Results 1 to 9 of 9
    cape town
    Default T8 Ford Ranger - AT Tyre advice needed.
    Hi,
    I have the standard 265/65/17 AT Conti tyres on my 2019 Ford Ranger 2.0 XLT 4X4 10 Spd Auto. The tyres are klaar, got 80 000km out of them and its time to replace them.
    I need some advice as I am not a tyre boffin. My bakkie does mostly tar and a little bit of recreational offroad and light towing during holidays.
    My own requirements.
    - Must be at atleast a AT tyre (must look good).
    - Must not break the bank. R3000 - 3700 a tyre around there and I am happy.
    - Would prefer white littering... for the look if possible.
    Do I go slightly bigger? Do I go higher or wider? I think if possible higher and not wider? Is it possible to go 265/80/17 ?
    A friend has suggested I go with General Grabber AT3s, I like the look of the ATX.
    I am in the western cape, northern suburbs - Any specific tyre dealers to go to?
    What do you guys suggest? Personal experience with tyres on Ranger would be appreciated.
    Thanks.
    Wayne Barker
    Oct 2023
    Thanked: 172
    Default Re: T8 Ford Ranger - AT Tyre advice needed.
    Quote Originally Posted by PotholeDriver View Post
    Hi,
    Thanks.
    From my extensive (obsessive if you ask my girlfriend) research, the biggest tyre a ranger can fit is 285/70/r17 but you will have uneven wear and technically apply greater stress to wheel bearings.
    The optimal tyre (and most readily available) is either 265/65/r17 or 265/70/R17. There is very little benefit to going wider and will be more detrimental to your consumption.
    At those sizes you will not be able to get BFs/coopers.
    You can try errolstyres. So far they have the best prices from all my extensive comparisons, (excluding the occasional deal that a retailer has in-store).
    Radar Renegades, General Grabbers, Maxxis At980 and Yokahama Geolander AT/ G015 are all good options for that price range.
    Cheaper options would be Dunlop AT5 / Kumho Road Venture AT52. The latter is available at Lombard tyres for +/- R2800 when I was there in June and they are high rated tyres for that price range.
    Just note if you go from 265/65/R17 to 265/70/R17, your fuel consumption and odometer will be off by +/- 3.5%
    Meaning yohr fuel consumption will be 3.5% better than the odometer figures, and you will be driving +/- 3.5kmh faster than indicated on your speedo (at 100kmh)
    Hope this helps!
    Thanked: 203
    Quote Originally Posted by Oom Walter View Post
    At those sizes you will not be able to get BFs/coopers. You get both these in those sizes, they are just out of the price range mentioned.
    Meaning yohr fuel consumption will be 3.5% better than the odometer figures, and you will be driving +/- 3.5kmh faster than indicated on your speedo (at 100kmh) The speedo will be more accurate. At 100km/h on the speedo you will be doing exaclty 100km/h on the GPS
    Hope this helps!
    Ford Ranger XLT Double Cab 4x4
    Suzuki Jimny
    Auto Union 1000 (DKW)
    Metalian Parthian
    Pyga Stage Max
  4. The Following User Says Thank You to BlueRocket For This Useful Post:
    Thanked: 203
    I have just replaced my standard Conti's with General Grabber ATx in 265/70/17.
    You can defenitley feel it is a heavier and stronger tyre. Ride comfort reduced, you can feel smaller bumps more.
    You can also feel it pulls a little worse than with the smaller tyres.
    From the old worn tyres to the new the diameter difference is quit noticeable.
    You hear them at around 80km/h. Not noisy, you just hear them. At speeds above this, wind and engine noise take over and you don't hear tyres at all.
    Best price I could get was R4300 each.
Name:	WhatsApp Image 2024-09-06 at 12.43.19_48223cb7.jpg
ID:	731346   Click image for larger version.
Name:	WhatsApp Image 2024-09-06 at 12.43.19_2d5d7522.jpg
ID:	731347   Click image for larger version.
Name:	WhatsApp Image 2024-09-06 at 12.43.19_52ec09e6.jpg
ID:	731348   Click image for larger version.
Name:	WhatsApp Image 2024-09-06 at 12.43.19_f61e060b.jpg
ID:	731349   Click image for larger version.
Name:	WhatsApp Image 2024-09-06 at 12.43.19_f7e66e99.jpg
    Suzuki Jimny
    Metalian Parthian
    Pyga Stage Max
  6. The Following User Says Thank You to BlueRocket For This Useful Post:
    Sep 2008
    Vanderbijlpark
    Thanked: 940
    T6
    The Generals are very good value, IMHO, and I'd stick to the standard size (OEM)
    ZS6VL
  8. The Following 2 Users Say Thank You to An3s For This Useful Post:
  9. #6
    Oct 2023
    Thanked: 172
    Man, I had a set of dunlops and went over to BF KO2 and one profile bigger, and didn't notice any difference in rideability, except at highway speeds with the radio off.
    Braking is a bit worse than before too.
    But to me it feels like the bigger tyre soaks up te bumps more and even like it maaaybe pulls away a bit nicer hahaha
  10. #7
    Petoorstown
    Thanked: 225
    I wont go 265/70/17's will stick to 265/65/17's.
    Slower response and slower pull away and it is heavier , bigger tyres is not always better imo. The 265/65 is a nice overall size on your rig .
    2018 VW Amarok V6 TDi
    2017 Toyota Prado 3.0 D4D VX
  11. The Following User Says Thank You to The TRANSPORTER For This Useful Post:
  12. #8
    Humansdorp
    Thanked: 127
    Unless you are into 4x4 stuff, going for a bigger (and heavier) tire is just a headache. Stick to the original size. The entire vehicle is "tuned" for that size. I am 58 years old. For the past 40 years I have played/modified tire sizes and gearbox ratios on many a vehicle, hopping of improving things. And yes, I know my maths. Mathematics was my preferred subject at school All this years I thought: surely I can do better than the engineers did with the standard model. Guess what - I failed.
    If you use the vehicle for what you said you are using it, keep the original size but look at different compounds.
    The tires are the heaviest rotating mass on a vehicle. Than comes the flywheel. Even small deviations in the mass of this components have some "after effect". And more often than not - it is not a good one
    I love Mozambique!
  13. The Following User Says Thank You to Gomario For This Useful Post:
  14. #9
    Nov 2006
    Thanked: 885
    I'd also stick to standard size.
    I've just paid R3300 a piece - Falken AT3wa, which is about the tyre for your use.
    Bostoe
