Steyr Puch Haflinger 4x4
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 47
    Default Steyr Puch Haflinger 4x4
    Hey Guys,do any of you know these 4x4's,they are quite strong and has front difflock rear difflock and full difflock (4x4)
    They have a 700cc 2 cylinder Boxer Motor.....They were used by the austrian army
    I am looking at buying one of them as a hunting vehicle?How do they compare to a Polaris Ranger XP 4x4 Side by side?
    was the polaris built off the same principle?
    Thanx Guys
    Waiting For Your Reply's
    Jan 2007
    Tamboerskloof, Cape Town
    It's the vehicle with the lowest maximum indicated speed - there should be a little plaque on the far right of the dash - in 1st gear that I know of, ie the crawling ability is incredible, so if that would be useful to you it's something to consider. It doesn't have low range as such, but the gearing is so low anyway that you would probably only use 3rd to 5th on normal roads, and 1st to 3rd on difficult terrain. As you'll also see on the same plaque, maximum speed in general is low, somewhere in the region of 40-odd kmh. I'm pretty sure a Ranger would be faster, but you could confirm that with the agents. Finding parts for it is quite a bear, obviously.
    Family member had one that we used in the mountains of Mpumalanga, quite awesome offroad but bloody slow!
    May 2007
    Daar by die gat,in die NK
    Vir interisandheid, How much? Ek sal like van so iets! het nie werk vir dit nie maar 'n "nice to have"
    No one ever ruined their eyesight by looking at the BRIGHT side!!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Nissan King Cab (aka Navara )
    Albert Einstein
    Whoooopa 3 The Goat strike back
    https://www.youtube.com/watch?v=uqw5...ature=youtu.be
    Another teazer.....
    https://www.youtube.com/watch?v=51KljMSXOnI
    Pune
    There was a nice restored one on Gumtree for R45K.
    Hehe,speed isnt a great factor we want to use it for hunting,and picking up the animals in rough terrain we bought a nice one from a oke in JHB,for R35,000,its still in good condition and compared to the price of the polaris @R135,000....it was a good buy.
    Here is a pic of the one we bought....
    Thanx Guys for your replys.....
    Check out Puch on Youtube.....these things look awesome....hehe
ID:	37254   Click image for larger version.
    Jan 2007
    Good grief, that one looks brand new! 8)
    Because they have portal axles, their ground clearance is totally off the chart compared to anything else with the same 11" stock wheel size; something like 235 mm, iirc. It's better, in fact, than many modern-day bakkies' clearances, and with a track width of just more than 1 m, a wheel base of not much more than that and approach and departure angles to dream about, you'll appreciate why their slogan reads something like, "Going places other 4x4s can only dream about."
    May 2007
    Baie ougat!! Ek dink ek het 'n nuwe ryding vir die Heks gekry!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Albert Einstein
    Another teazer.....
    Jan 2007
    Quote Originally Posted by Frans Reichert View Post
    Dis 'n baie lekker inkopietrollie... 8) Parkeerplekke voel so groot, 'n mens het sommer lus om hom net daar op die plek om te draai net om te wys jy kan!
    Check out this link for all the specs.....ours is a 1972 Model with 7000Km's on....not bad....
    http://www.motorestropicales.com/Haflinger_Specs.pdf
    Here's a article about the history of the puch.....
    http://www.hy-q.com/cooper/haflinger/download.htm
    Wow, Dons baie mooi Puch !
    Dankie Vlakkie,sal nog fotos opsit as ons die jagraam,winch,bullbar en runnerbars opgesit het,hehe,ons wil n tipe foam in die wiele pomp,sal dit werk vir sekelbos dorings?....
    ek dink as die wiele gevul is met die foam,gan daar baie min goed wees wat die puch gaan stop.....
    Dankie mense vir al julle reply's
    DonS
    Hey,het vandag die puch gaan haal en is baie tevrede,die dingetjie is awesome,ons het bietjie by die werk met hom gespeel,hy het sonder enige moeite oor die 4 pallets geklim,en sy spoed is ook nie te versmaaie nie
    Hier is n paar fotos
    Groete....
