Cracked Navara chassis
Results 1 to 20 of 23
    Pretoria/Beauvais France
    Default Cracked Navara chassis
    I am posting this on behalf of Karl dempsey Ireland.
    He cracked his Navara chassis while towing .(To my understanding not a heavy load)
    He wants to know.
    Any know problems with the Navara chassis ?
    If any one else have had the same problem ?
    Is this the reason Nissan changed decreased the tow ball weight on later models ?
    Basically he is looking for as much info as possible.
    I did attached the pictured he e-mailed me this afternoon . I have never seen a chassis snap like this
    Any help appreciated.
    Hillcrest, Malaysia
    Thanked: 5979
    Default Scary
    Three things come to mind, none of whic really answers your question.
    1/. There was a manufacturing fault on that vehicle
    2/. It may be a known problem
    3/. Unfortunately I think this is the most likely. Your friend may have underestimated the load or the conditions.
    No help. but scary non the less
    Oct 2006
    CAPE TOWN ,SOUTH AFRICA
    Thanked: 502
    Could have been in an accident previously. Or something else that hasnt been stated .They can weld that strong today. If factory fault , nows the time for Nissan to react to gain some trust from the public.
    ORA
    Ian
    dublin
    hi, this is karl dempsey ireland, the pick up has never been in an accident as i have had from new and ive never crashed it,
    but i have fitted firestone air bag on the leaf springs.
    as jgoosen said any help.info would be much appreciated
    thanks karl
    Thanked: 983
    Karl, do you have a standard towbar? Ball weight of trailer towed? weight of trailer towed? load on vehicle ? Hit a hole when towed? if you stayed in the manufacturers spec, Nissan would fix it. IF not, well then......
    [email protected]
    +27824453301
    dublin
    hi engel, yes i was within all the weights for the year i bought 2006, but the vertical force on ball was dropped on 07 on.from 120kg to 92kg. why was i not inform by nissan that these had changed and also i have looked at 07 model and at this point on the chassis it has been stiffened also leaf springs are stronger
    karl
    dublin
    i have had it on a weight bridge to confirm this.
    im off for 2 hours to go to underwater hockey, i belive you south africans are very good at it?
    back soon
    karl
    Thanked: 983
    the ball weight from 120 to 92 is not a train smash. Go see them and ask for a explanation. I see it has cracked after the blade. Nothing to fix.
    [email protected]
    +27824453301
    Jan 2009
    Aston Manor
    Enlarging the photo (unfortunately not very clear) seems to indicate that the bottom of the saddle side weld may have been the initiation point. I suggest an inspection of the weld itself - it may just indicate if an undercut, flash or even poor penetration could be at fault.
    dublin
    engel and botswana, do you both belive that this could be fixed by means of WELDING?
    Sep 2008
    Sunningdale
    Looks to me like a stress fracture. It does seem to lead to the weld like Botswana said, but judging by the way its bent tells me its started at the top. Do you do alot of towing?
    I dont see that as a major train smash, bend it back into place, weld it up and stiffen with some plate or channel.
    Nigel
    Thanked: 2078
    Quote Originally Posted by karl dempsey ireland View Post
    Yes that is repairable.
    Just some things to bear in mind.
    The plate you use to patch must have no sharp corners. That is where the next crack will run from.
    I would make a long plate that will start way ahead of that crack and it will run untill after that towbar.
    Put holes into the plate so that you can have weld from the center of the plate, straight onto the chassis.
    I would also use a minimum of 8mm plate. Maybe even 10mm. You might want to mount something onto that chassis at some stage. Like recovery hooks.
    Use somebody that can pilot a MIG welder properly.
    Good luck
    PS. I agree with Andre. Both sides need to be done.
    Uniglide
    +27 zero eight 2 four 95 9252
    Thanked: 59
    Is it just me, or is that an old crack. Looking at the edges, it's not nice and shiny like a new crack but brown like it's rusted. Maybe the last towed load was just the last straw on the camil's back.
    Yes, it can be fixed (Henris's method) but it will always be in the back of your mind when ever you hitch something up. Also, do both sides while your at it. You never know when the other side is going to do the same - see another thing that's going to be in the back of your mind when ever your towing again.
    dublin
    the other side is cracked aswell
    Murcia
    I am unsure if I would be spending time considering repairing it! I would be beating a path to the Nissan dealership with a cracked chassis on a vehicle less than three years old!
    This repair idea is moving away from the original threads 'has anyone else experienced this?'. It has already come to light that the later vehicles have been downrated/reinforced, if this is indeed the case then this appears to be a design/manufacturing fault assuming no overloading/misuse ect.
    The owner should not be concerned (at this particular moment with a repair), just get up to Nissan with a hefty bat in the shape of a good lawyer.
    regards
    Dave
    Remember as an individual you are unique.......................just like everyone else
    Landcruiser HDJ80, UK spec (triple lockers ect)
    Kirstenhof, Cape Town
    Hi. Not with Nissan, but I remembered a similar story from way back - about 2002.
    see http://www.news24.com/News24/South_A...535437,00.html
    also www.my4x4.co.za.
    In this case it was an Isuzu. After much testing and (apparently) some collusion between SABS and GM South Africa (missing reports, etc...) the complainant won the case.
    I agree with Dave, it's going back to the manufacturer.
    DV8 - I'D RATHER BE OFFROAD
    2009 Disco 3 TDV6 HSE- stock (for now, but don't tell SWAMBO!)
    1996 Disco V8i \ K&N Hyperformance Filter \ Unichip \ SAC Freeflow exhaust system \ Ironman Suspension
    in a previous life, 1973 2.25l Series III SWB Landy - "Striptease" and 1969 2.25l Series IIA SWB Landy - "Lazarus". ITC Parabolic suspension \ Monroe Gas Magnum 4x4 shocks \ SAC freeflow exhaust system.
    dublin
    There is a lawyer on the case as we speak, hopefully it does not take years to sort out!
    dublin
    well nissan have finally come back and said its not their problem, so here comes a long fight
    dublin
    oh, i can now sell my navara! anyone interested in a 06, 55000 km, yes thats all, grey, leather, elec seats, roof, a/c, sat nav....... top spec in ireland......oh and a snapped chassis......
    Gautengeleng
    Thanked: 42
    Default Re: Cracked Navara chassis
    Know this is old but what happened in the end.
    Corne
  1. Replies: 19
    Last Post: 2010/03/02, 08:21 PM
  2. Nissan Navara bent Chassis
    By JGoosen in forum Nissan
    Last Post: 2009/03/05, 04:50 PM
  3. Cracked Chassis
    By Willies in forum Vehicle & Technical Chat - General
    Last Post: 2008/09/20, 06:29 PM
  4. Welding on Chassis
    By Andre N in forum General 4x4 Discussion
    Last Post: 2008/09/10, 09:02 AM
  5. Navara Safety
    By SimonB in forum Nissan
    Last Post: 2008/03/10, 04:20 PM
