Hacking car remotes
Results 1 to 20 of 20
    Nigel
    Thanked: 2294
    Default Hacking car remotes
    Has anybody come across this yet?
    I locked my car. As I walked away I heard my car door unlock. I went back and locked my car again three times .. Each time, as soon as I started to walk away, I would hear it unlock again!! Naturally alarmed, I looked around and there were two guys sitting in a car in the fire lane next to the store. They were obviously watching me intently, and there was no doubt they were somehow involved in this very weird situation. I quickly chucked the errand I was on, jumped in my car and sped away.. I went straight t o the police station, told them what had happened, and found out I was part of a new, and very successful, scheme being used to gain entry into cars. Two weeks later, my friend's son had a similar happening....
    While traveling, my friend's son stopped at a roadside rest to use the bathroom. When he came out to his car less than 4-5 minutes later, someone had gotten into his car and stolen his cell phone, laptop computer, GPS navigator, briefcase.....you name it. He called the police and since there were no signs of his car being broken into, the police told him he had been a victim of the latest robbery tactic -- there is a device that robbers are using now to clone your security code when you lock your doors on your car using your key-chain locking device..
    They sit a distance away and watch for their next victim. They know you are going inside of the store, restaurant, or bathroom and that they now have a few minutes to steal and run. The police officer said to manually lock your car door-by hitting the lock button inside the car -- that way if there is someone sitting in a parking lot watching for their next victim, it will not be you.
    When you hit the lock button on your car upon exiting, it does not send the security code, but if you walk away and use the door lock on your key chain, it sends the code through the airwaves where it can be instantly stolen.
    This is very real.
    Be wisely aware of what you just read and please pass this note on. Look how many times we all lock our doors with our remote just to be sure we remembered to lock them -- and bingo, someone has our code....and whatever was in our car.
    Uniglide
    +27 zero eight 2 four 95 9252
    The Windy City
    Thanked: 3849
    From eBay....
    Detect, receive, copy all kinds of car remote control signals, then command the car as freely as the carís owner
    - Working frequency range: 305~330MHz
    - It receives the signal sent by the fixed code anti-theft system, save and copy the masterís remote control signal
    - The effective distance is 100 metres
    Nigel
    Thanked: 2294
    Eish.
    So my old school, mechanical, "draad en tang" approach is still the best.
    Uniglide
    Jan 2009
    Aston Manor
    Does the copying of the signal also apply to the systems using "code hopping" seeing that the copy made is from a now defunct signal and the next one should be different, not the same?
    Oct 2006
    Redland Bay - Queensland
    So much for 'keyless' systems! The newer 'hopping code' systems should overcome this problem provided these scanners are not clever enough which I doubt! Some cars don't activate the alarm system unless it's set via remote so locking the car via key is not always the best. Here the infrared 'point at receiver' remote system is maybe safer.
    Toyota Hilux D4D SR5
    ZS6YR/VK4JHE
    Oct 2008
    very scary stuff.... not just in being burgled... but it opens a doorway to others waiting for you inside the car.
    '94 Land Rover Defender 110, 200tdi
    COFFEE.EXE Missing - Insert Cup and Press Any Key
    Jan 2007
    Thanked: 325
    My Colt's remote is so weak, you have to stand right next to the bakkie to be able to lock/unlock it...
    4ePikanini Guest
    Quote Originally Posted by dph View Post
    same story with my Jetta
    On the other hand my owner's manual says that encrypted communication takes place between car and remote and that the signal security code is scrambled every time it is used.
    Thanked: 14
    Quote Originally Posted by Renier View Post
    OR worse they UNLOCK the doors for you in your driveway.
    Code hopping is the way to go. We have recently upgraded all our remotes in our complex to code hopping. i have a security gate between the garage and the house for exactly this reason. garage door is one of the easiest to copy.
    Should be simple to upgrade your cars system, the wiring is already there, just a better remote and receiver...............IT SHOULD BE
    Wonder what the insurance has to say about replacing all your stuff without any forced entry signs. With their track records they will probably say the police are DREAMING.
    Hilux Dakar & Comfort trailer
    The first 40 years of childhood are the toughest!
    Apr 2008
    JHB
    Holy smoke!
    Cloning of remotes like this was a big thing about TWENTY YEARS ago.
    That's precisely why rolling code (aka code hopping) remote schemes were invented.
    (South African invention, by the way, now used the world over.)
    I am in the security business and I am not aware of anyone having cracked rolling code technology. I'm pretty sure it would have been discussed in many different security journals and Internet forums if it had happened.