ID:	37292   Click image for larger version.
ID:	37293   Click image for larger version.
    Hey mense,update op die puch,ons het vandag begin met die modifications op die hilux se jagraam vir die puch....
    ons moet die trap sak en daar moet nog n pyp inkom,die raam werk heel goed uit,hy sit op dieselfde hoogte as wat n land cruser se raam sit....en die raam dien ook as n rollbar,sou dinge skeefloop....
    die raam is 600mm te lank,so ons sal hom moet korter maak...
    Ek het ook die puch se silencer afgehaal en n ander een opgesit
    (Wat ons by gekry het) het die olie geruil,olie filter,airfilter en moet nog die belde bietjie stywer stel....
    Gaan hom weer oor spray,weet iemand wat noem mens die kleur wat die land crusers in uitkom,daai khaki kleur....
    Dankie
ID:	37341   Click image for larger version.
ID:	37342   Click image for larger version.
    zs6p Guest
    Ja, di's jammer dat so 'n uniekie voertuig nou belas moet word met al die pyp rommel op hom want hy was in elk geval nie ontwerp vir so 'n loonvrag nie.
    Die Puchs wat in die RSA is, kom van die dep. van Bosbou/Waterwese, die weermag en vanuit Bechuanaland Protecturate, nou Botswana, waar hulle ook in hul destydse weermag diens gedoen het. Myne het van laasgenoemde gekom en was 'n komunnikasie voertuig gewees. Ek het hom later aan 'n wynboer in die Kaap verkoop.
    Hier is 'n oulike truuk:
    Vat 'n 210 l drom en spyker hom stewig op die grond vas en die Puch, met al sy grendels gesluit, sal net so oor hom klim. (behalwe as jy olie op die drom smeer!!)
    Tjerk ZS6P
    My late Dad immigrated from Austria in the late 1940's after WW2. and he used to speak of these little things. We actually looked for one for use on our small holding, but that was on the '70's and they were not easily available here. I've since seen a few of them in action .... damn nifty!
    Krugersdorp
    Guys to see their crawling power checkout this link
    http://www.youtube.com/watch?v=JOKIe...455296&index=3
    Amazing!
    Jan 2007
    Apparently they were also pretty popular for use in the sugar plantations in KZN. Still a couple of them chugging around there, I believe.
    Wel,dit is waarvoor ons hom wil gebruik,om bokke te gaan haal waar ander 4x4's sukkel,die raam en als kan afgehaal word,geen skade word aan die bakwerk gedoen nie.....en het buitendien nie meer die oorspronklikke bak op nie.....verder word niks aan hom verander nie,tenminste gan hy nou gebruik word,en nie in iemand se motorhuis staan en oproes nie....
    Oct 2008
    My pa het destyds 2 gekoop by die weermag wat hulle getoets het. Die kleintjie en 'n groter een. Die weermag kon hulle nie breek nie so hulle is tough. Die grote was ongelooflik sterk. Jy kon sy 4 wiel en diff lock met levers in die kajuit aansit en dit was 25 jaar terug. Hulle kom ook met 6 wiele uit. Hy het dit detyds aan 'n boer naby Wellington verkoop en ek dink hy staan nog daar. Ek kan sy nommer probeer kry as iemand sou belangstel.
  1. Brakkeduine 4x4 Trail near PE.
    Last Post: 2017/11/13, 07:56 AM
  2. Females
  3. Steyer puch haflinger
    By drb in forum Vehicle & Technical Chat - General
    Last Post: 2009/04/24, 04:54 PM
  4. Another bash at The Rocky Mounatin 4x4 Trail
    Last Post: 2007/02/20, 01:19 PM
  5. Search Engines
    By benhur in forum General 4x4 Discussion
    Last Post: 2006/09/14, 09:42 PM
