Results 1 to 20 of 26
    Thanked: 1728
    Default TD5 AMC Head required
    I'm looking for an AMC td5 head, anybody know who still stocks them?
    Padraic Berry
    Mar 2015
    New Germany
    Thanked: 2180
    Default Re: TD5 AMC Head required
    Try Dover parts, British 4x4, LP4A if no one has them your other option is Turnerengineeing in the UK
    2002 Defender with 300TDi VNT modified
    2005 Defender TD5 CR VNT turbo, Ashcroft lockers,HD CW&P, HD side shafts & CV and Pegged, 35” coppers STT pro ………..and more
    Aug 2016
    Thanked: 473
    I know and agree that the AMC head is 1st, 2nd,3rd and 4th prize. But I helped a friend rebuild his TD5 a while back and he used a head from Components for Africa ( Heads for Africa ). That engine is still running with more than 80 000km completed. My old D1 300tdi was also rebuilt with one of their heads and that has done more than 200 000km on the rebuilt engine.
    Thanked: 624
    Www.intrade.co.za
    I recently enquired about another head and they went out of their way to help me locate a head at one of their dealers.
    Si vis pacem, para bellum
  5. The Following 2 Users Say Thank You to thabogrobler For This Useful Post:
    Thanked: 1728
    Found one at Dover, R24k bare R30k with valves..
    Padraic Berry
    Thanked: 624
    Joh, that is dear!
    A bare 1KZ head is R8k now.
  8. The Following User Says Thank You to thabogrobler For This Useful Post:
    Thanked: 1728
    Quote Originally Posted by thabogrobler View Post
    Joh, that is dear!
    There is apparently another brand that sells for R15k. It's a new brand, untested.
    I found a complete motor with 200k km on it fir R35k, on exchange, but one is never sure what one is actually getting.
    Padraic Berry
    Mar 2015
    New Germany
    Thanked: 2180
    I found a complete motor with 200k km on it for R35k, on exchange, but one is never sure wgmhat one is actually getting.
    I would not get another motor on exchange at that price what happens if wanted to swop parts over if so called exchange engine parts were not as good as your old parts
    Thanked: 1728
    There's diesel in the oil, so it's either injector rings or washers or the head that's cracked. Previous owner replaced the head gasket a few months ago, so I'm leaning toward head cracked. I'll first get the rings and washers replaced and then retest. Hopefully that will solve the issue, if not, new head.
    Trouble is I'm overseas for the next 3 months and there's nobody to take the defender to the mechanic...Will have to wait till next year to resolve.
    Padraic Berry
    Mar 2015
    New Germany
    Thanked: 2180
    Get original O rings and washers don’t wast time with aftermarket ones
    also if have to take head off make sure the head dowels are the metal ones not plastic
  13. #11
    Thanked: 1728
    LR quoted me R305.00 per injector for a seal and washer! O-ring R180.00, washer R125.00
    Good grief!
    Padraic Berry
  14. #12
    Mar 2015
    New Germany
    Thanked: 2180
    Good grief!
    I payed 70 pounds think for a set of original green Orings and washers, rather that then some cheap aftermarket ones that leak and have to do the job over again
    Certain parts I don’t touch aftermarket
  15. The Following User Says Thank You to clivemd For This Useful Post:
    _FC
  16. #13
    Aug 2016
    Thanked: 473
    Good grief!
    I had the same thought when I still had my D2. Fitted after market o-rings and washers after reading warning from Clivemd. How bad can the after market ones be afterall...
    Well 2 weeks later I redid the job with OEM o-rings and washers.
  17. #14
    Aug 2010
    Centurion, Pretoria
    Thanked: 222
    Quote Originally Posted by _FC View Post
    What was your car doing with aftermarket o-rings and washers?
    Just 1 more month to save up for seals on my car then I can get her running...
    2001 Discovery 2 TD5 Auto ES. Bonatti Grey.
    2011 Freelander 2 SD4 HSE. Kosrae Green of which there are two in the country...
    2016 Campmaster Compact 100 trailer.
  18. #15
    Mar 2015
    New Germany
    Thanked: 2180
    Quote Originally Posted by mariusrautenbach View Post
    O rings, the diesal starts to bypass them and then fuel starts to dilute the engine oil, oil levels rise lack of lubrication and so on
  19. #16
    Aug 2016
    Thanked: 473
    They leak . Issue is it goes to your oil. So you dilute the oil. I realised something was wrong when I pulled the dipstick and suddenly it was way overfilled.
  20. The Following User Says Thank You to _FC For This Useful Post:
  21. #17
    Thanked: 1728
    I had a discussion with Turner Engineering. They mentioned LR has changed suppliers of injector orings recently. Turner supply an OEM top end gasket set, excl head gasket , incl orings,washers for pretty much the same amount as the lr seals. This is the same set they use.
    Padraic Berry
  22. #18
    Thanked: 272
    Good grief!
    Use TDi injector washers and go to BMG and get Nitrile O rings. Whole lot cheaper
    I did my injectors at least 8 years ago and all going well
    Edwin
    Defender '99 TD5 Pick Up
    Rock sliders, Spare wheel carrier, Roof Rack, Aluminium canopy, Tentco RTT, Tentco Awning, 280Ah Dual batteries, 3 x Sliding Drawers, Water tank, Hot Shower, Kitchen
  23. The Following 2 Users Say Thank You to Defender TAZ For This Useful Post:
  24. #19
    Sep 2014
    Thanked: 117
    I would suggest that you first check for a cracked head. After removing the injectors you can lightly sand the injector bores with 1000 water sand paper, then using a torch shine it inside each bore. You should then be able to see the crack, it almost looks like a scratch but the sanding will make it stand out. I also went the seal and washer replacement way first, but you are wasting time and money. It's easy to do the check yourself and no special tools needed if you can bend a buggered or cheap chinese water pump plier handle to lift the injectors out.. Replacing the head is a bigger job but can be done if you are handy and have decent tools. If you want I can post a pic of what the crack on my head looks like
  25. The Following 3 Users Say Thank You to Duke1098 For This Useful Post:
  26. #20
    Thanked: 1728
    Quote Originally Posted by Duke1098 View Post
    Please do, which cylinder was it cracked on?
    Padraic Berry
