Results 1 to 18 of 18
    Mar 2024
    Default Minimal Power Installation
    Hi Everyone
    I am a new member of the jimny tribe and I am overwhelmed with all the possible modifications and accessories that lay before me. That being said my question is this: I want to run very little off of any power from the vehicle, dual battery or otherwise. I don't want to install a fridge (too much space) nor run lights if the vehicle is not running (the whole point of camping is to get away from the lights as much as possible). All I want to install is one light bar for extra visibility whilst driving for the sake of safety and two anderson plugs for a compressor. Can I run all of this from the main battery if the vehicle is running? Are there any other critical powered components/options I am overlooking? Main goal is to use the vehicle for "light" overlanding. Probably 1 week maximum.
    Would appreciate any and all feedback.
    Oct 2006
    Thanked: 523
    Default Re: Minimal Power Installation
    It would be quite simple to install a set of cables with fuses for a harrison/anderson connector in the load area.
    I would then just install the largest capacity battery u could fit in the engine bay
  3. The Following User Says Thank You to Racer-X For This Useful Post:
    Mar 2024
    Albury
    Thanked: 19
    In that case I'd be putting in a larger battery, it's not 100% necessary but it does provide a little extra fudge factor.
    One mob out my way does a no drill battery conversion mentioned for running a bigger battery for a winch, but if you put something like that in with a dual purpose battery so you have drinking and a bit more draw then you should be in good shape.
    A lot will depend on the size of the light and compressor, if you run them only when the engine is on then you probably don't need to change anything.
    But definitely carry a small lithium jump start unit, it's a heap of reassurance to have.
    In your situation a dual battery wouldn't help anyway, you shouldn't run driving lights, winches, compressors ect off of a second battery anyway. The draw is too much, they need need that constant alternator power.
    edenvale
    Thanked: 339
    Before fitting a light bar - learn about the rules - 99% of lightbar installs are wrong and open you up to being stopped / fined / bribing your way out of a situation you dont even need to get yourself into
    work out the possible amp draw of accessories before even worrying about a different / bigger battery
    also only buy what you really really will use - not because some salesman said - never trust the opinion of someone you are about to give money to......
  6. The Following User Says Thank You to 3bar For This Useful Post:
    Plett
    Thanked: 4508
    Quote Originally Posted by 3bar View Post
    Lightbars are illegal….many threads about this. I had one on my Jimny and was forced to remove it at a roadblock but still got a fine although the fitment centre fitted it legally.
    2022 Defender D300HSE
    2022 Isuzu Mux 4x2 LSE
    2019 FJ Cruiser
    BL Kewer 3188
    Fusion 17
    Thanked: 4469
    Sounds like you dont need a dual battery system and your lights and compressor options will work just fine if the car is running powered by the alternator.
    Maybe a tiny portable power pack just to charge a camera/phone/laptop at camp and get some lights while you are cooking or cleaning at night kind of thing. Add a decent headlamp with red light option and for your needs you should be sorted.
    "K.a.k Wheeler"
    Dont take anything I say as actual advice or fact. I dont.
    GWM P Series 4x4 Limited
    Ex 2019 Ranger DC XLT Manual 4x4, 2017 XL Auto 4x4, Ex Haval H9
    Ex 320d, Maz MPS, CITI Golf, Anglia Van
  9. The Following User Says Thank You to PsyPhin For This Useful Post:
  10. #7
    New Germany
    Thanked: 324
    Might be worth running one power cable from main battery via a relay switched from the ignition for the power points in the back.
    That way you can't accidentally leave something on and kill the main battery.
    It does mean that your ignition will have to be on for the power point to work though.
    2008 Suzuki Grand Vitara 3.2 V6
    2012 GWM Steed 5 DC 4x4 TCI - Sold
    2002 Isuzu Frontier 280dt LX 4x4 - Sold
    2000 Suzuki Grand Vitara 1.6 3dr - Sold
  11. The Following User Says Thank You to kippie2 For This Useful Post:
  12. #8
    Feb 2020
    Melkbosstrand
    Thanked: 770
    Quote Originally Posted by Brendan Harle View Post
    Hi Everyone
    You don't need a second battery. But as noted by others, light bars are not legal in South Africa.
    Rather find a pair of nice spots and make sure they comply with local legislation.
    They should be a certain distance apart (I can't remember how much) and should only be able to be activated when your headlights are set to bright IIRC.
    1995 Defender 110 300tdi
    Shortly taking wing..
