Results 1 to 10 of 10
    Jan 2010
    Potchefstroom
    Thanked: 205
    Default Need a mounting solution for my 276c
    I have two 276c units, historically used with the sand bag type dash mount. These are a bit worse for wear after years in the sun and also the rattling against the windscreen is becoming an issue. Had a search for RAM mounts but would love some pointers or advice as to where I should throw my money.
    PS, units get moved across several vehicles so something portable is required
    PPS; Apologies for spelling error in thread title
    Oct 2012
    Ramsgate
    Thanked: 147
    Default Re: Need a mounting solution for my 276c
    Quote Originally Posted by Reece View Post
    All depends on how you want to attach it to the dash/windscreen.
    This link has all
    https://www.rammount.co.za/catalogue...e-RAM-HOL-GA7U
    I use the twist lock suction cup (don't want to drill into my dashboard). Some olive oil around the edge of the suction cup and it stays there for a long bit. Else you can drill into your dash and it will never fall off. I use a ram mount for my phone, and used one for my old Montana 650.
    The guys from Ram mount SA are very helpful if you have more specific model questions
  3. The Following 2 Users Say Thank You to Gothan For This Useful Post:
    Oct 2012
    Ramsgate
    Thanked: 147
    Default Re: Need a solution for my 276c on teh dash..
    Oh and the nice thing of ram mounts, it's modular. So you can have different base mounts in different vehicle. You might have a suction cup in one and a drilled in dash mount in the other. You just unscrew the double socket arm from one ball joint and attach it to the ball joint in the other vehicle
  5. The Following User Says Thank You to Gothan For This Useful Post:
  6. #4
    Pretoria - Garsfontein
    Thanked: 44
    I bought a "RAM-B-166-347U" (includes the mounting plate, arm and suction cup) for my 276cx through Luke here on the forum (https://www.4x4community.co.za/forum...-lukestrugnell ) - excellent service! From placing the order to having it in my sweaty paws, was less than 3 days. That thing sticks to the windscreen like you-know-what, through speed bumps, corrugations, you name it!
  7. The Following User Says Thank You to Gustav E For This Useful Post:
  8. #5
    Jan 2010
    Potchefstroom
    Thanked: 205
    Thanks for the lead!
  9. #6
    Oct 2014
    Thanked: 146
    Unfortunately most of the Garmin car mounts are inadequate. I've tried all the usual tricks (hot water, gorilla tape, vaseline etc), they do improve things but don't solve the problem. I've resorted to using a RAM Mount base & modifying the device clip to attach to the RAM base. See attached pix.
Name:	01 Garmin vs Ram Base.jpg
ID:	719742   Click image for larger version.
Name:	02 Garmin vs Ram Base Suction Cup.jpg
ID:	719743   Click image for larger version.
Name:	03 Garmin vs Modified 600 276cx Clip Front.jpg
ID:	719744   Click image for larger version.
Name:	04 Garmin vs Modified 600 276cx Clip Back.jpg
ID:	719745   Click image for larger version.
Name:	05 Garmin vs Modified Ram 600 276cx Clip.jpg
ID:	719746   Click image for larger version.
Name:	06 Ram base with Modified Tread Clip.jpg
  10. The Following User Says Thank You to StorminH For This Useful Post:
  11. #7
    Oct 2012
    Thanked: 1502
    Quote Originally Posted by StorminH View Post
    I had a 276 and now a 276cx and find that, unsupported, the suction cup on the RAM mount usually pops once or twice, particularly on hot days it seems. My solution, let it rest on the dash protector, no more issues.
  12. #8
    Jul 2009
    Langebaan
    Thanked: 151
    Suction cups will drive you crazy
    Find a suitable spot and mount a Ram Ball permanently. No more hassles
    https://www.instagram.com/reel/Co7ei...hrYmJjNmduZQ==
  13. #9
    Sep 2024
    Dubai
    Mounting a GPS in my vehicles has always been a PITA, so to get rid of the issue and to make sure that I have something that can be used for additional items, I devised a navigation bar which I use all the time now. The photos are self explanatory I think.
Name:	Nav Bar 2.jpg
Name:	Nav Bar 3.jpg
Name:	Nav Bar 1.jpg
  14. The Following User Says Thank You to Desert Dog For This Useful Post:
  15. #10
    Garsfontein
    Thanked: 7199
    I just 3D printed RAM mounts a few weeks ago. I can print some for you for free. Filament is dirt cheap.
    Works a treat.
    Ian de Villiers
    Patrol 4.5 GRX
    Sole local member of the GFYS club
    Jurgens XT65 2x0 with Super Select Zero
    ORRA: H80
