Gearbox or Clutch?
Results 1 to 4 of 4
    britsnj Guest
    Default Gearbox or Clutch?
    Excuse my ignorance on this one. I have a 2.4 D/C 4x4 with 150000 on the clock. Lately I battle with the gearshift. Up is scratchy and down is near impossible. THe question now is... clutch or gearbox. I'm opting for clutch.
    Pretoorsdorp (Centurion)
    Thanked: 148
    Do you have a problem with all the gears or only a few? Normally if all the gears gets sticky its the clutch, if you only have a problem with let say 2de and 5th... then it could be the sincros on those gears.
    By the way, I see its your first post! Welcome to the forum, why not introduce yourself?
    SUSPENSION FOR THE FUTURE www.amadaxtreme.co.za
    203 Edison Crescent, Weca 4x4, Hennopspark, Centurion, GPS: 25°52’19.0”S 28°09’59.3”
    Cobus Böhmer CEL: 071 641 7947 Email: cobus@amadaxtreme.co.za
    Mondeor, JHB.
    check your slave and master cylinders, could be time for a rebuild.
    D2 V8. Pro Comp MX6 Shocks with Mikem Custom Progressive Coils. Wildcat Headers. 265/75/16 Hankook RT03's. FLI Audio. Kaiser Locker.
    britsnj Guest
    Thanks guys. Cobus, did the intro thing. Meant to a while ago but never got round to it!
    She is sticky throughout. Think I will do the clutch and master / slave in one go. That should sort out the lot. Thanks again guys!
    By charlatan in forum Jeep
  2. New ford ranger 3 litre diesel clutch problems
    By DaBump in forum Ford & Mazda
    Last Post: 2010/12/07, 10:15 PM
  3. Defender 2 issues clutch shudder and noisy gearbox
    By trance-porter in forum Land Rover
    Last Post: 2009/07/07, 09:29 AM
  4. clutch noise!
    By kwerner in forum Mitsubishi
    Last Post: 2008/08/28, 12:20 PM
  5. Recon Gearbox Problem
    By Eben in forum Land Rover
    Last Post: 2008/02/23, 10:22 AM
