Results 1 to 5 of 5
Thread: Fault 07
    Thanked: 5668
    Default Fault 07
    Hi Guys
    This morning, we hear a beep when the pool kicked on via the timer. I go to look at the inverter and see nothing wrong. We decided to try and repeat the event, so I watched as Swambo turned off the pool and then turned on again. For a second only, I saw Fault 07 flash on the screen and then all back to normal again.
    This is something new and has not happened before.
    Fault 07 in my manual states
    overload by 110 %
    Could my capacitor on the pool pump be seeing it's last ? 8 years old
    What could be the cause of this new problem ?
    Stranger
    GOF Club
    BMW R1200R
    Thanked: 5668
    Default Re: Fault 07
    No opinions ?
    Could it be that because it is so cold that the pump is asking for that little extra power. I know they can pull 6-7 ? times more for a second or two to get the pump spinning.
    My inverter is a 5.5 kw
    Stranger
    GOF Club
    BMW R1200R
    Gauteng
    Thanked: 2394
    No opinions ?
    Are you sure it's a fault and not just a warning. Warnings go away but faults can remain for you to see before it clears.
    But in any case you got answers on the other forum.
  4. The Following User Says Thank You to ekkekan For This Useful Post:
    Thanked: 5668
    Yoh
    I have a stalker
    Stranger
    GOF Club
    BMW R1200R
    Gauteng
    Thanked: 2394
    Yoh
    I have a stalker
    Better cover your tracks 😜😜
  7. The Following User Says Thank You to ekkekan For This Useful Post:
