Nissan 3.3 fuel injection question
Results 1 to 7 of 7
    Oct 2008
    Sasolburg
    Question Nissan 3.3 fuel injection question
    My fuel consumption on my 06 3.3 is bad and erratic. I varies from 7.5 to 4.5 km/litre. I have fitted a Dastek chip and it made a difference after fitment and then became erratic (on long trips again).
    She does this on long open road trips down to the coast. On arrival there it is as if she want to die below 1000 rpm. She kept this symptom on arriving back in Sasolburg.
    I suspect that one of the sensors feeding the ECU is giving the wrong reading and thus the FI wrong mapping. (I understand how the mapping works on my Yamaha bike - it uses RPM and throttle position / carb slide position) I unplugged the mass air flow sensor on air box inlet pipe and this worsened the symptoms (missed badly when revved). Plugging it back however, made her run smooth again. It was if something was "reset". I suspect she is now back to her 7.5km/l best behavior.
    Questions:
    what are the input signals to the FI ECU other than RPM?
    has someone else experienced this?
    any solutions / suggestions?
    Gaborone, Botswana
    Thanked: 960
    If the 3.3 is the same as the 3.0 (VG30E) you will have the following.
    Mass Air Flow meter.
    RPM
    Water Temp
    There is a Throttle Position Sensor as well, but it is only used when in "limp" mode.
    Kobus
    Nissan
    Oct 2008
    Sasolburg
    Thanx Kobus, I suspect it will be the same for 3.3.
    Is the mass air flow meter the sensor on the Air box inlet pipe? If so I thought it is an air inlet temperature sensor. I will then have to update my first post.
    Gaborone, Botswana
    Thanked: 960
    Armand
    Yes, the sensor is on the air intake. Mine has 4 wires. 5V, 0V, and signal (0 - 5V) back to the ECU. 4th wire is unused.
    If you disconnect it, it goes into limp mode. Max 3000RPM and very bad idling.
    Check the water temp sensor. It is close to the sensor for the temp gauge in the dash. If you get the wrong signal from this sensor, the ECU may think the engine is still cold, and will adjust the idling valve and fuel mixture.
    Kobus
    Nissan
    Oct 2008
    Sasolburg
    I suspect it is the mass airflow meter. After unplugging and plugging it back, she was fine again. Removing the power must have reset it.
    When she plays up again, I will measure out the idle readings from it.
    Gaborone, Botswana
    Thanked: 960
    May be a bad connection in the plug. While idling, wiggle the wires at the back of the plug.
    I had a similar problem with mine. Occasional bad behavior.
    Kobus
    Nissan
    Klerksdorp
    also make sure there is no bugs or stuff stuck on the "siffie" infront of the airflow sensor! this has caused me a few headaches untill i sealed the airbox on the inside! also see if your airfilter has a rubber seal on the inside at the arflow meter end, mechanics tend to remove the rubber and never put it back
    "Blue Thunder"
    Gert Ferreira
    By charlatan in forum Jeep
  2. Fuel Tank (Aftermarket) Excel
    By Tabatwa in forum Vehicle & Technical Chat - General
    Last Post: 2011/08/11, 06:58 PM
  3. Replies: 1
    Last Post: 2010/10/15, 04:36 PM
  4. Grand Cherokee Error code
    By Nick47 in forum Jeep
