Results 1 to 6 of 6
    Thanked: 579
    Default Garage door opener - Centurion SDO4 Smart any good?
    Is the Centurion garage door opener SDO4 Smart any good ?
    Due to lack of availability of spare parts for my current garage door opener I am investigating replacing them with Centurion SDO4 openers, I currently have digidoor openers but the supplier is struggling with spare parts (pc boards specifically) together with SWAMBO recovering from a shoulder op I need the doors working.
    Neil
    May 2010
    Bergbron, Roodepoort
    Thanked: 359
    Default Re: Garage door opener - Centurion SDO4 Smart any good?
    Very good motor. at 1200N the strongest on the market as well. Centurion support is also very good.
    Only fact that I have an issue with is that it works off batteries and not off 220V supply like the other garage door motors, so even if you have an inverter/solar system installed at your house, the SDO4 has to have batteries installed. All the other garage door motors can work without batteries.
  3. The Following User Says Thank You to Flagster For This Useful Post:
    Jan 2022
    Kempton park
    Thanked: 667
    I use the DTS openers and gate motors. 24 months warranty. I never get comebacks. Installed 100s. Service backup is tops.
    DTS is also high access so it runs on mains and only uses battery as a backup in power failure
  5. The Following User Says Thank You to Andrew V9X For This Useful Post:
    Feb 2017
    Thanked: 100
    We have two - they run very silent. I can confirm the previous comments about the strength and having to run from batteries. Getting to the batteries to replace them was a mission though. Very little info on how to do it. The screws are on the top part - which go against the ceiling, so you have to drop the unit in order to open the cover.
  7. The Following User Says Thank You to CabousBeer For This Useful Post:
  8. #5
    May 2024
    Cape Twon
    Hi Gents
    I have a garage door motor which I want to repurpose into another project(slow turning tumbler or spit) but find it difficult to get the correct power supply.
    It is a 24Vdc motor. Probably 5amp?? as there is no markings on the motor but I guess opening a garage door does need a bit of oomph.
    I have bought a 2 amp 220Vac - 24Vdc power supply, but it does not run. Gentleman at counter say I need a 10-15 amp power supply. Cost of that is R900 which doesn't justify the project. Probably can find a 220V motor for that price.
    The motor does have a transformer(toroidal) which was part of the original opener, but that make 220Vac - 24 Vac. It obviously used to go into the circuitry of the unit and somehow convert to 24Vdc and also charge the battery.
    Now my thought is, is there anyway I can get the 24Vac to 24Vdc? And off course this "thing" must be able to draw about 10 amps(starting) I guess.
    My knowledge on power conversions is very limited, but I refuse to give up as I learn in the process. The motor runs very nicely of two car batteries(tested it) but that is obviously not a long-term solution.
    It seems such a waist to not being able to use such a nice strong and steady motor.
    Any suggestions?
    Many thanks
    Stefan
  9. #6
    Jan 2022
    Kempton park
    Thanked: 667
    Quote Originally Posted by Schoemies View Post
    Hi Gents
    Any suggestions?
    Many thanks
    Stefan
    Just get a 35A bridge rectifier. Most decent electrical shops and electronics shops will have in stock.
  10. The Following User Says Thank You to Andrew V9X For This Useful Post:
