Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 66
  1. #41
    Feb 2012
    Sedgefield
    Thanked: 1417
    Default Re: Is cooling down a TD still a thing?
    Quote Originally Posted by PieterOos View Post
    How did she test it?
    Fuel consumption over 6 months using and then not using for another 6 months. Regular work trip daily. 1.5 litres /100 km more using ASS.
    2018 Hilux Dakar fully kitted.
    2016 Metalian Parthian
    2021 Suzuli Swift 1.2 GLX Swambo's shopping trolley.
  2. #42
    Mar 2018
    Bronkhorstspruit
    Thanked: 58
    Quote Originally Posted by pwgg View Post
    stop start must cause wear and tear. It puts strain on timing chains & starter motors and I also prefer to let the turbo cool down for a bit. Swambo had an X Trail that drove me crazy with its ASS. There again ASS is a good description for it 😃😃
    2015 Navara 4x4 LE auto
    Camil Suspension, Long range tank, Snorkel
    2004 Nissan Hardbody ZD30 4x4
    Camil suspension, Long range tank, Snorkel
  3. #43
    Jun 2012
    Thanked: 10220
    I did a desktop calc and came to the conclusion that there are savings on my commute but very little as a car uses very little fuel while idling. I seem to recall BMW quoting 0.3l/100km saving.
    I cannot see how it can use more fuel with ASS though, and certainly not 1.5L/100km so there must have been other variables not accounted for.
    More modern systems no longer uses the starter to restart the car so minimal added wear and tear and lot more seamless than older systems. I'm still not a fan of the system but have become neutral with the latest itteration.
    Anton Muller
    Nothing upsets me more than vegetarians having pudding
    2024 X5 M60i
    2020 X3 M40i
    Birkin SR20VET race car
  4. The Following User Says Thank You to mullerza For This Useful Post:
  5. #44
    Feb 2021
    JOHANESBURG
    Thanked: 7
    It's not about cooling down but rather, slowing down the turbo because if the engine is switched off, the turbo continues to spin at a high speed, but there is no oil feed to it. If I pull off the highway for a refreshment stop, I open a window or door until I hear the engine idle rough like a non-turbo diesel would, before switching off. I once went on a bus trip from Johannesburg to Lilongwe, Malawi and the driver did not once switch off the engine on the route. That is 3 rather slow border crossings one way, immigration and customs clearance for all the passengers, with the engine running. I thought at the time that this was a good standard operating procedure for the bus company because the cost of fuel does not compare to what it would cost to replace turbos damaged by drivers switching off.
  6. The Following User Says Thank You to Ramilayo For This Useful Post:
  7. #45
    Thanked: 3146
    Quote Originally Posted by Ramilayo View Post
    I think there are a number of things at play here, many (maybe most?) modern cars keep circulating oil to the turbo after engine shut down. With big diesels they certainly don't appreciate stop and start probably for more reason than just the turbo, and I suspect passenger comfort on a bus would also factor into it (aircon is only running if the engine is running).
    All I am saying is I don't think you can draw a direct correlation between a bus (not sure how long ago this was and how old the bus was) and a modern diesel car that is designed to take fairly unskilled (not professional) drivers into account.
    '13 Audi Q7 3.0 TDi quattro - stock standard
    '12 Audi Q5 3.0 TDi quattro, 255-65R17 AT tires - Sold
  8. #46
    Mar 2014
    Joburg
    Thanked: 164
    I drive a Amarok, BITDI, it's done 470K, never have cooled it down after driving, nothing has failed this far.
    I think technology has changed, better materials, better tolerance and so on.
  9. The Following User Says Thank You to Geiler Keiler For This Useful Post:
  10. #47
    Mar 2017
    Okahandja
    Thanked: 2305
    Also, a 2lt Amarok. 465k and never idled to cool turbos. No problems to date.
  11. #48
    Petoorstown
    Thanked: 157
    Well old habits dont die,im still idling mine down after each trip,town slow etc not so much or long driving hard or towing definately.
    2018 VW Amarok V6 TDi
    2017 Toyota Prado 3.0 D4D VX
  12. The Following User Says Thank You to The TRANSPORTER For This Useful Post:
  13. #49
    Mar 2014
    Joburg
    Thanked: 164
    Oh had a Ford 2.5TD that I bought from a friend with 480K on the clock, speedo had been broken for 3 years before I fixed it. He never let it cool down nor did I, never gave and problems.