    I therefore assume that the remote control system in this particular story is the much older fixed code type, which is amazing - I had no idea any vehicle manufacturer still installed fixed code systems.
    Picking up the signal from a fixed code remote and then copying it is very easy and has been happening for a couple of decades already. Nothing new.
    Usually you don't find any fixed code systems on vehicles although many remotes used for gates and garage doors are still of the fixed code type due to the cheapskate nature of the SA public who would rather save ten bucks than have decent security.
    Tim
    Scepticism is the highest of duties,
    and blind faith the one unpardonable sin.
    T H Huxley
    Nov 2006
    Thanked: 432
    Few months ago I locked my bakkie door with the remote and heard the Caravelle parked next to it unlock its doors.
    Came back later and the Caravelle was still there. Unlocked my vehicle and the Caravelle answered with a flash but I couldnt hear doors locking.
    Happened again a few months later at the mall with an Audi parked two cars away. I press the button, the Audi howls. Had fun for awhile.
    Explanation? Naw, not from me.
    Thanked: 1185
    Quote Originally Posted by TimJNB View Post
    H
    Of course is an SA invention - all good security inventions are!!
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Apr 2008
    There was a recent claim from someone in our neighborhood watch community that the Hummer remote was found to be able to open certain types of gate Motors. I assume these are the transponders that don't use code hopping. I will see if I can locate that email. Specific mention was made of the "vulnerable" transponder boards.
    Feb 2012
    WC
    Thanked: 12
    Greetings - I respect this is an old thread, also not sure if there are other more current threads to this, and if so please accept my humble apologies.
    Just over a year ago in the (very busy) parking lot of Raslouw Lifstyle Centre (next to the Mall @ Reds) Centurion, we arrived back at the car after about 10 minutes in the shop at around 17:15 on a Friday - unlocked the car, got in and went home. Only on the way home did we realise cell phone, camera, GPS was missing from the center console box. Nothing we could do.
    There is a fair amount in the media which mentions that crinimals also use specialised electronics and gadgets which the dealers have. This puts vehicle owners in a bit of a predicament and opens other untoward channels such as those bad apples that will take advantage in other ways. Time to weld a big old padlock onto each door it seems.
    A little off-topic "maybe", but the few times I have been in these big electronic supply shops, I have often wondered about the devices and circuitry bought by some customers - highly opinionated and unfounded of course, but I seriously have my doubts. As they say "Africa is a tough country".
    Garsfontein
    Thanked: 564
    I'm so glad my car is still manual locking...
    Dana Bay / Qatar
    Thanked: 88
    Don't need sophisticated devices to "open" cars with lately. You can try this at home, it works.
    When you walk away and push your lock button on your remote, the car will never lock if someone close to you have a regular, every day gate or garage door remote that they push and hold. This "jam" the signal from your remote to your vehicle and it doesn't lock. You think it is locked and walk on and the bad guy comes, opens the door and does his affirmative shopping.
    2015 Nissan X-Terra
    2006 KTM 950 Adv
    All the great things are simple, and many can be expressed in a single word: freedom, justice, honor, duty, mercy, hope.
    Winston Churchill
    Pta
    The South African invention is called Keeloq: http://en.wikipedia.org/wiki/KeeLoq
    It got cracked in 2007: http://www.wired.com/threatlevel/200...searchers-cra/
    Kathu
    Thanked: 2847
    Thumbs up
    Eish.
    Feb 2012
    WC
    Thanked: 12
    Quote Originally Posted by jfe View Post
    A couple of mates got together at work and did this on each other's different cars to which ones it works on and which it does not. Very interesting and amusing for what a bad thing is worth. good eye opener for people to see the actual risk under safe conditions
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 190
    My standard gate remote so far jams any vehicle I have come across locking signal.
    Just hold it down and the vehicle does not lock up to 20 meters away.
    Although it does not impact the Netstar system as this works every time. Tried to jam it with some "other equipment" and it still works.
    Seems to lock your vehicle you must key it and then push the remote to activate the alarm. Else have you Netstar wired to the locking gadget and alarm system.
    Some manufactures does not allow this and with the GM products it is not possible - so far?
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  1. Hacking a car CD Frontloader
    By jdjoubert in forum The 4x4 Pub
    Last Post: 2009/09/10, 10:47 AM
  2. Replies: 6
    Last Post: 2009/06/08, 09:17 AM
  3. Has your car Lost HALF its Value ?
    By JeepOnly in forum General 4x4 Discussion
    Last Post: 2007/03/23, 02:31 PM
