If the pipe goes straight out the wall you are loosing a significant portion of the heating, always run the flue as far as possible inside the house.
Option 1, pipe inside to below ceiling 2 x 90 deg bends to take pipe through wall and then up
Option 2, pipe throught ceiling and roof - use double walled pipe with insulation for portion through ceiling and roof
I have both setups in the house
Anton Muller
Nothing upsets me more than vegetarians having pudding
2024 X5 M60i
2020 X3 M40i
Birkin SR20VET race car
Perhaps this will be of some help as well. So when they installed my fireplace I asked the installer about the distance to the wall and he assured me it was fine like this. Needless to say the first winter the wall started to crack and the tiles in the bathroom on the other side of the wall was crazy hot, that is actually how we realised the issue first.
So I started to look into it and this was indeed a fireplace that the heat does not only go to the front but in 360 degrees. So I had to keep the heat from the wall.
Now this might not be everyone's taste, but my best solution was:
I got high temperature insulation sheets they apparently used in kilns installed it with a space to hopefully create a cavity effect.
Visually was the problem so I finished it off with a corrugated sheet.
The part that surprised me most, was the change after that. The amount of heat that the corrugated sheet reflected, especially from the flue pipe, which I knew was a huge heat contributor, was crazy.
Sorry, this is the only photos I can find now
@JacoE
What you say is true, my Jetmaster is a double skinned 360 deg one and we also had to install a good way away from the wall. Mine is next to an outside double wall so no ill effects, but you can feel the wall is warm.
Stranger
GOF Club
BMW R1200R
Just went and got 4 bags now. R70 for 20 kg of broken bits. So a little less than a 9kg gas bottle, will do the job better and probably will last longer.
Winner winner chicken dinner.
https://youtu.be/Gn60NUcwisk
Stranger
GOF Club
BMW R1200R
I Must admit I like this, it looks very nice!! simple and I think very effective.
I need somebody to come and service my anthracite fireplace its old.
I might have to redo the pipes as they are single wall straight up. in the roof they did put insulation around the pipe, but outside of the roof, it single stainless steel pipe, so I need somebody with the required expertise to advise and fix.
Any suggestions around Pretoria?
Anton Muller
2024 X5 M60i
2020 X3 M40i
Pleasure, I find the broken bits works just as well in an open fire and far less messy than wood.
Stranger
GOF Club
BMW R1200R
I would not mind a nice fireplace, but, then, perhaps I want a dual purpose setup, one that doubles as an internal braai, AND a fireplace
Willem
Ford Ranger 2.2 XLS D/C
Toyotota Rav4 4 door - rooi gevaar
avoid steel - rusts.
go cast iron - just installed a big NoordFlam with stainless flue. double flue through roof.
expensive but efficient.
cc
Merit before Race - anything else IS Racism.
Stay Calm, engage low-ratio, keep buggering on - a Landy Man
Longevity isn't worth dying for,
I have the steel one.
Looks a bit like this https://www.lifespacesa.com/cdn/shop...2826&width=823
There's no rust on it.
I think the one I have is too small from the area because its doesnt make much of a difference. If I had to buy again , It will definitely buy a cast iron one.
