Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 64
  1. #41
    Sep 2010
    Centrurion
    Default Re: Is Solar panel cleaning worth it?
    I cleaned my panels last winter, and the panels facing NWW improved quite a bit. The ones facing N not much of an improvement.
    I bought an extendable rod ( to 6m) and used it with a mop and squeegee to clean the panels.
    Based in Centurion
  2. The Following 2 Users Say Thank You to Preggy For This Useful Post:
  3. #42
    Jan 2022
    Kempton park
    Thanked: 455
    I have just cleaned mine. 4x575W. I noticed recently they were battling to keep up when my pool pump was running and the battery was subsidising the load. Immediately after cleaning the battery was now charging again as well. They are on a flat roof though with little rain recently.
  4. The Following User Says Thank You to Andrew V9X For This Useful Post:
  5. #43
    Jan 2022
    Kempton park
    Thanked: 455
    Default Is Solar panel cleaning worth it?
    Duplicate
  6. #44
    Dec 2014
    Thanked: 3981
    Quote Originally Posted by Andrew V9X View Post
    I joked above, about the rain doing its thing, but with the construction site next to us, the best I am seeing is peaks of 2.5kw, also not seeing peaks being handled or batteries charged.
    My panels look Grey with dust. 10550w. I am using a lot more Eskom than last year with 2 Batteries. I added a 3rd in July last year.
    Calling Herman, to clean and do a check of the system, as posted above
  7. #45
    Middelburg
    Thanked: 735
    Quote Originally Posted by Preggy View Post
    Care to share the details of that 6m extendable rod please?
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
  8. #46
    Thanked: 2914
    I did a test this morning. Panels were installed October 2022. Cleaned them for the first time today. They looked dusty. I then checked pv and compared the last 16 days from 11am until 11:45 under the same sunny conditions. Surprise!!! There is virtually no difference in efficiency. Maybe Gauteng will be different and other areas depending on chemical fallout, dust, grime etc.
    Pal of mine did same last week ... huge difference in production.
    Bottom line: Try it once ... see if there is a change, or not.
    There is no "one size fits all".
    Political Correctness
  9. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
  10. #47
    Thanked: 4601
    Sprayed them with water. They just had a layer of dust on.
    Meh, wasnt worth the time I spent outside
    Blue is yesterday, red is today, battery is about to be full so no use continuing the monitor
    "K.a.k Wheeler"
    Dont take anything I say as actual advice or fact. I dont.
    GWM P Series 4x4 Limited
    Ex 2019 Ranger DC XLT Manual 4x4, 2017 XL Auto 4x4, Ex Haval H9
    Ex 320d, Maz MPS, CITI Golf, Anglia Van
  11. #48
    May 2023
    Witbank
    This photo was taken a few years ago, before and after I cleaned the panels....
    Staying in Mpumalanga close to the power stations and coal mines tends to get a bit dusty.
Name:	Screenshot from 2019-08-04 12-24-12.png
    Fortuner 2.4 GD6
    Jurgens Xplorer Xcell
  12. #49
    Johannesburg/Prague
    Thanked: 519
    [QUOTE=Andrew V9X;5236047]I have just cleaned mine. 4x575W. I noticed recently they were battling to keep up when my pool pump was running and the battery was subsidising the load. Immediately after cleaning the battery was now charging again as well. They are on a flat roof though with little rain recently.[/QUOT
    yes if on a flat roof and not positioned to get the most of our Winter Sun then cleaning will help , I also have flat panels and they do need cleaning the once on the roof 30 deg pitch are fine, I have never cleaned them and the output from them does down around 5% , the flat panels dropped to 50% after cleaning down to 25% so a big improvement
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
  13. The Following User Says Thank You to 12richardk For This Useful Post:
  14. #50
    Apr 2014
    Thanked: 10645
    I can clean standing on the ground. I have not seen any difference in the output. Using municipal water we have to pay for it. Using own water then it is 2 pumps running. Electricity from the panels.
    I wash them only for the look.
    Those washing contracts are in the same category and air con servicing.
    Jouko
    2015 Grand Cherokee Summit Petrol
    2012 Smart
    Never drive a normal car
  15. The Following User Says Thank You to Jouko For This Useful Post:
  16. #51
    Jan 2016
    Middelburg
    Thanked: 1345
    Definitely worth it. Batteries weren't charging fully before. Now, all is back to normal.
  17. The Following User Says Thank You to GH For This Useful Post:
  18. #52
    Dec 2014
    Thanked: 1279
    Quote Originally Posted by GH View Post
    South facing panels aren't optimal they say
    2012 Jeep Wrangler JKUR -- Sold (I'll be back )
    2015 Jeep Grand Cherokee Overland 5.7 Hemi
  19. The Following 5 Users Say Thank You to Alwyn777 For This Useful Post:
  20. #53
    Jan 2016
    Middelburg
    Thanked: 1345
    Quote Originally Posted by Alwyn777 View Post
    Smart of you to notice.
  21. #54
    Dec 2014
    Thanked: 1279
    Just poking some fun.
    To this, I also decided to give mine a rinse with the hose pipe today as they looked kind of dusty so I obviously hoped for some material difference post rinsing, but alas. PV went up with 100-200w max. But you're right, they do look better black than brown.
  22. #55
    Apr 2014
    Thanked: 10645
    I assume that the cleaning benefit depends on the area and how flat the panels are. We are close to "dust free" and the panels are at a nice angle. Inside 3 month between the dusting and house is still OK. Panels do get thin layer so that there is a slight color change.
    Once I was told that on those panel farms in NC there are permanent cleaners but the bigger issue are the rats that like the wires. I have not checked these claims.
    Jouko
    2012 Smart
  23. #56
    May 2013
    Thanked: 1186
    I had the panels at my house "professionally" cleaned last week.
    Made ZERO difference. This after you could see how filthy the panels were. They are looking nice and shiny now, though.
    I'm still peaking at about 2.5kW out of a possible 4.3kW.
    My parents live about 500m from me, and theirs makes a bit more, but that is a brand new system.
    Current: Mercedes-Benz ML350 4Matic
    SWAMBO: 2020 Renault Koleos 2.5 Dynamique
  24. #57
    Jan 2016
    Middelburg
    Thanked: 1345
    We cleaned on Saturday. Friday the 24th the panels hardly got to 30kw and didn't charge batteries fully. Eskom also had to cover loads in the morning before the sun.
    Sunday Eskom wasn't needed because after cleaning on Saturday the batteries charged fully. Panels went over 30kw and after 13:00 batteries were fully charged and panels covered load.
ID:	723097   Click image for larger version.
  25. #58
    Apr 2014
    Thanked: 10645
    I used to live in Witbank. Air quality was bad. Middleburg has most probably the same. Coal mines, power stations and dust from farming. Maybe this mixture is "poison" for the panels.
    Jouko
    2012 Smart
  26. #59
    Centurion + Others
    Thanked: 441
    besides getting onto the roof - I suppose you could have a pole with a squeegee on the end.
    spray water - wipe off
    need to make one
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
  27. #60
    Jan 2016
    Middelburg
    Thanked: 1345
    Quote Originally Posted by Jouko View Post
    Definitely. Winter is very dusty. With harvesting and the solar system is mainly used for the silos, having trucks riding in and out a lot of dust is thrown into the air just from that. If the dragline on the mine is running with the wind from the north, we get that dust too.
  28. The Following User Says Thank You to GH For This Useful Post:
