Carb settings
Results 1 to 3 of 3
Thread: Carb settings
    Barberton
    Thanked: 973
    Default Carb settings
    Gents,
    Please give advice. I was staring down a Nissan 1400 LDV carburettor over the weekend. I friend has this 20 year old 1400 for fishing, doesn't even remove his fishing rods or worms between trips. It is terribly down on power and up in fuel consumption. He has had it serviced, which included new plugs, points, condenser and filters (air, oil and fuel). Unfortunately it didn't make much of a difference.
    He asked my advice (indication of how desperate he must be). I dug out the old timing light (haven't used it in two decades), hoping for a quick fix. No problem there and the engine sounds lovely.
    After staring down the carb, my poorly judged opinion is that the second stage doesn't "kick-in".
    PLEASE: any advice on how to confirm that my diagnosis is valid and advice on how to help my mate solve his problem will be hugely appreciated.
    Roelf
    Barberton
    4ePikanini Guest
    low on power and high on fuel consumption is usually jets or vacuum leaks.
    I suspect he hasn't fiddled so trace the old rubber pipes and check for vacuum leaks.
    My own world
    vacuum advance working?
    Second stage isn't here an diagram thats activates the kick down ,maybe buggered.
    Ford F250 v8 37' super swamper boggers ,
    Ford F250 V8 35's Maxxis ,
    Colt 4x4 2.8
  1. 36 Zenith Carb on Series Landy
    By snoopy in forum Land Rover
    Last Post: 2009/08/01, 02:44 PM
  2. Corolla 1.3 head bolt settings
    By KobusDJ in forum The 4x4 Pub
    Last Post: 2009/01/10, 01:23 PM
  3. Carb setting 125 2 stroke.
    By Koekies in forum Vehicle & Technical Chat - General
    Last Post: 2008/01/24, 12:07 PM
  4. Nikki / Weber 36 Carb?
    By JP in forum Toyota
    Last Post: 2007/05/15, 02:42 PM
  5. Quick Reply & Other Settings
    By imported_admin in forum General 4x4 Discussion
    Last Post: 2006/09/08, 10:50 PM
