Results 1 to 17 of 17
    May 2013
    Jeffreys Bay
    Thanked: 11
    Default 2.2 Ranger Starting and limp mode problem
    Hi everyone. I'm gonna try to be as specific as I can be.
    I fitted a secondhand motor to my ranger as my original overheated and an machanic stripped my original motor to beyond repair.
    So I fitted the new motor and she was running fine for a week or so.
    She then started to go in limp mode while driving. An easy reset (off/on) switch did the trick.
    I noticed a bit of power loss and replaced the turbo with one from turbo clinic. Power was back but limp mode while driving continued.
    The ranger also started to struggle to start ( hot or cold).
    I changed the injectors and had the injectors programmed. Bakkie started fine for a day or two and then same thing started happening again... But this time the bakkie would go into limp mode and after a quick reset she will stall leaving me on the side of the road. At first after waiting a while she will start but die again immediately. Later on she would start and I could continue. It became so bad that I had to carry an extra battery with me as all the struggling will drain my battery.
    We set the crank sensor and she will start... A day later...same problem.
    I took off the fuel tank, made sure it was clean, checked the pump, fitted it again and still the problem is there.
    This morning I got stuck again and immediately organised a new crank shaft sensor. While doing the sensor we cleaned the cam sensor as well.
    Everything plugged back in, turned the key and the bakkie started.
    Went for about a 3km drive, stopped at a client's place and when I wanted to leave.... Bakkie wouldn't start....
    Got it started with a bit of quick start and drove her home.
    Now I am at my wit's end.... I have know idea what further can be wrong.
    I someone have any ideas ... Please help!!!
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    Suzuki GSXR1100 - net vir die teer.... - Sold
    BB - Restored
    Previous:
    Toyota 3.0KZ-TE SC (you will be missed)
    Pajero 3.5 V6 (Die dors ene)
    Thanked: 1681
    Default Re: 2.2 Ranger Starting and limp mode problem
    Do you have any error codes? Might help diagnose the problem.
    Padraic Berry
    May 2013
    Jeffreys Bay
    Thanked: 11
    I have one of those Kenwei obd testers. Doesn't pick up any fault codes.
    Change the fuel filter again this morning..
    Engine just swings...
    Cleaned all sensors and sensor connectors.
    Engine just swings.
    Checked for fuel bypass on injectors but there is none. Only little splatter when engine is revved.
    I started the engine again with quick start, bled all the injectors and the engine started up.
    Took her for test ride and bakkie went into limp mode.
    Stopped back at the garage, switched the engine off and tried to start again.
    Engine just swings again.
    Started up again with quick start and bled injectors again. Engine started again. Again a test drive and same thing happens.
    Beginning to think that the fuel system might be sucking air in somewhere or something.
    Just no idea where it could be.
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
    Ballito
    Thanked: 11169
    Have a good look at the earth strap.
    Jaco Nell
    Dec 2015
    Thanked: 237
    Also check the fuel rail pressure sensor. Click image for larger version.
    Feb 2013
    CT
    Thanked: 253
    Take it to a reputable performance workshop for a diagnostic scan..
    VW TDI 205kw 6 speed + 2022 Suzuki Swift GLX
    Dries de Kock
    ZS1SPY
    May 2013
    Jeffreys Bay
    Thanked: 11
    Quote Originally Posted by jaconell View Post
    Which earth strap are you referring to?
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
    May 2013
    Jeffreys Bay
    Thanked: 11
    Quote Originally Posted by ditchdoctor911 View Post
    I dit take it out to make sure it's clean. There was a whitish liquid on the thread and on the inside of the rail.
    Cleaned it off, but have no idea what that could be.
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
    May 2013
    Jeffreys Bay
    Thanked: 11
    Quote Originally Posted by kadafi View Post
    Will have to do that again I think. Last time when they programmed my injectors it showed a fault with my crank sensor. That was the reason I replaced the sensor.
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
    Nov 2006
    Thanked: 923
    Your problems sound exactly like the behavior of a faulty relay on the ignition supply to the electronic control module.
    Iow a faulty relay/ecm.
    If my technical terms are correct.
    Have it checked out.
    Ballito
    Thanked: 11169
    Quote Originally Posted by JJjbay View Post
    I will see if I can find a Ranger and take a pic for you - but when looking at the engine bay there is a earth strap about 50/60 cm long on the far right. It earths near the top of the engine bay. I had Rangers in my business a couple of years ago and these straps would cause problems with 2 of them going into limp mode quite often. Once replaced all was good.
    Jaco Nell
  12. The Following User Says Thank You to jaconell For This Useful Post:
    May 2013
    Jeffreys Bay
    Thanked: 11
    Quote Originally Posted by Damdan View Post
    Will this be one of the relays in the fusebox in the engine bay?
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
    May 2013
    Jeffreys Bay
    Thanked: 11
    Will really appreciate it. I don't recall an earth strap. I'm obviously aware of the main earth from the battery.
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
  15. #14
    May 2013
    Jeffreys Bay
    Thanked: 11
    I fitted another earth wire this morning, just to make sure it's not a earthing problem.
    Now I'm getting this.
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
  16. #15
    May 2013
    Jeffreys Bay
    Thanked: 11
    Ok...
    Changed the injectors....
    Changed the crank sensor....
    Drained the tank and check in tank pump.
    Replaced diesel filter....again...
    Changed the fuel rail and fuel rail sensor...
    Changed the solonoid and sensor in high pressure pump...
    Swopped the Maf and Cam sensors with my other 2.2.
    Swopped all relays in fusebox with my other 2.2...
    Double checked the injectors for any bypass...
    Made 100% sure there are no fuel leaks...
    Bakkie is still not starting on its own while cranking.
    When put on diagnostics it only brings up the fuel pressure up to half the desired kPa.
    When the bakkie is started with quick start spray and running the fuel pressure is perfect in line within the desired specs...
    When bakkie is switched of the fuel pressure disappear and the bakkie won't start again unless using quick start.
    While driving the bakkie will go in limp mode specially around 3rd or 4th gear while boosting. If I try to reset while driving the bakkie will run out of fuel within about a kilometer. If I continue driving in limp mode I only have about 2200rpm to use but I can continue without the bakkie cutting out.
    4 different diagnostic machines later and still can't find the problem..... Just keeps on saying my injector fuel pressure low.
    I've done everything I could think of....
    Any tips or advise please
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
  17. #16
    May 2013
    Jeffreys Bay
    Thanked: 11
    Unhappy Re: 2.2 Ranger Starting and limp mode problem
    Replaced the complete fuel supply pipe from the lifter pump and still no start
    GET IN, SIT DOWN
    SHUT UP, & HANG ON
    BB - Restored
    Previous:
  18. #17
    May 2013
    Kloof KZN
    Thanked: 168
    Was this problem ever resolved ?
    Ford Ranger Supercab 3.2 auto 4 x 4.. Jurgens Penta
    Stofpad sump and gearbox guard,ironman snorkel
    Mazda MX5 _ sold after 5 happy years
    Polo 2.0 wifes car sold --- now Chery Tiggo Pro SE
    Retired
