Results 1 to 4 of 4
Hybrid View
    Blouberg
    Default Pajero 3.5GLS AT Transmission fluid in Radiator
    Hi guy's, just wondered if anyone has experienced the same thing and can maybe offer some conclusive advice...?
    2001 Pajero 3.5GLS AT Transmission fluid ends up as a red murky bubbling fluid overflowing from the Radiator water container. Apparently I need a new radiator but surly the AT oil cooler is a separate item?
    How does the transmission fluid end up in the water system..?
    Help..!
    Greets
    Will
    4ePajero Guest
    The ATF cooler is in the radiator's bottom tank.
    Replace / repair radiator and have transmission flushed and refilled with ATF - don't drive it before you do it!!!!
    May 2007
    Thanked: 10
    Quote Originally Posted by Madwhily View Post
    Help..!
    Greets
    Will
    It is a recurring problem on the older Audi A4's. As per 4ePajero's advice, the radiator goes, the water and ATF mix, and, on the Audi, the water contaminates the PAPER clutches in the ZF gearbox, causing them to swell and, eventually, stick. What gearbox does the Pajero use?
    I am not a complete idiot - there are still some parts missing
    Please don't send me a PM without direct contact details
    97 SVM 3000
    86 HiLux D/C
    Blouberg
    Thanks Guy's, found a post on the forum, thanks to Rui, got good advice on what to do very helpful guy too.
    Original Post: http://www.4x4community.co.za/forum/...990#post217990
    Greets
    Willy
    By charlatan in forum Jeep
    Last Post: 2020/06/01, 01:02 PM
  2. Grand Cherokee Error code
    By Nick47 in forum Jeep
  3. Pajero io or 3.5gls swb or 3.0swb, please help
    By The Lee in forum Introduce yourself
    Last Post: 2009/06/09, 09:39 AM
  4. Pajero Radiator
    By tjs in forum Mitsubishi
    Last Post: 2009/05/25, 03:04 PM
  5. New Pajero
    By Gerrit Loubser in forum Mitsubishi
    Last Post: 2006/11/04, 03:40 PM
