Results 1 to 6 of 6
    Sep 2012
    Thanked: 29
    Default Koste van "grid tie"
    As mens hier in die Wes Kaap n grid tie inverter het wat krag terugstoot na die Grid- wat is die koste verbonde per maand - ja ek weet hulle betaal iets soos 83c per kw/h, maar is daar enige "levy" per maand - mens hoor allerhande stories wat nie sin maak nie
    So is hier iemaand wat n "grid tie" stelsel het - wat is julle mndelikse koste behalwe die verbruik - praat met my.
    Dankie
    Feb 2013
    Da Bush - ZA
    Thanked: 7728
    Default Re: Koste van "grid tie"
    If there's someone who will know, it will be TTT, I know he is pretty up to date with the CT regulations and have researched it extensivly.
    Before you judge a person, first walk a mile in their shoes.
  3. The Following 2 Users Say Thank You to bigboy529 For This Useful Post:
    Cape Town - RSA
    Thanked: 1270
    Speaking from memory.
    There is a R5 monthly meter fee that gets added. So not an issue
    There is a bi-directional meter that you must buy R6000 for single phase.
    You need to apply as a complete new SSEG application which may cost you some money.
    There must be a physical disconnect box outside your property so that they can manually disconnect your house if they need to do work etc. Cost is not that much but probably a few thousand depending on complexity.
    application is through the online portal and if you have a decent installer is pretty straightforward.
    So the math is, if you spend R10 000 to get it done, how long till you pay it back vs buying a 3/4th battery.
    2017 Venter Savuti + Tentco Jnr, Dometic CF50 Fridge + Ecoflow River Pro and 120W solar panel.
    Ex - 2005 Cherokee CRD
  5. The Following 3 Users Say Thank You to Quiksilver For This Useful Post:
    Friemersheim, Southern Cape
    Thanked: 8928
    Quote Originally Posted by Reccepops View Post
    Dankie
    Moet se, as 'n klein gebruiker en opwekker is die kool nie die sous werd nie
    Robert van den Berg
  7. The Following 5 Users Say Thank You to Prof For This Useful Post:
  8. #5
    Thanked: 3546
    Thanks.
    Summed up nicely what Quicksilver said.
    Application is through the online portal and if you have a decent installer is pretty straightforward.
    What one could add:
    When you run the grid-tied inverter flat-out to earn income, good idea to factor in a earlier replacement costs just in case.
    I concur 100% with what Prof said:
    Political Correctness
  9. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
  10. #6
    Cape Town - RSA
    Thanked: 1270
    If I was installing a brand new build today, in CoCT. I would opt for a grid feedback. Just to have it done and done.
    If you have an existing installation, the schlep of getting it done doesn't seem worth it.
