Results 21 to 40 of 53
  1. #21
    Apr 2014
    Thanked: 10745
    Default Re: Fireplace recommondations
    I have lived quite a few years in houses heated by wood. I checked all of the links. Not one of those are real heaters. Proper wood fired heater was invented in Sweden 17 hundred something if I remember right. They are made out of brick. Smoke goes up, then down and then out. This system was invented on king's orders as Sweden was running out of wood. Efficient. Chimney has a closure plate or two.
    Most probably too expensive.
    What ever type is installed the following has to be there:
    - Carbon monoxide detector or two
    - Smoke detector
    - Roof/ceiling penetrations are causing plenty of house fires. It must be done correctly
    - Fire extinguisher/s
    Detectors must be able to wake up sleeping persons. (Location issue)
    Heat pump is a better option
    Jouko
    2015 Grand Cherokee Summit Petrol
    2012 Smart
    Never drive a normal car
  2. #22
    Sep 2019
    Pretoria East
    Thanked: 6230
    But surely the closed ones too? If they smoulder? Smoke comes out the gaps?
    No, the modern ones are very well designed and insulated. As long as you as the operator doesn't stuff up it's surprisingly 'clean'.
    Aristotle wrote; ''Excellence is never an accident. It is always the result of high intention, sincere effort, and intelligent execution. It represents the wise choice of many alternatives. Choice, not chance, determines your destiny''
  3. #23
    Sep 2023
    Thanked: 119
    Quote Originally Posted by eagle eye View Post
    Open fire place makes a house stink
    And messed up your ceiling..........I'm thinking of a wall mounted gas fire place although wood is nice .......
  4. #24
    Oct 2020
    Thanked: 251
    Very happy with our combustion stove from Hydro Fire, more importantly the price of spares is not that exorbitant.
    Annually you need to replace fire bricks
    2017 Pajero Sport 2.4 d
    XCape
    Bicycles Plenty
    BMW GS 800 A
    2015 Pajero Sport 2.5 d (sold)
    2010 Pajero Sport 3.2 d (sold)
  5. The Following User Says Thank You to Woody62 For This Useful Post:
  6. #25
    May 2013
    Tzaneen
    Thanked: 280
    Don't feed the monkeys!
  7. #26
    Dec 2018
    Calitzdorp
    Thanked: 1414
    Quote Originally Posted by Kamakazi View Post
    Probably not expensive enough & way below budget at just over R5k all-in with flue pipe; ceiling plate & rotating cowl:
    https://lavafires.co.za/product/half...SAEEgKWovD_BwE
    These kaggels are just awesome & you could probably buy +/-20 000 pieces of wood with the spare change to last a couple of winters..
    Very uneconomical - Eat wood like you cant believe and most heat goes up the flue.
    Closed combustion is the way to go..
  8. The Following User Says Thank You to AfriqueDS For This Useful Post:
  9. #27
    Thanked: 1324
    Here is an article on an interesting scientific study of air quality in houses with fireplaces. I have not worked through the whole thing in detail, but essentially they find that fireplaces cause air pollution in homes that can be detrimental to health. Closed (internal combustion) fireplaces are better than conventional kaggels, but still not perfect. Their sampling size was small, but from following one of the authors' research in the past it often builds up to very interesting new research, valuable knowledge and technological developments.
    Tyrannosaurus R5 (sold) and now on my second second hand D4 British Tata.
  10. #28
    Mar 2014
    Secunda
    Thanked: 93
    Just a note, whichever fireplace you decide to go with, make sure your flue pipes are properly insulated where it goes through the roof. If a roof truss is to close, it may become a fire hazard.
    My parents newly built home in Negester went up in flames due to this omission, luckily the house was not signed over to them, and the builder had to repair / rebuild the roof.
    BTW, they installed the closed combustion fireplace they took from their old home. It is the dual fuel one, which can burn antracite and wood, had it for about 20 years, and works flawlessly. Cant remember the brand though.
    The antracite /wood stoves seems to be disappearing to emission regulations.
    I am also in the market for a closed combustion wood fired unit.
  11. The Following 2 Users Say Thank You to NvN For This Useful Post:
  12. #29
    Mar 2014
    Secunda
    Thanked: 93
    Quote Originally Posted by Woody62 View Post
    Which model do you have? I haven't heard of replacing the bricks annually.
    As mentioned in the post above, my parent has a closed combustion stove, only replaced the bricks once in 20 years, including the glass and sealing rope.
  13. #30
    Oct 2021
    Randfontein
    Thanked: 45
    Hi All.
    I have also been looking at fireplaces.
    Came across this one:
    https://www.vlakvarkkaggel.com/en/kaggels
    What I like about it is that it has tubes on the outside sucking in air from the bottom and dispensing hot air out on top again (no smoke in this part).
    The idea sounds good, just don't know enough about fireplaces to really say.
    The finish off on the product, looks a bit rudimentary, but does the "heat exchanger" method really work on this?
    Welgeluksalig is die man wat nie wandel in raad van goddelose en
    nie staan op die weg van sondaars en
    nie sit in die kring van spotters nie.
  14. #31
    Jan 2009
    Thanked: 333
    Quote Originally Posted by NvN View Post
    Same happened at my previous house about a year after installation. Luckily a water pipe melted due to the flames and killed the fire. So I ended with more water damage than fire damage.
