Results 1 to 20 of 21
    Jun 2008
    pretoria
    Thanked: 160
    Default snowmaster fridge cooling on 220v but not 12 volt
    Hi All
    My snowmaster fridge cools on 220v but when plugged in on 12 volt stops cooling. What could be the problem. Thanks
    2020 Toyota Landcruiser 200 GX-R
    2018 Range rover sport
    2017 BMW M4
    Vredenburg, West Coast
    Thanked: 2550
    Default Re: snowmaster fridge cooling on 220v but not 12 volt
    Quote Originally Posted by pieter_fourie View Post
    Hi All
    Snowmaster's Head Office and factory outlet is in Edenvale, off the R24 about 2km past OR Tambo Airport.
    Bring it to them to resolve. They are nice reasonable people and should resolve it for you in next to no time. Perhaps just a connection or a small component failure...
    Malcolm van Coller - retired 2013, West Coast from April 2024.
    1. 2008 Nissan Patrol 3.0 TDi GL with front Lokka (Use it mainly for Safari business)
    2. 1998 Nissan Patrol 4.5 GRX - stock (Will use it for Safari business)
    3. Wife - 2021 Renault Duster 1.5Dci 4x4
    Sold: 2010 Nissan Pathfinder 2,5 CDi LE Manual (with front Lokka) -
    Sold: 1999 Nissan Terrano 2.7 TDi
    Sold: 1995 Nissan Patrol GQ 4.2i Auto
    Sold: 1988 Nissan Patrol 2.8 with 5 speed conversion
    Sold: 1995 Nissan Sani 3.0 V6 Exec
    Jun 2015
    Thanked: 92
    Set fridge on low battery cut out and have a load test done on battery
    Jan 2008
    Thanked: 70
    Check the 12v fuse.
    Had the same problem. New fuse problem solved.
    JR
    98 Nissan Hardbody 3l, Front Runner detachable roof rack, own drawer system and dual battery.
    13 Toyota Fortuner 4x4 auto, Wilderness 310.
    Sep 2008
    Port Alfred
    Thanked: 102
    Apologies if hijacking this thread.
    I have the same with a 20-something year old Engel.
    I am told it is the PC board that is faulty, and the fridge is obsolete and parts no longer available - any ideas?
    Triton 3.2 A/T D/Cab 4x4
    BL Vlooi 295
    Platkar - Rav4
    Previously: Isuzu "LUV", Disco D1 TDi, KZ-TE
    A bad day in the bush is better than a good day at the office
    Jun 2015
    Thanked: 92
    You can get spairs, from 4x4 mega world in JHB. But not cheep
    Jun 2015
    Thanked: 92
    We're you located
    Polokwane
    Thanked: 2582
    I would do the following.
    1. Check the battery or try another battery.
    2. Set the voltage cut-off to 10.5v
    3. Check all fuses and connections.
    4. Then take it to Snomaster or Johan Prinsloo (he is in Lynnwood)
    2013 Toyota Fortuner 3.0 D4D 4x4 Auto
    ZS6DCP
    Oct 2022
    Tete
    Thanked: 7
    I had the same problem with my snomaster.
    It was my own fault, tried to run it from a 12v generator which spiked and cooked the transformer.
    Contacted Snomaster direct who were very helpful and supplied me with a replacement transformer which I was able to replace fairly easily.
    Dec 2015
    Kensington/Boshof
    Thanked: 403
    Quote Originally Posted by dust-devil View Post
    Had the same problem with my 20+ year old engel last year. Took it to 4x4 megaworld and they replaced the power supply module and now working 100% again
    Kenneth
    LC 79 V8 double cab
    Plett
    Thanked: 4502
    Quote Originally Posted by Kennyg View Post
    Do you have approximate cost for this? I also have a poked Engel.
    2022 Defender D300HSE
    2022 Isuzu Mux 4x2 LSE
    2019 FJ Cruiser
    BL Kewer 3188
    Fusion 17
    Dec 2015
    Kensington/Boshof
    Thanked: 403
    The power supply module, new rubber gasket/seal for the lid and labour was just under R4k.
    Kenneth
    LC 79 V8 double cab
  13. The Following User Says Thank You to Kennyg For This Useful Post:
  14. #13
    Mar 2013
    Boksburg
    Thanked: 52
    Hi Pieter. I had the same problems a couple of years ago and Snomaster could not fix it initially. There specialist technical person solved the problem. Drop the battery protection to the lowest possible and change the cooling to Auto. Since then the fridge worker perfect in Kalagadi. You can run a test at home by plugging the fridge into a 12v source. Good luck.
    My lorrie: 2014 Toyota Hilux 4x4 D4D
    2006 Isuzu 250 Fleetside
    Vrou se platkar: 2023 VW T-Cross
    4x4 Trailer: Bushlapa Kewer 2155
    EX: Amarok BTDI DC
    Echo 4
  15. The Following User Says Thank You to kp dippenaar For This Useful Post:
  16. #14
    Thanked: 2224
    Get rid of it and buy a Engel!
    usually just PSU. I have lost 3 snowmasters that were not fixable. Its a brand I cannot support
    Angel Group
    Solar-Construction-Offroad
    [email protected]
    0824453301
    Next event: 4x4 Recovery-TBA
    https://gfolk.me/HermanEngelbrecht475422
  17. The Following User Says Thank You to Engel For This Useful Post:
  18. #15
    Jun 2015
    Thanked: 92
    The only thing that is not fixable is a gas leak within the walls.
  19. The Following User Says Thank You to calitzfamily For This Useful Post:
  20. #16
    Pretoria, South Africa
    Thanked: 34
    Contact Camp Fridge Repair on 082 903 9971.
    Johann Prinsloo.
    Lynnwood
    066 207 0593.
  21. The Following User Says Thank You to JohannP For This Useful Post:
  22. #17
    Thanked: 34
    Quote Originally Posted by calitzfamily View Post
    Contact Camp Fride Repair on 082 903 9971.
    Johann Prinsloo.
    Lynnwood
    066 207 0593.
  23. The Following User Says Thank You to JohannP For This Useful Post:
  24. #18
    Oct 2012
    Roodeplaat
    Thanked: 441
    It can be saved
    064 344 1489
  25. #19
    Oct 2012
    Roodeplaat
    Thanked: 441
  26. #20
    Jun 2015
    Thanked: 92
    Warner were are you located
