Nic
Watter slides het jy gebruik? Die 9330 of die 7330?
Onthou net dat die toegelate massa op die slides net op 450mm extension is, nie op vol extension nie.
Uys
Hi Guys,
Just finished building a new slide for the bin.
I went for a flat slide instead of the drawer system as I feel that this gives one more flexibility when it comes to packing. Loose boxes on top does the trick for me.
It was a lot easier than I thought.
I tested it with 90kgs of "live load" and it still cleared the end of the tailgate by 5mm.
Started building another one at high level, just high enough to clear my fridge.
Will post as soon as this is finished.
97 Land Cruiser GX 80 - 1FZ-F
09 Challenger Wilderniss
06 VW Passat 2.0 TDi
06 Opel Corsa 1.4
Nic
Uys
Everything is a hammer.
Unless it is a screw driver.
Then it it a chisel.
083 399 2046
Nice!
Fortuner 2.8 GD-6 4x4 Auto
(Tough Dog Suspension / Frontrunner Roofrack and some more goodies...)
Wow....
This is amazing!!
How much did it set u back?
How long did it take to make it?
Will u take orders?
Regards,
Conrad
Uys,
7330 x 1m lank.
Ja, die supplier het genoem dat die gewig op 450mm geneem word,
maar soos dit 'n goeie ISUZU man betaam wou ek dit net 'n bietjie verder toets as wat ek toegelaat word.............
Conrad,
No orders, but thanks for the compliment.
All in it was just shorth of R900.
I got a quote from a "professional" for R2400
06 Opel Corsa 1.4
I've had one or two requests for more details from Coop and others.
I bought the slides from “Furnlock & Slide” in Cape Town (021 558 3373).
I used the 7330 x 1m long.
See their website for other options and contact details elsewhere:
http://www.furnlock.co.za
Attached is a section of the build-up that I designed and used.
You can find all the aluminium and Connect-It blocks at Maizey’s in Paarden Island (021 511 9783)
See their website for details on how this works – very simple and cheap – it saved me a lot of time.
They will cut the aluminium for you to exact lengths.
http://www.maizey.co.za
I also glued a thin rubber mat to the top to prevent slipping.
The whole thing took me about 7 hours to build, spread over a couple of nights during the week, as I sorted out details and bought the stuff bit by bit as I went along.
Hope this helps.
06 Opel Corsa 1.4
Thanks Nic H, I will definitely spend some time on this one.
Thanks vir baie nuttige inligting - veral omdat dit inni beskikbaar Kaap is!
Isuzu KB300 4x4 D/C
KTM 1050 Adventure
BL Boskriek #659
Nic Job well done.
However, I have a few questions:
1. I assume that your alluminium frame have a few support to prevent sagging
2. what locking mechanism do you plan to use?
3. how do you tie down your stuff on top of the slide
Francois
Francois,
1. The aluminium all round frame and 16mm supawood make for a very rigid platform. It's a bit heavy though. For the upper side I'll be using plywood with intermediate support yes.
2. No locking mechanism currently, but realised this will be necessary when parked on an incline. Anysuggestions?
3. I've added small ring type tie-downs on both sides of the platform at 300mm c/c in order to tie straps to.
06 Opel Corsa 1.4
Nic
I used this type with my fridge slide:
(Just attach a piece of flat metal with a hole drilled through to the side of the slide). You can purchase them at any hardware store or at places that sell trailer parts (like McNaughtans in Parow). At Fastener Warehouse in Brackenfell they were fairly inexpensive (can't remember the exact amount, but definately under R50).
Francois
As discussed:
Francois Johnson
(swambo: Christel)
Our rides
- 2010 Isuzu KB300LX DTeq 4x4 D/C
- Metalian Maxi Trailer, Maxine
Now that's a neat drawer!
06 Opel Corsa 1.4
Very nice! Let me know if you're in the market to build another one...
Just needs a bit of finishing, some tie-downs and a lock and I'm done!
Kom CCP, jy raak agter!
06 Opel Corsa 1.4
Nic
I must admit: this is a very professional job. Well done - now you will enjoy your vacations even more! AND, I have work to do...a second platform is definitely on the cards for me.
Francois
Francois Johnson
(swambo: Christel)
Our rides
Yes, I bolted brackets (square tube) to the downstand lip of the rim at the top of the bin and then bolted 3 aluminium square tube bearers to this accross the bin to carry the slide. I again added hard compound rubber strips between the bearers and brackets to prevent things from shaking loose.
See attached sketch.
Nohing attached to the roll bar.
I still need to add the infill pieces on the sides.
Your idea of a storage space in the "ceiling space" sound very interesting.
Send pics if you have please.
06 Opel Corsa 1.4
Hi Nic
The slide looks geat, actually planning on building one myself now. Just one question, what is the spec of the rubber strips you used, and where did you get them from?
Andrew
VW Touareg V8 TDi
Isuzu KB 300 D-Teq 4x4 DC -Sold
Isuzu Frontier 320 4x4 - Sold
Hi Andrew,
I just asked for a hard compound rubber strip.
The guys at Cape Town Rubber cut me 45mm wide strips from a 15mm thick sheet.
021 511 0850.
Up your way there's a place called TRUCO (Transvaal Rubber Co.) 011 839 2370 that seems to stock similar products.
Hope this helps.
06 Opel Corsa 1.4
Thanks Nic, much appreciated
VW Touareg V8 TDi
