Results 1 to 13 of 13
    Vredekloof
    Thanked: 66
    Default Mitsubishi l200 gearbox woes
    Good morning
    I hope some of you clever oaks can give me some advice.
    My 2007 4x4 2.5did started to slip out of first gear about a week ago. Feels like it only engages 5mm( not far enough in gear)
    So I haven't really used my first gear the last week.
    It gets worse......this morning it started to engage difficult in 3rd gear and gets kind of stuck in reverse.
    Also with the bakkie in neutral releasing clutch pedal there is load on the rear driveshaft which was not there before.
    Clutch is fine, all gear oil levels are fine.
    I am planning on dropping the box tonight and open tomorrow.
    My question is..... Am I missing something I can look at before dropping gearbox.
    Also what to look out for once I open the box
    Thanked: 4882
    Default Re: Mitsubishi l200 gearbox woes
    Any chance there's something interfering with the gear lever? Or broken engine/gearbox mounts causing movement that shouldn't be there?
    May 2016
    Thanked: 9636
    It sounds like a selector problem, to me.
    2003 Mitsubishi Pajero 3.2 Di-d LWB
    Vredekloof
    Thanked: 66
    I have taken the gear levers out to see if there is any kind of obstruction, but all is fine
    Vredekloof
    Thanked: 66
    Hopefully it is just a sleeve or bearing that's worn and having play on it
    Vredekloof
    Thanked: 66
    I have also checked all mountings on gearbox and engine, they're all fine
    Robertson/ Larissa, Greece
    Thanked: 10130
    Maybe this can help.
    My son had a similar problem with his Colt bakkie about a month ago. The culprit was a broken spring on a selector detent ball. You can take it out from inside the cab. Maybe a have look. You may be lucky!
    Vredekloof
    Thanked: 66
    Thank you Francois, I will have a look at that, but I don think there is enough space to look at that from inside the cab. So I will have to remove the box and take it from there. I think I will check all the bearings and change the oil seals as well while I've got it down
    Vredekloof
    Thanked: 66
    I can only hope that the problem is so small
    Vredekloof
    Thanked: 66
    So I've stripped down the gearbox and everything inside is looking good except the out shaft bearing that's nackered
    Vredekloof
    Thanked: 66
    Does anybody perhaps have one lying around or know where I can get one on a Sunday
    Vredekloof
    Thanked: 66
    Apologies, it is the input shaft bearing
    Vredekloof
    Thanked: 66
    Latest update on the gearbox.
    So after replacing the bearing, which is the one just behind 1st gear and not input shaft.
    Assembled all completely. Just before installing back in my bakkie, I tested everything to be sure.............1st gear did not feel right, so after a lot of I stripped everything apart again and found that the sleeve on the 1st gear syncro is broken . Now I've decided to take the complete stripped box to Mayfair in Brackenfell.
    At least the lobour charge will be considerably less lol
