Results 1 to 5 of 5
    Dec 2023
    Knysna
    Default Discovery 2 ACE Bleeding
Name:	WhatsApp Image 2024-10-12 at 17.28.49.jpg
    My one rear ACE flex hose got damaged, luckily I managed to catch it in time before causing damage to the pump. I have removed the ACE relay and fuse putting it into "block mode" but am still slowly losing fluids. Will have to remove said hose and take to a hydraulics shop here in Knysna to have the flex hose replaced.
    Once I have the newly fixed pipe in hand, do I need to replace the seals that go into the valve block as well? - I've read mixed opinions on this
    Once all is replaced, is it necessary to bleed the whole system again? - some say just drive like a mad bastard, swerving all over and some say, you need a nanocom/testbook and some say it will sort itself out
    If I wish to get rid of the ACE system, can I simply remove the hydraulic actuators/rams, pipes, replace the pump with the aftermarket pulley and shorter belt?
    If not, are there any none ACE anti-roll bars available on the group?
    Thanked: 1728
    Default Re: Discovery 2 ACE Bleeding
    Are you replacing the pipe from the ACE block or just putting a new piece into the break?
    Nanocom does have an ACE bleed function but I've never used it. When I.replaced the hydraulic ram on mine I just drove around a roundabout in both directions, tilting the body as much as I could..Seems to have worked.
    Padraic Berry
    Dec 2023
    Knysna
    I am going to ask that they just replace the flexhose that was broken. I am not sure if the hydraulics shop will be able to do the replacement with the pipe still connected to the valve block.
    My actuators are also leaking a tiny bit so I am considering replacing the ACE with a standard anti-roll setup in the medium term.
    Thanked: 1728
    Speak to Walter at Lrxtreme. I was told they can "deactivate/lock" the system by doing some magic and just adding a new idler pulley and assembly. Not sure how it works.
    I had a pipe repaired in situ by landitech in boksburg. They cut out the damaged piece and put in another piece with hydraulic fittings..
    Padraic Berry
    Thanked: 129
    "Do not try to win over the idiots - you are not the Jerk Whisperer.."
  6. The Following User Says Thank You to Spectator For This Useful Post:
