Cruise control for 03 KZTE
Results 1 to 10 of 10
    Default Cruise control for 03 KZTE
    I am planning on doing a couple of repairs and mods to my Hilux in the following order:
    1)Replace clutch - bearing bit noisy and slight shudder
    2)Service injectors and re-map Unichip
    3)EGT gauge
    4)2nd battery system (PBE or NL)
    5)Maxe OE bullbar
    6)OME suspension upgrade
    7)TPMS
    Radio
    9)Roof console to house NL controller, EGT gauge, TPMS, radio etc
    10)Cruise Control
    The bee in my bonnet at the moment is researching the cruise control and as far as I can gather the 03 KZTE is drive by wire (is this correct?). Has anyone done a retrofit like this before? I am looking for suggestions on a stalk that looks OE and I also need wiring diagrams on how one would go about fitting cruise control - I do everything myself (not the clutch and injectors).
    Another question - did the 03 IFS Hilux or the Prado in that period come with the option of cruise control cause maybe I can use that.
    Any help and suggestions appreciated. Thx
    Pieter
    10 Toyota Prado 150 4.0 VX
    03 Toyota Hilux KZ-TE 4x4
    99 Isuzu 2.8DT LX 4x2 (Sold)
    95 Isuzu 2.8DT LE 4X2 (Sold)
    4ePikanini Guest
    You have two options.
    1. Factory option with kit and ecu re-program
    2. Aftermarket kit linked to throttle pedal - google 'audiovox ccs 100'
    Strand
    Thanked: 21
    Default KZTE Injectors
    Pieter, this is what the injectors look like. Easy Sat morning service on all 4.
    Enjoy it.
    I might be a FOOL, but I am an OLD fool - from unknown.
    hotshot Guest
    Hi Pieter. I would like to know more about your roof console.
    Quote Originally Posted by 4ePikanini View Post
    I did not realise that the KZTE had the option of a factory option kit - would you maybe have any part numbers, wiring diagrams or additional info on the kit or parts.
    Pieter
    Quote Originally Posted by hotshot View Post
    I am still doing research in my quest to build one. I am not paying R3500 for something that I am not hundred % happy with. I want the roof console to have reading lights and space for all my gadgets. Will let you know once I am done (could be a while!)
    Pieter
    Quote Originally Posted by Ockert123 View Post
    Enjoy it.
    Ockert, het nie besef dis so maklik. Kan jy my help asb - presies hoe gaan ek te werk en wat het ek nodig om te vervang en moet ek dit by Toyota koop?
    Pieter
    Nigel
    Thanked: 2078
    Speed control ?? KZ ?
    A brick would do.
    Uniglide
    +27 zero eight 2 four 95 9252
    A brick would do.
    I know -but really having a brick in my car does not do it for me
    Seriously, I normally cruise at 110 or there around and speed control makes the journey so much more pleasurable.
    Pieter
    Langebaan
    Thanked: 13
    When I bought my 2.7 I fitted a speed cruise. Fantastic for a heavy foot. I even save fuel with it.
    Carel Pieterse
    2015 Toyota Hilux Legend 45 D/C 4x4 D4D
    2015 Toyota Prado VX D4D
    2019 Conqueror Comfort Platinum
    By charlatan in forum Jeep
  2. Replies: 12
    Last Post: 2012/04/26, 07:53 PM
  3. Grand Cherokee Error code
    By Nick47 in forum Jeep
  4. Cruise control
    By NO FEAR in forum Jeep
    Last Post: 2009/03/23, 12:25 PM
  5. Cruise Control
    By Donovan in forum Vehicle & Technical Chat - General
    Last Post: 2007/06/02, 05:37 PM
