Google is conflicting but I can't work out what animal this would belong to.
Frog turd.
2003 Mitsubishi Pajero 3.2 Di-d LWB
Frog poop. We find them in our garden regularly. Had a small frog family that stayed here. Came out early evening for a swim in the bird baths we have in the garden
If you can, break the turd and try and identify whether the contents contains plant/insect or rodent parts. Then you can narrow down the list of suspects.
"When a clown enters a palace, he does not turn into a prince, the palace turns into a circus."
Luka Geertsema
I would also go with frog. White tip on poo is absent.
Only one way to be 100% sure. Dress up as a frog and sit still in the garage. If a snake comes to eat you, you have a snake. If a frog comes to mate with you, you have frog.
Alwyn777, Andrew V9X, breyts, Chopped, Chris8d, Ferty, GROENIEdieDRAAK, Half-Pint, Jan D, johanventer, Jonatan, Kallie Vos, kilimanjaro, Lowrider, Luka, MarcR, Mikel89, milanrenaud, Nords, Papsak, Poggie, Ramilayo, RobH, sAnD.mAn, Stranger, Toxxyc, Tsotsi
For every snake you see, 99 have seen you. So why worry about that 1...
Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km, almost.
2007 Patrol Pickup TD42 "bulldozer" - 500 000km
2014 Patrol GU 3.0CRD "teenager" in puberty - 180 000 km
2007 Echo3 Trailer "the nest" with Braked Axle fitted + 265/75/R16 rubber on Patrol Rims!
Ewiks Caravan Movers now fitted to trailer, lekkerrrr - I should have done that long ago. AND 2.6kW lifepo4 in trailer, 3.1kW lifepo4 in NL box with Victron MPPT and DC-DC in Patrol, 2x1kW in small packs with MPPC/ DC‐DC as backup in case , all self built, 480W panels Victron MPPT and 220V 25A IP67 charger
2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 158 000 km
In the interest of transparency, I must disclose that my real name is Anakin Skywalker. I hail from the planet Tatooine. When I am not piloting my Imperial Class Destroyer, a magnificent vessel that perfectly complements my malignant narcissism, I drive a Nissan Patrol, a Japanese automobile from Planet Earth that certainly grounds me in many, many ways.
Found this. Looks too small for the dung size.
Very large skink lizard.
Looks like Variegated Skink
Luka Geertsema
This?
Defiantly a frog.
FJC - Just Cruising
Maybe you have a snake and a frog...
Aristotle wrote; ''Excellence is never an accident. It is always the result of high intention, sincere effort, and intelligent execution. It represents the wise choice of many alternatives. Choice, not chance, determines your destiny''
I would say a gheko.
We have a couple around the house.
Most turds do have a white tip, but occasionally do get them without the white tip.
We find ours near open windows, guessing that they hang around here hoping to catch the odd miggie?
Toad
