Re: T8 Ford Ranger - AT Tyre advice needed.
Originally Posted by
Oom Walter
From my extensive (obsessive if you ask my girlfriend) research, the biggest tyre a ranger can fit is 285/70/r17 but you will have uneven wear and technically apply greater stress to wheel bearings.
The optimal tyre (and most readily available) is either 265/65/r17 or 265/70/R17. There is very little benefit to going wider and will be more detrimental to your consumption.
At those sizes you will not be able to get BFs/coopers. You get both these in those sizes, they are just out of the price range mentioned.
You can try errolstyres. So far they have the best prices from all my extensive comparisons, (excluding the occasional deal that a retailer has in-store).
Radar Renegades, General Grabbers, Maxxis At980 and Yokahama Geolander AT/ G015 are all good options for that price range.
Cheaper options would be Dunlop AT5 / Kumho Road Venture AT52. The latter is available at Lombard tyres for +/- R2800 when I was there in June and they are high rated tyres for that price range.
Just note if you go from 265/65/R17 to 265/70/R17, your fuel consumption and odometer will be off by +/- 3.5%
Meaning yohr fuel consumption will be 3.5% better than the odometer figures, and you will be driving +/- 3.5kmh faster than indicated on your speedo (at 100kmh) The speedo will be more accurate. At 100km/h on the speedo you will be doing exaclty 100km/h on the GPS
Hope this helps!
Ford Ranger XLT Double Cab 4x4
Auto Union 1000 (DKW)
Pyga Stage Max
