Results 1 to 4 of 4
    Feb 2024
    Default 2008 Outlander Radio AUX inputs
    Good Day,
    I have a 2008 Outlander with a upgraded Rockford Fosgate sound system.
    The radio has a AUX function but I do not see any AUX inputs.
    Please can anyone help on how to get AUX on my radio please.
    Attached is photos of the radio.
    The radio is connected with 2 plugs from the harness. There is another plug taped to the harness, and I have no idea what that is for.
    I can not find any wiring diagrams for the radio nor the harness.
ID:	714440   Click image for larger version.
ID:	714441   Click image for larger version.
ID:	714442   Click image for larger version.
    Thanked: 2868
    Default Re: 2008 Outlander Radio AUX inputs
    Its can be done..give me a bit I will find the link to how to do it..You splice three of the harness cables and connect a earphone jack cable that you then plug into your phone so you can play music and also answer calls
    Thanked: 2868
    Just to make sure..You dont have the RCA points inside your middel arm rest?Then all you need is a dual rca to earphone jack and nothing else
    Thanked: 2868
