It would be quite simple to install a set of cables with fuses for a harrison/anderson connector in the load area.
I would then just install the largest capacity battery u could fit in the engine bay
Hi Everyone
I am a new member of the jimny tribe and I am overwhelmed with all the possible modifications and accessories that lay before me. That being said my question is this: I want to run very little off of any power from the vehicle, dual battery or otherwise. I don't want to install a fridge (too much space) nor run lights if the vehicle is not running (the whole point of camping is to get away from the lights as much as possible). All I want to install is one light bar for extra visibility whilst driving for the sake of safety and two anderson plugs for a compressor. Can I run all of this from the main battery if the vehicle is running? Are there any other critical powered components/options I am overlooking? Main goal is to use the vehicle for "light" overlanding. Probably 1 week maximum.
Would appreciate any and all feedback.
Youtube
Owned:09 Mitsubishi Triton 3.2 D/C 4x4
Sold:99 Mitsubishi Colt Rodeo 3.0 V6 4x4
Sold:05 Chevrolet Lumina UTE SS 5.7 V8 Auto
Sold:98 Mitsubishi Pajero Gen 2 SWB 3.0 V6 4x4
Sold:97 Ford Ranchero Outback 4.0 4x2
Sold:79 Land Rover Series 3 88" Ford 3.0 V6 4x4, 80 Landrover Range Rover 3.5 V8 4x4, 79 Landrover S2A 109" Chev 4.1 4x4
In that case I'd be putting in a larger battery, it's not 100% necessary but it does provide a little extra fudge factor.
One mob out my way does a no drill battery conversion mentioned for running a bigger battery for a winch, but if you put something like that in with a dual purpose battery so you have drinking and a bit more draw then you should be in good shape.
A lot will depend on the size of the light and compressor, if you run them only when the engine is on then you probably don't need to change anything.
But definitely carry a small lithium jump start unit, it's a heap of reassurance to have.
In your situation a dual battery wouldn't help anyway, you shouldn't run driving lights, winches, compressors ect off of a second battery anyway. The draw is too much, they need need that constant alternator power.
Before fitting a light bar - learn about the rules - 99% of lightbar installs are wrong and open you up to being stopped / fined / bribing your way out of a situation you dont even need to get yourself into
work out the possible amp draw of accessories before even worrying about a different / bigger battery
also only buy what you really really will use - not because some salesman said - never trust the opinion of someone you are about to give money to......
2022 Defender D300HSE
2024 LC Prado 250 VXR
2019 FJ Cruiser
BL Kewer 3188
Fusion 17
Sounds like you dont need a dual battery system and your lights and compressor options will work just fine if the car is running powered by the alternator.
Maybe a tiny portable power pack just to charge a camera/phone/laptop at camp and get some lights while you are cooking or cleaning at night kind of thing. Add a decent headlamp with red light option and for your needs you should be sorted.
"K.a.k Wheeler"
I'm a moron, but humour me.
GWM P Series 4x4 Limited
(4x4) Ex 2019 Ranger DC XLT Manual + 2017 XL Auto, Haval H9
Ex 320d E90, Maz MPS 2.3 DISI, CITI Golf MKI,
Ford Anglia 307E in British racing green, my first car ❤
Might be worth running one power cable from main battery via a relay switched from the ignition for the power points in the back.
That way you can't accidentally leave something on and kill the main battery.
It does mean that your ignition will have to be on for the power point to work though.
2008 Suzuki Grand Vitara 3.2 V6
2012 GWM Steed 5 DC 4x4 TCI - Sold
2002 Isuzu Frontier 280dt LX 4x4 - Sold
2000 Suzuki Grand Vitara 1.6 3dr - Sold
You don't need a second battery. But as noted by others, light bars are not legal in South Africa.
Rather find a pair of nice spots and make sure they comply with local legislation.
They should be a certain distance apart (I can't remember how much) and should only be able to be activated when your headlights are set to bright IIRC.
Thanks Everyone for the great feedback! My takeaway is that I might reconsider the lightbar/look for something legal. I think I will proceed with the anderson plug power install. Would this be a feasible project to take on myself (I think my electrical skills are more or less okay) or should even a small project like this be left for the professionals? Would they even take on such a small project?
Regarding bars and spots as I just went through this exercise :
The front of a vehicle must have an even number of lights on left and right.
A vehicle cannot have more than 6 headlights, including stock.
No lights may be placed higher than 1400mm from the ground.
No light may be placed higher than the leading edge of the bonnet.
No light may be placed across the vertical median of a vehicle. This is what makes LED bars illegal.
All lights must be in a working order. Even if they are covered or disconnected, still illegal.
Spots cannot be adjustable.
They are only illegal because our law hasnt caught up with the rest of the world, that is probably why it isnt enforced so much. But you just need that one cop in a bad mood.
https://www.arrivealive.mobi/lightin...es-of-the-road
"K.a.k Wheeler"
Yes. It's a pet gripe of mine - seeing some of the folk driving around with the terra-watt light set ups. Normally a light bar on the leading edge of the bonnet and 60 spots mounted on the roll bar...
Whilst my truck is legal in all aspects in terms of lights and driving lights, I gathered the other day that my work light on the back of my roof rack is actually technically illegal. I shall remedy this...
Ian de Villiers
Patrol 4.5 GRX
Sole local member of the GFYS club
Jurgens XT65 2x0 with Super Select Zero
ORRA: AG149
Could a case be made for a rear worklight being an extra reverse lamp?
I had 2 roofrack-mounted led lamps on the back of my Defender, that were wired to come on when in reverse, but could also be switched on and off independently of the reverse lamp (which I might add was useless, as there was no way to see through the canopy).
Erin Bosch (082 342 1909)
4xfagger no. GP0048
2012 VW T5 2.0BiTdi 132kW 4Mot Transporter
2005 Land Rover Discovery II TD5 Facelift
They are higher than 1400mm and you cannot have white light at the back, only red. But again so many people have rear working lights for camping and such.
My last Ford Ranger came with one stock so I dont know how that is legal. Maybe because it only shines in the load bin, was very dim and could not be permanently switched on?
"Also, bear in mind that spotlights that emit white light – or those with a blue tinge – are permitted only at the front of a vehicle, while spotlights that emit red light are allowed only at the rear. So, the backward facing white spotlight you have fixed to your 4×4 to illuminate your camp site in the bush is illegal."
https://www.getaway.co.za/brand-feat...s-and-the-law/
"K.a.k Wheeler"
We had a similar rule here about light bars, I fould a way around it by putting an inch or two of black duck tape in the middle making it 2 lights.
That was the only way to get it passed rego when it went over the pit.
But your definitely safer off with spotlights by the sounds of it.
If you are going to wire anything up to the rear, have it connected to the axillary circuit with a relay like lights.
That way you can't forget about something and end up with a flat battery at an inconvenient time.
"K.a.k Wheeler"
Not always, they got their act together but when lightbars were new there were the usual teething problems and were regarded as off road only for a period.
At least in the state I moved to after I got one fitted and has to pass a roadworthy.
No reason why you cannot do it yourself. Just get all the facts straight before you start. Wire thickness, connections soldered, isolation, fuses, routing issues to look out for etc. Think twice about installing 2 and the Brad Harisson. You are welcome to come and talk to me in Centurion. I do not want to do the job or sell you anything. Experience I give away.