  13. The Following User Says Thank You to CraigWatt For This Useful Post:
  14. #9
    edenvale
    Thanked: 339
    yip thats what I am warning about
    there are some lightbars that are legal (seperation etc) and then fitted in accordance with height / split etc - hence my 99% comment - as there are some that are legal but 99% are illegal and will lead to drawing unwanted attention
  15. #10
    Mar 2024
    Thanks Everyone for the great feedback! My takeaway is that I might reconsider the lightbar/look for something legal. I think I will proceed with the anderson plug power install. Would this be a feasible project to take on myself (I think my electrical skills are more or less okay) or should even a small project like this be left for the professionals? Would they even take on such a small project?
  16. #11
    Thanked: 4469
    Regarding bars and spots as I just went through this exercise :
    The front of a vehicle must have an even number of lights on left and right.
    A vehicle cannot have more than 6 headlights, including stock.
    No lights may be placed higher than 1400mm from the ground.
    No light may be placed higher than the leading edge of the bonnet.
    No light may be placed across the vertical median of a vehicle. This is what makes LED bars illegal.
    All lights must be in a working order. Even if they are covered or disconnected, still illegal.
    Spots cannot be adjustable.
    They are only illegal because our law hasnt caught up with the rest of the world, that is probably why it isnt enforced so much. But you just need that one cop in a bad mood.
    https://www.arrivealive.mobi/lightin...es-of-the-road
    "K.a.k Wheeler"
  17. The Following 4 Users Say Thank You to PsyPhin For This Useful Post:
  18. #12
    Garsfontein
    Thanked: 6280
    Quote Originally Posted by PsyPhin View Post
    Yes. It's a pet gripe of mine - seeing some of the folk driving around with the terra-watt light set ups. Normally a light bar on the leading edge of the bonnet and 60 spots mounted on the roll bar...
    Whilst my truck is legal in all aspects in terms of lights and driving lights, I gathered the other day that my work light on the back of my roof rack is actually technically illegal. I shall remedy this...
    Ian de Villiers
    Patrol 4.5 GRX
    Jurgens XT65 2x0 with Super Select Zero
    ORRA: H80
  19. #13
    Nov 2006
    Edenglen
    Thanked: 841
    Could a case be made for a rear worklight being an extra reverse lamp?
    I had 2 roofrack-mounted led lamps on the back of my Defender, that were wired to come on when in reverse, but could also be switched on and off independently of the reverse lamp (which I might add was useless, as there was no way to see through the canopy).
    Erin Bosch (082 342 1909)
    4xfagger no. GP0048
    2012 VW T5 2.0BiTdi 132kW 4Mot Transporter
  20. #14
    Thanked: 4469
    Quote Originally Posted by Imvubu View Post
    They are higher than 1400mm and you cannot have white light at the back, only red. But again so many people have rear working lights for camping and such.
    My last Ford Ranger came with one stock so I dont know how that is legal. Maybe because it only shines in the load bin, was very dim and could not be permanently switched on?
    "Also, bear in mind that spotlights that emit white light – or those with a blue tinge – are permitted only at the front of a vehicle, while spotlights that emit red light are allowed only at the rear. So, the backward facing white spotlight you have fixed to your 4×4 to illuminate your camp site in the bush is illegal."
    https://www.getaway.co.za/brand-feat...s-and-the-law/
    "K.a.k Wheeler"
  21. #15
    Mar 2024
    Albury
    Thanked: 19
    We had a similar rule here about light bars, I fould a way around it by putting an inch or two of black duck tape in the middle making it 2 lights.
    That was the only way to get it passed rego when it went over the pit.
    But your definitely safer off with spotlights by the sounds of it.
    If you are going to wire anything up to the rear, have it connected to the axillary circuit with a relay like lights.
    That way you can't forget about something and end up with a flat battery at an inconvenient time.
  22. #16
    Thanked: 4469
    Quote Originally Posted by Bob9863 View Post
    Light bars are legal in Aus though? And they have to be center mounted...
    "K.a.k Wheeler"
  23. #17
    Mar 2024
    Albury
    Thanked: 19
    Not always, they got their act together but when lightbars were new there were the usual teething problems and were regarded as off road only for a period.
    At least in the state I moved to after I got one fitted and has to pass a roadworthy.
  24. #18
    Aug 2016
    Thanked: 337
    No reason why you cannot do it yourself. Just get all the facts straight before you start. Wire thickness, connections soldered, isolation, fuses, routing issues to look out for etc. Think twice about installing 2 and the Brad Harisson. You are welcome to come and talk to me in Centurion. I do not want to do the job or sell you anything. Experience I give away.
  25. The Following User Says Thank You to Pieter de Waal For This Useful Post:
