Results 1 to 5 of 5
    Thanked: 247
    Default Bushlapa water pump pulsating
    Hi Guys
    I am not sure if this has always been the case or if I am only noticing it now but this past weekend I noted my water pump pulsating a few times an hour just for a second or two. I assume there may a tiny leak in the system and its compensating for the drop in pressure?
    I dont see any water leaking either so may mention it when it goes in for service next time unless there is an easy fix?
    Oh this is on a newish Boabab 2
    Thanks guys.
    Jay
    2023 Toyota Fortuner
    2018 Toyota Hilux 2.8 GD6
    2016 Toyota Fortuner GD6 Auto
    2012 Jeep Grand Cherokee 3.0CRD
    2011 Jeep Cherokee
    2006 Jeep Grand Cherokee 3.0CRD-50mm EFS Lift, GDE Tune
    2009 Jeep Rubicon-50mm Coil Lift, Branches, Free Flow, K&N, MT`s
    2013 Suzuki Vitara-40mm lift
    2012 Suzuki Jimny-Fully Kitted.
    2007 Jeep Cherokee-Std
    Plett
    Thanked: 4811
    Default Re: Bushlapa water pump pulsating
    Definitely a small water leak somewhere
    2022 Defender D300HSE
    2024 LC Prado 250 VXR
    2019 FJ Cruiser
    BL Kewer 3188
    Fusion 17
    Brackenfell
    Thanked: 296
    Jay make sure your shower tap/selecter at the shower is in the off/close position.
    Uys Snyders
    Toyota Fortuner 2.4 4x4
    Bushlapa Vlooi B237
  4. The Following User Says Thank You to Uys Snyders For This Useful Post:
    Thanked: 247
    Thanks Chaps, will take a closer look in the morning....never thought of the shower at all.
    2011 Jeep Cherokee
    Thanked: 2196
    If you don't see any water droplets anywhere, the leak is in the system and can only be the diaphragm in the pump. It is fairly common that the tinest of dirt (like a piece of hair) gets stuck in the diaphragm, allowing a teensie amount of water to pass back through the diaphragm. It's an easy fix, (depending on the pump, but most are the same construction), loosen the four top screws to reveal the diaphragm and give this a gentle rub (even if you don't see anything), rinse and re-assemble.
  7. The Following 4 Users Say Thank You to Heinz Modricky For This Useful Post:
