Results 1 to 2 of 2
    Fish Hoek, WC
    Thanked: 475
    Default Solved: High idle - 2016 BiTdi
    Edit 20 July: I tightened the loose battery terminals and all is well.
    Back to normal - I believe the alternator was struggling to charge (or something) and the idle was adjusting to compensate.
    Morning all
    Last few weeks I've noticed the Amarok idles at 900rpm in general, but after a drive (when warmed up) it hangs around 1000/1100 rpm.
    Is this normal? It's been a while since my last diesel.
    I'm not wise, I just talk slow.
    3x4x4s
    Jan 2014
    Northern KZN
    Thanked: 834
    Default Re: High idle - 2016 BiTdi
    It depends on a few things, one of which where it is in the regen cycle. Since I removed the dpf on my V6 it idles much more consistent. It only varies when the aircon is activated. When cold it actually idles faster until operating temp is reached, then slows down to 900rpm.
    Groetnis
    Koos
    2013 Amarok 4 motion manual DC (The workhorse)
    2020 V6 Amarok (The underrated and underestimated Plaas Passat)
