Results 1 to 10 of 10
    May 2010
    Bethal
    Thanked: 8
    Default Winch on winch bracket behind OEM bumper. ???
    Looking for help + advice. Is it ok to fit a winch behind the OEM bumper. I need to fit a winch with a front removable Tow hitch. This is mainly to Surf launch and retrieve a Ski boat.
    What is the size of the winch that is able to be fitted behind the OEM bumper. I am looking at a Runva 9500lbs to 12000lbs. Not sure what will fit.
    It must have the removable tow hitch similar to what is fitted to the back of OEM Hilux. It will be installed on 2023 Hilux ext cab.
    2nd Question: Where could I get this done. Supply winch bracket, supply tow hitch bracket and either I can supply the winch or they could. Plus installation.
    Thanked: 637
    Default Re: Winch on winch bracket behind OEM bumper. ???
    Stofpad4x4 can help you on the plate and tow-hitch receiver (if they still make them).
    https://www.stofpad4x4.co.za/winch-plates
    Quote Originally Posted by Rollercoaster639 View Post
    Neil
    Plett
    Thanked: 5565
    I have done this on numerous vehicles. Very worthwhile
    2024 LC Prado 250 VXR
    2025 Tank 300 2.0 Super Lux
    2017 Chevy Trailblazer Z71
    BL Kewer 3188
    Tarpon 170, 2x70 Yammies
    Plett
    Thanked: 5565
    Landylove on the forum can help I’m sure
    Nomadic Gear
    BL Kewer 3188
  5. The Following User Says Thank You to BruceHun For This Useful Post:
    Thanked: 6125
    Quote Originally Posted by neoT View Post
    Yes, we do make them- but the type of vehicle wasn't mentioned.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
    Thanked: 637
    ....2023 Hilux ext cab.
    Neil
    May 2010
    Bethal
    Thanked: 8
    Hi Uys
    It will be installed on 2023 Hilux ext cab..
    Do you guys also do fitments.
    Thanked: 6125
    We make them for the D4D and GD6.
    There is a place in Ermelo that often buy from us, just can't remember their name.
    083 399 2046
    Mar 2017
    Okahandja
    Thanked: 2704
    Seikel also does it
    WELLINGTON
    Thanked: 205
    I had something made up for me many years ago...Removeable winchplate that fit into a receiver on my Land cruiser back and front. Same size receiver...with all connections. Winch was bolted onto the plate and could be carried around... I am sure someone will be able to create a similar set-up for you.
    The idea was to be able to attach the winch both on the front and at the back to be able to winch both ways...
    Note that I did not have the original front bumper But maybe a plan can be made. You don't say what vehicle you are driving so one has to guess with regards space available behind your bumper.
    ON the pics you see the actual plate with it's retaining pin, and on the other you see the square receiver on the bottom of the left hand side, bumper with the electric coupling next to it. Grey Brad Harrison plug. 100A I believe?
ID:	754306   Click image for larger version.
    John van Dyk
    Land Cruiser VX 4.7l V8 1999 - verkoop
    Mercedes - Benz GLC 250 -2017
    Mercedes Benz G350 D 2021
    Bush Lapa - Boskriek 2021
    Mercedes Benz E 200K - nou seun se vrou se ryding
    Noname Boswa -
    VW California - SOLD
