Results 1 to 20 of 22
    Sep 2020
    Thanked: 53
    Default 215/80/R15 - Will they fit?
    Hi All, as per the title, will these tyres fit on a stock gen4 with no lift or spacers?
    Has anyone fitted this size on their Jimny (Gen4)?
    I do not mind trimming some plastic here and there to get rid of rubbing, and i'm also not against using spacers. I just am not too keen on a lift kit.
    Hard times create strong men, strong men create good times, good times create weak men, and weak men create hard times.
    Oct 2012
    Thanked: 284
    Default Re: 215/80/R15 - Will they fit?
    Yes they will fit with no mods required on a gen4 jimny.
  3. The Following User Says Thank You to Fearl3SS For This Useful Post:
    Thanked: 966
    With space to spare.
    235/75/15 BF AT's fit without a lift.
  5. The Following User Says Thank You to Andre N For This Useful Post:
    Sep 2020
    Thanked: 53
    Quote Originally Posted by Andre N View Post
    235/80/15 BF AT's fit without a lift.
    Wow, this is a huge jump from the stock 195/80/R15! So a 10% bigger tyre fits without modifications, and is able to be driven offroad without contacting the body or suspension bits even at full articulation?! That's almost hard to believe o.o
    Jan 2007
    Thanked: 491
    Quote Originally Posted by BankRun View Post
    That looks like a typo. 215/80R15 is the biggest you can fit without trimming.
    Vic
    Thanked: 966
    Not a Typo.
    I also know of a couple of Guys running 235/75/15 Grabbers.
    Did Piesangkloof last weekend. No rubbing. Standard Suspension, nothing trimmed.
  9. The Following User Says Thank You to Andre N For This Useful Post:
  10. #7
    Sep 2020
    Thanked: 53
    Not a Typo.
    I also know of a couple of Guys running 235/85/15 Grabbers.
    This is remarkable
  11. #8
    Jan 2022
    Westville
    Thanked: 127
    Not a Typo.
    They look good! Were you alone in the vehicle or was it fully loaded with passengers as the extra weight may cause some rubbing?
  12. #9
    Jan 2007
    Thanked: 491
    Not a Typo.
    Firstly, there is no such size. The size you are thinking of is 235/75R15.
    I speak from experience, they rub. Not much but they rub.
    Vic
  13. #10
    Feb 2024
    Colima
    Thanked: 8
    I'm running 225/75r15 with no issues. You should be fine.
    2024 Suzuki Jimny (3 door)
    2014 VW Amarok DC 2lt 6speed manual
    1973 VW Safari
  14. The Following User Says Thank You to Gustav Nelson For This Useful Post:
  15. #11
    Thanked: 966
    Quote Originally Posted by Japanese Jimny View Post
    Me, The Mrs, 2 X Teenagers, Coolbag, Couple chairs and recovery kit on the Roof. Pretty much as much load as my Jimny will ever see.
    Ok, I see now what's going on, Corrected, Don't know where I got the 80 and 85 from.
    Which 235's did you run, and where did they rub ?
  16. #12
    Thanked: 966
  17. #13
    Jun 2018
    White River
    Thanked: 3019
    I personally had Grabber X3 235/75R15's and with a Des Sol 50mm lift, I rubbed on full lock on my mudflaps and hooked on my front bumper under compression. Quickly rectified with removing mudflaps and replacement bumper. I also had spacers fitted.
    Mike
  18. #14
    Thanked: 966
    Quote Originally Posted by AfricainHD View Post
    Did you experience the Rubbing with or without the Spacers fitted ?
    Will cross axle my Jimny on a ramp later today and see what the clearance looks like.
  19. The Following User Says Thank You to Andre N For This Useful Post:
  20. #15
    Jun 2018
    White River
    Thanked: 3019
    With spacers, all rubbing was when I had a fair amount of steering angle on. So on trails and full lock when reversing out of a parking etc.
    Mike
  21. #16
    Thanked: 966
    Ok, So with Spacers fitted will explain your Rubbing. Your Scrub radius were/are pushed out by the thickness of your spacers.
    Assuming you have the run of the mill 32mm spacers fitted your Front wheel will move forward and backwards a fair bit as you turn your wheels.
  22. The Following User Says Thank You to Andre N For This Useful Post:
  23. #17
    Dec 2007
    Thanked: 19
    What tires are available in 215/80/r15?
  24. #18
    Oct 2012
    Thanked: 284
    Quote Originally Posted by Genis View Post
    Take a look on errolstyres.co.za there you will have an idea what is available and estimated costs
  25. The Following User Says Thank You to Fearl3SS For This Useful Post:
  26. #19
    Jan 2007
    Thanked: 491
    My favourites are the Firestone Destinations
    Vic
  27. The Following User Says Thank You to saxj For This Useful Post:
  28. #20
    Dec 2007
    Thanked: 19
    Thx guys. What tyres are you running SAXJ?
