke. Ek gaan daai pad maar mis ry as ek maandag ry
    Johannesburg South Africa
    We are also travelling that road on Monday on the way to Legogo near Jangamo. Don't know of any way to avoid it as the dirt bypass is said to be VERY slippery after the rains thay have had.
    Quattro
    2005 Touareg V10
    2006 BMW M5
    2017 Invader Duo
    2007 Noble Ferrari P4 replica
    2013 High Spec TRD Toyota 86
    Centurion, Pretoria, SA
    Coming through Maputo there are odd potholes in the main road through and out towards Xai Xai. I would time my trip to avoid peak time in Maputo 'cause the traffic can be hell. From Maputo to Xai Xai the road is great but from Xai Xai for about 100kms they are working on the road and you should definitely travel through here in daylight. Lot of dust too.
    Now when the construction ends the real problem is for about 30kms there are serious potholes that you must be prepared for. Do not travel to close behind the guy in front 'cause you need planty time to react. Driving fast you will only cause you to swerve for one and hit two!
    We're waiting for you and the beer is cold !
    JHB
    My Family drove on Friday. The road was slow going - 60km took two hours, My family to be has a place in Chidenguele. they know the road pretty well.. They drove straight from JHB a 14 1/2 hour trip. Drive safe as we will be travelling the road on Monday..
    Cheers.:
  1. Accommodation in Xai Xai
    By Rikus.Mulder in forum Mozambique
    Last Post: 2009/12/11, 08:37 PM
  2. Trip to Xai xai
    By pitch in forum Mozambique
    Last Post: 2009/09/17, 09:40 PM
  3. Giriyondo to Paindane via Xai Xai - Sept 2009
    By mccabe in forum Mozambique
    Last Post: 2009/07/20, 11:12 AM
  4. Giriyondo to Chidenguele / Xai Xai
    By Jeanette in forum Mozambique
    Last Post: 2008/12/10, 03:20 PM
  5. Girriyondo to Xai Xai
    By JK Master in forum Mozambique
    Last Post: 2008/10/23, 12:20 PM
