Towing Regulations - Page 9
Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 161 to 173 of 173
  1. #161
    Garsfontein
    Default Re: Towing Regulations
    Quote Originally Posted by Ericl View Post
    Hi,
    The short answer is no - a C1 only allows for a 750kg trailer, you will need an EC1 license.
    See attached.
    100%
  2. #162
    Aug 2018
    Swakopmund
    Thank you
    This forum has such a wealth of information to offer
  3. #163
    standerton
    I need to use an A-Frame to tow a Bantam bakkie.
    Where can I find the regulations regarding this perhaps?
  4. #164
    Apr 2011
    Hartbeespoort
    Looking for advise on the license requirements for a goose neck trailer / horsebox being towed with a cruiser with ebrakes.
  5. #165
    Langs die rivier, op n berg
    Quote Originally Posted by MickPrado View Post
    Eerste vraag, watter cruiser? Meeste cruisers kan/mag nie meer as 1500kg sleep nie.
    Kyk binne bonnet of in deur pilaar op plaaitjie wat gcw van voertuig is.
  6. #166
    Garsfontein
    Do you mean the drivers license requirements, or something else?
  7. #167
    If you have coupled brakes and a eb license (old code 08) then you should be fine up to the tow rating of the tow vehicle.
    As mentioned elsewhere, Toyota’s traditionally have very low tow ratings so check what your maximum towing mass is.
    Also make sure you do not fall foul of the gcm.
    Perhaps post the trailer Tare mass and gross mass. Then the tare for your Prado, as well as the gvm and gcm for the prado.
    A little more detail on the electric brakes would also be interesting and are they locally approved? Sabs or similar?
  8. #168
    Goose neck? Does that mean with the 5th wheel in loadbox type of hitch? So only on bakkie?
  9. #169
    This consept?
  10. #170
    Nigel
    This consept?
    Will, If you chop the back of the 100, fit a disc, you will have a brilliant tow vehicle. Just make sure your cooler is sufficient.
    Combined mass on that car is 6780kg
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  11. #171
    Default Towing Regulations
    Solank die 100 n fabrieks 4.2td of 4.7v8 is. As dit n 4.2d 4.2 afternarket turbo, of 4.5 is, gaan dit glad nie werk.
  12. #172
    Apr 2011
    Hartbeespoort
    Big question is what drivers license would be required and do brakes have to be air or electric?
  13. #173
    What vehicle did you had in mind? You said cruiser. Can you be a bit more specific. That should be your starting point.
    For drivers licence and brakes, what would you think would be the maximum loaded mass of the trailer?
  1. Fortuner Towing with a Hilux or Fortuner
    By Uys in forum Toyota
    Last Post: 2014/10/13, 01:15 PM
  2. The new legislation and towing
    By Poen in forum 4x4 Recovery & Recovery Gear
    Last Post: 2009/08/16, 06:22 PM
  3. DiscoII V8 fuel consumption and towing?
    By PolarBear in forum Land Rover
    Last Post: 2008/10/06, 07:39 PM
  4. Towing Bush-Baby trailer with Ford Bantam
    By ZR6SGN in forum Camping, Fridges, Accessories
    Last Post: 2008/05/06, 01:42 PM
  5. 2800tdi for towing?
    By lostprophet in forum Mitsubishi
    Last Post: 2008/05/04, 09:28 PM
