Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
  1. #21
    Fourways Gardens
    Thanked: 854
    Default Re: Defender Puma 2.4 tdci power loss in 6th gear
    Quote Originally Posted by Bosvark Kzn View Post
    @Montari
    My one was performing without issues in town and dirt road driving, but once you hit the open road, doing like 120 km/h, it had the same symptoms as yours.
    I knew the loss of performance was due to it going into limp mode, but why?
    I only figured it out when I had someone drive it and I sat passenger with my diagnostic tool, keeping an eye on live data. I noticed the coolant temperature going up and then when it reached a certain temp, it would go into limp mode.
    While this was happening, the temp gauge did not move from its normal position. In fact, I’ve never seen the temp gauge gradually climb when there’s an overheating problem, it always goes from normal position all the way into the red in an instance. Not sure why it's like that, but it’s not very helpful. The way the temp gauge functions, basically just tells you “ok now it’s too late” it already overheated.
    Anyway, after that, I went through the coolant system and found the radiator to be dirty, grass seeds etc. Cleaned it properly and made sure I bled the coolant system properly and correctly (this is very important) and in my case it sorted the problem out.
    Good advice! If the cooling system is fine after checking, could be a bad map still. Maps cause temps to accelerate in high gears pushing pumas into limp.
    Series III 88"
    Scout Nomad
  2. The Following User Says Thank You to ClaudeG For This Useful Post:
  3. #22
    Dec 2013
    Klaas Voogds Robertson
    So I bled the radiator and cleaned it and the intercooler externally. I also had it on a diagnostics computer. The turbo boost and diesel delivery are not the problem. The temp is also good.
    The problem is that injector learning was not done. It also says overfueling is happening. We tried doing the injector learn but it bombed out about three times. He reckons the reconditioned injectors are bad. Lately the Landy smothers around 2000 rpm and black smoke comes out. Also at idle it revs up to 2000rpm on its own before returning to normal. Not happy with the garage that did the injectors in Worcester.
  4. #23
    Strand
    Thanked: 1459
    Quote Originally Posted by Montari View Post
    Where are you based?
  5. #24
    Aug 2024
    curno
    Good afternoon fellow Landy people. I need help on a frustrating issue. I recently had the following done to my 2011 Defender 110 (210000 kms): Water pump, EGR valve, reconditioned injectors, Clutch. All except the clutch was done by an independent Land Rover garage and the clutch by LR dealer. Symptoms before were heavy smoking on cold start for 3-5 min after which it ran well with no smoke. When the water pump started leaking it was taken to the garage to fix and then asked about the smoke. This lead to the EGR change but it didn't solve the issue so the garage send the injectors for testing and all failed. Reconditioned injectors in and now it starts and idles well and pulls like a train for 5km after which it loses all torque in 5th and 6 gear. Maximum 3000 rpm. Apparently no fault codes according to the garage.
    I had some good advice from the forum in the past, so what could it be?
    hi. i have the same problem and i'm really desperate. did you manage to solve the problem? thanks
  6. #25
    Dec 2013
    Quote Originally Posted by Benson View Post
    Hi Benson
    I am in Robertson.
  7. #26
    Dec 2013
    Quote Originally Posted by Lampa View Post
    Not yet, but am working towards it. Will let you know for sure Lampa.
  8. #27
    Aug 2024
    curno
    Cool Re: Defender Puma 2.4 tdci power loss in 6th gear
    Hi montari. I have already changed (all new):
    high pressure pump
    Injectors
    Rail with sensor
    Fuel level indicator (fuel tank one)
    Rpm sensor
    Camshaft position sensor
    Timing chain
    Maf and map sensor
    Fuel filter and support
    Fuel tank cleaned
    Stock ecu file
    Checked all cables
    Water temperature sensor
    New turbo
    Exhaust and intake checked
    Injection coding
    Pump calibration
    Intercooler cleaned
    Cooling system cleaned
  9. #28
    Dec 2013
    high pressure pump
    Injectors
    Rail with sensor
    Rpm sensor
    Timing chain
    Maf and map sensor
    Fuel tank cleaned
    Stock ecu file
    Checked all cables
    New turbo
    Injection coding
    Pump calibration
    Intercooler cleaned
    That is an extensive list! The only thing I don't see is the VCV. Mine revs up and down on idle which prohibits the injector learning (apparently) So I am planning on changing the VCV and try re-learning again.
  10. #29
    Strand
    Thanked: 1459
    Hi Benson
    I am in Robertson.
    If you are ever in Strand area. Please make a turn by the workshop.
    I would really like to have a look at the Puma....
