Originally Posted by
JJP
Are parts easily to come by and are they expensive?
No, they can mostly be bought at MB and cost money. to know weather they are expensive you would have to be comparing to something else.
JJP
Can one get a hold of body parts like lights, trim, mirrors etc.
Yes, MB could help you there as well.
JJP
Would any proper service centre be able to redo/service prop shaft, diff's and basically replace all parts on engine like pumps, injectors and piping.
Yes.
JJP
Service/rec-con engine.
I am busy doing an OM617 engine, which is what you have in the G... the cost of the parts, like new sleeves, pistons, big ends, main, small ends, full gasket set, seal set, 2 oil changes and antifreeze as well as ATF Top up is just on 7k. This includes having the engineering done on the block, fitting the new sleeves and machining the bore to match the new pistons. I have done the head already and this was R2k, which included new injector seals and oversize precombustion chamber spacers. The head gasket is OEM from MB, as is all the seals and spacers. The pistons and sleeves, and bearings are from Alert engine parts.
JJP
All your inputs will be appreciated alot as this will help me to decide whether I should or not.
If I was you, I would start with a G that has less work, the costs pile up so quick, before you know it, you have totally over capitalised. An idea is also to have a look on the G Wagon Club website, they will be able to direct you as well. The vehicle is a good one, is veru capable, in any terrain and the beauty of it is that the motor will run on almost anything you care to chuck in the tank....
Have now covered 270 000Km on veg oil.
Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
Rand for Rand gets 33Km/L