  14. #50
    Thanked: 3057
    Quote Originally Posted by Geiler Keiler View Post
    On this one and the Amarok posts, we don't how he, you or erwin is driving. You might be driving civilised.
  15. #51
    Mar 2014
    Joburg
    Thanked: 164
    I don't drive like Miss Daisy, my Amarok has REVO software, does 120kw on the back wheels and 500Nm torque, I put foot but don't rev the crap out of it. Works hard as sell, I tow generators, 150KVA, all over SA and install them for a SA restaurant group.
  16. #52
    Kathu
    Thanked: 7064
    This.^^^^
    Designed so that in most cases oil from the oil lines gravity feeds the turbo bearings.
  17. The Following User Says Thank You to grips For This Useful Post:
  18. #53
    Jan 2020
    Thanked: 92
    i cant imagine the turbo taking too long to slow down with engine at idle, a few seconds maybe?
    could be wrong, im not a mechanic but watched far too many youtube videos with cars with big turbos
  19. #54
    Dec 2012
    Secunda
    Thanked: 622
    Ek doen dit nog steeds as ek ver gery / sleep het laat ek my bakkie vir n minute idol dan sit ek hom af
  20. #55
    Thanked: 3540
    Always....since turbos still spin at serious rpm's.
    It's not about slowing down the turbo.
    It's about cooling the turbo housing so the oil in the turbo doesn't cook, boil and carbon when the engine is switched off and circulation stops.
    The moment your car idles the turbo rpm will reach idle rpm in a second or two.
    High boost turbos usually have engine coolant circulating through it to help with cooling but many turbos are only cooled by the incoming air and the oil circulating through it.
    1993 3.0 V6 Pajero - SOLD : 2001 3.2 Di-D Pajero - SOLD
    2005 Touareg R5 2.5 TDi - SOLD : 2007 Pajero LWB 3.2 Di-D
    My YouTube channel
    Touareg Manuals Google Drive Folder : Pajero Manuals Google Drive Folder
    The clever ones are being outbred & overruled by the not so clever ones. Pair that with unchecked selfishness. We are heading for a fall!
  21. The Following 2 Users Say Thank You to MariusFourie For This Useful Post:
  22. #56
    Thanked: 220
    Interesting. Do you know which engines do this? I assume they would need an electrical oil pump to circulate oil after the engine has switched off.
    I know of electrical aux water pumps, but haven't seen an electrical oil pump.
    I would assume that hybrid vehicles would have an electrical oil pump.
  23. The Following User Says Thank You to veedub For This Useful Post:
  24. #57
    Kuils River
    Thanked: 620
    Quote Originally Posted by Steve45 View Post
    Pielstick engines
    Is this a real engine
    2013 Lexus RX350 EX AWD - 12.8 l/100km currently 256,000km (best tank to tank 10.9 l/100)
    Alonso | Verstappen | Albon | Norris | LeClerc
    EX:
    2013 Ford Ranger 2.2 XLS D/C - 11.8 l/100km over 243,000km
    2007 Hilux 3.0 D-4D D/C - 11.9 l/100km over 342,000km
    2001 Hilux 2.7 Raider D/C - 15.1 l/100km over 321,000km
  25. #58
    Aug 2017
    Nylstroom
    Thanked: 2790
    As I'm new to the TD market, I'm trying to treat this thing as well as I can. When starting first thing for the day, I usually let it idle for a bit before I take off. I also drive like a grandpa for the most part, don't rev high (a cold diesel sounds "crass" to me and it feels like I'm breaking it), and when I'm done I stop at the gate, open the gate, slowly drive in, into the garage, etc. This also takes a few seconds and it's at idling speed, no throttle even used.
    Anything I should specifically look out for?
  26. The Following 2 Users Say Thank You to Toxxyc For This Useful Post:
  27. #59
    Aug 2019
    Thanked: 1877
    Quote Originally Posted by CraigJ View Post
    The French knows how to name an engine
  28. #60
    Mar 2014
    Joburg
    Thanked: 164
    How many cases have there been recently of things going wrong when not cooling down a TD and what exactly went wrong?