    Old Wheeler
    Range Rover Big Body 5.0 V8 Supercharged
    Range Rover Evoque SD4
    Land Rover Defender 110 V8 Game viewer
    Land Rover Defender 100 PU V8
    Jaguar XJS V12
  15. The Following User Says Thank You to bvandyk For This Useful Post:
    NvN
  16. #32
    Jun 2012
    Thanked: 10490
    Quote Originally Posted by Barend. L. Jacobs View Post
    Hi All.
    A friend of our has a similar design (german made, cant remember the name), it is very effective
    Anton Muller
    Nothing upsets me more than vegetarians having pudding
    2024 X5 M60i
    2020 X3 M40i
    Birkin SR20VET race car
  17. #33
    Nov 2012
    Thanked: 125
    I had one of these put in.
    https://fireplacewarehouse.co.za/pro...on-invincible/
    Not from this company though, a local cape town company. Said hes been fitting them for years with no issues.
    Anyways, Lasted 4 years, grid broke twice, baffel plate cracked. They said I was over firing it but the rest of the innards were fine.
    I took it out and put in one of these
    https://homefires.co.za/product/dovr...v=edb5dc74af1c
    They changed the chimney to an insulated chimney whilst they were there. The Flue almost cost as much as the fireplace so just be aware of that.
    This is the 3rd year now and no wear and tear and I can say it is much more efficient.
    Dont be like me and pay twice, do it properly the first time round.
  18. The Following User Says Thank You to Mypro-D For This Useful Post:
  19. #34
    Feb 2013
    Da Bush - ZA
    Thanked: 6761
    I'm no expert, but isn't it much safer, not necessarily better, to have the flue go directly through the wall and then run up outside the house, rather than going up through the ceiling and roof space?
    Granted of course you have the fire place against a outer wall.
    Before you judge a person, first walk a mile in their shoes.
  20. #35
    Thanked: 1196
    I believe a (relative) large percentage of the generated heat is radiated from the flue?
  21. #36
    Cape Winelands
    Thanked: 895
    Quote Originally Posted by AfriqueDS View Post
    Yes, closed combustion is more economical on fuel & probably the preferred option for smaller spaces, flats, etc (less wood to carry upstairs, and-and..) Might also be better from safety perspective as you can close the door and leave it unattended unlike normal open kaggels that comes with some responsibility to close the screen before going to bed.
    The capital outlay is just a bit eyewatering if we talk R30k-R70k and it will take multiple decades to justify the fuel economy, but can understand paying for the convenience in some use cases.
    The Jetmaster will use more wood, but once it gets going you can chuck the largest stump that will fit in there to burn all day long.
    Comments that it smells or most heat goes up the flue are not so true as it is a stand alone unit that radiates heat from the exposed flue and steal unit itself over and above the additional benefit of the open fire. In large open areas of say 50-70sqm it actually produces more heat than closed combustion stoves.
    I'm probably a bit of a caveman that enjoy the ambience of starring into an open fire with the sound of crackling burning wood, so each to their own according to your preference & enjoy your choice of burners. We are privileged in this country to still be allowed to burn wood at our properties, whether it is for Kaggel or Braai.
    PS: Double insulated flue pipe is a must, dont skimp on this!
    2022 FX4 Ranger 2L Sit 4x4 Auto
    2004 Ranger 4000 V6 Auto (Farm Lorrie & Heavy loads)
    2011 CashCow 1.6 (Swambo)
  22. #37
    Middelburg
    Thanked: 753
    Quote Originally Posted by Jouko View Post
    Similar?
    https://on-fire.co.za/wp-content/upl...ser-Manual.pdf
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
  23. #38
    Jun 2013
    Thanked: 5857
    This thread prompted me to put mine on last night, using those pellets (I buy broken ones from the factory) my large living room was toasty within 30 mins and it was just a case of throwing a few more on every hour and a half to keep it going. I used around a coal scuttle full and these things don't smell at all. Mine definitely radiates the heat through the steel as you can feel this as you get close.
    When I got married my first flat was coal fired with a back boiler and radiators. Messy but hugely efficient. You banked your coal up in the morning and in the evening and you cleaned the tray when the fire was still on. Granted tiny space but it heated the whole flat and provided scalding hot water. The fire would burn continuously for months before we let it go out for a deep clean. It never really had that flame effect, more like a deep red lava look which is probably why I have never been into the big fires that South Africans love so much.
    This prompts me to say that you must ask yourself that question when you buy. Do you want bush tv in your lounge or do you want efficient at a reasonable price.
    Stranger
    GOF Club
    BMW R1200R
  24. #39
    Linden
    Thanked: 7469
    Quote Originally Posted by PieterOos View Post
    correct
  25. The Following User Says Thank You to Morne - Skip For This Useful Post:
  26. #40
    Feb 2013
    Da Bush - ZA
    Thanked: 6761
    Yes I know, that's why I said not necessarily better.
    But surely it would be a lot safer not having to deal with ceilings, roof trusses, roof insulation, possible water pipes and electric cables?
    Going even more off topic now, I cringe every time I see a fire place in a thatch roof house or built in braai in a lapa, it can probably be done "safely"to keep the insurance happy, but I can't really imagine myself sleeping soundly in such a house with a fire going through the night.
  27. The Following User Says Thank You to bigboy529 For This Useful Post:
