Loading a Jimny - Page 18
Page 18 of 19 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 341 to 360 of 362
Thread: Loading a Jimny
  1. #341
    Kimberley
    Thanked: 18
    Quote Originally Posted by Boskoets View Post
    Don't go over 40kg on the roof maybe 50kg if you have a aftermarket suspension.
    because the Jimny is light, short and narrow loading on the roof is very limited.
    Does that include the weight of the roof rack? What does a front runner weigh or any roof rack for that matter?
  2. #342
    Thanked: 88
    Rowan not sure but I did a Swazi trip with about 40kg on the roof rack with no issues.
    Zone Built JEEP 018
    ORRA AG42
    2013 Jeep JK Rubicon
  3. #343
    Mar 2012
    Quote Originally Posted by Rowan View Post
    It likely includes the rack, as those specs are probably for anything more than standard on the roof, and standard = rails, which weigh almost nothing. I estimate my K9 rack is about 15kgs.
    A roof rack close to the max on a Jimny is scary to drive. I'd rather take the fuel consumption hit with wind-resistance by packing the light bulky stuff up there (bedding etc.), than put anything heavy on top.
    It's not the size that counts, but how well it performs in the bush.
    - A Jimny -
  4. #344
    Aug 2015
    Thanked: 82
    Nou wil ek sommer vir my 'n Zuk gan koop
  5. #345
    Jul 2015
    Thanked: 18
    Great, this answer my question,
    All the light stuff on the top
    Heavy things inside,
    Dankie Manne
    2015 Jimny, Africa explorer
    2015 Renault GT 220
    2016 Ford Focus Rs
    Man cave full of MTB bikes
    Ex 2011 Renault RS 250 Cup
    Ex 2001 Renault Clio sport 2.0l
  6. #346
    Mar 2012
    Thanked: 9
    my pakasie as ek nie trailor sleep sit ek die amo sak op, het hom net verstewig met hout onder en wil nog 'n ietsie ekstra onder opwerk net vir die op en af skuif dat dit nie materiaal beskadig. gedink om dalk net n "basket te koop om hom daarin te sit
ID:	364288   Click image for larger version.
  7. #347
    Jul 2015
    Thanked: 18
    Quote Originally Posted by pienkie View Post
    Thanks man, yes that helps me as well,
    have the same set up barring the roof rack
    2015 Renault GT 220
    2016 Ford Focus Rs
  8. #348
    Mar 2011
    Walker Bay
    Thanked: 1068
    I have had well over 40kg (2 jerries plus spare tyre) with no problems.
    Currently a 63kg RTT - no problems. I do take it a bit slower around sharp bends.
  9. #349
    Kimberley
    Thanked: 18
    What would you all suggest: I can get 9mm ply-wood or 18mm shutterply, what would be best for a base board and second level that must carry a NL fridge? The 9mm will be lighter but will it be strong enough for the load?
  10. #350
    Thanked: 438
    You need to save all the space you can, go 9mm
    2004 Defender 110 Td5
  11. #351
    Oct 2014
    Thanked: 17
    I have a 9mm carrying my Waeco fridge. More than adequate
  12. #352
    What size wood did you use? I am going to be putting something together this weekend.
    I think it is 13mm
    Quote Originally Posted by Mistral View Post
  13. #353
    Nigel Johannesburg
    Hi, we do a heavy duty spring for your Jimny to assist with managing extra load. Do give us a call for a quote.
  14. #354
    Mar 2011
    Walker Bay
    Thanked: 1068
    Jimny has the suspension upgrade.
  15. #355
    Oct 2014
    Thanked: 17
    Air Springs are also a great help. Can adjust pressure to suit the load
  16. #356
    Jul 2015
    Does anyone know the name of the thread pattern for the bolts that are normally used to bolt the rear seats down?
    I'd like to buy longer ones to secure my homemade floorboard to the chassis as well as use these bolts to work as a fastening point for gear stored in the back. (not content with using the board alone as a fastening point)
  17. #357
    Franskraal
    Thanked: 23
    Default Re: Loading a Jimny
    Im currently planning my back boot of my jimny I will fost some pictures of the process
  18. The Following User Says Thank You to Daby Jimny For This Useful Post:
  19. #358
    Feb 2019
    Post Re: Loading a Jimny
    Hi all.
    New user here, expecting delivery of my pre-loved 2015 Jimny a little later this afternoon. Excited is an understatement.
    I've been trawling this thread for days and am super excited to try my hand at building an "OreRak" over the weekend. I suppose I'm wondering if anyone can confirm that the measurements also apply for a 2015 shape? A lot of the original posts in this thread date back to 2009 (!)
    I'm ideally going to build something...:
    a) that doesn't require me to remove the back seats
    b) that allows me to hide parcels (laptop bag, backgammon board, trail-running shoes/kit) away from prying eyes (ideally in a drawer or small ammo-box under the backboard)
    c) that can carry the weight of camping supplies for a couple for 2 nights (at least) without the need for a roofrack
    I'll keep y'all posted...
    Nick
  20. #359
    Dec 2013
    Paarl
    Thanked: 506
    Quote Originally Posted by SupremeSpring View Post
    Why not make us a Quick release Stabiliser bar for Jimny.. NOW THAT WOULD BE COOL..
  21. #360
    May 2007
    Uitenhage
    Thanked: 48
    Quote Originally Posted by Nick_G View Post
    Hi all.
    Nick
    Hi Nick.
    The orerak is perfeck, with the exception of the two side gaps. They are not required for the facelift.
    Suzuki Jimny
    Underbody Protection
    40mm Lift with Gabriel HDP's
    Some form of sound.
  1. Replies: 35
    Last Post: 2012/07/21, 12:05 PM
  2. Jimny - Wobling steering wheel
    By Monkey-D in forum Suzuki
    Last Post: 2011/09/14, 10:29 PM
  3. Jimny for a daily.
    By Stevh0 in forum Suzuki
    Last Post: 2009/11/26, 12:23 PM
  4. SA Women vote Suzuki Jimny Tops
    By Sawdust in forum Suzuki
    Last Post: 2009/10/16, 10:43 AM
  5. Jimny goes to Tiffendell
    Last Post: 2009/08/20, 02:52 PM
