Results 1 to 5 of 5
    May 2023
    Default NL Fridge Freezer 72L dual compartment or 90L one lid
    We are looking at buying a NL Fridge Freezer, and wondered if having the larger capacity 90L with single lid is better over the 72L dual lidded? Does the single lid cause an issue with the freezer part, when opening to access the fridge compartment? Both being the same outer dimensions
    Thanks in advance for any advice
    Jan 2009
    Thanked: 397
    Default Re: NL Fridge Freezer 72L dual compartment or 90L one lid
    Will probably be crucified for the following...
    Having had both and loving the space/lay-out of the 90L - I would really advise going the 72/74L way - the construction and reliability seems be better on the dual door-unit.
    My brother's brand new 90L Legacy Smart that was not even a year old in December gave issues not reaching below zero after running for numerous days....
    My 2c's worth
    Martin Pienaar
  3. The Following User Says Thank You to Martinj For This Useful Post:
    Tshwanetoria
    Thanked: 4771
    If you take a single compartment, you will definitely be adding a cooler-box to the configuration as well. Space? Additional management?
    Vredenburg, West Coast
    Thanked: 2840
    Quote Originally Posted by AHalle View Post
    I have had the 90lt Dual Door NL since their launch. I also had the 72lt Dual Door version since that model's launch, which i sold for the bigger version. I got it the 90lt for around R11500 as a launch special price. I particularly enjoy the extra fridge space. The freezer is much the same size, both are maybe 40mm deeper, if my memory serves me correctly.
    I had the 72lt one for about ten years and had it serviced once because the lid rubbers became tatty and needed replacement, not any other issues . The small fridge compartment always irritated me though.
    The 90 lt must also be about 8 or 10 years old now, absolutely no issues apart from the slider graunching up the 12v cable. I got a new one directly from National Luna at their factory in Edenvale.
    The 90lt one has thinner insulation, hence the extra space, so the 72lt is the better option if you camping in one place for longer, but I have never had an issue with the lesser insulation as I stay at any one place for 2 days max, then I move along. The alternator then keeps the LiFePo2 battery strong for running the compressor slightly more often.
    Malcolm van Coller - retired 2013, West Coast from April 2024.
    1. 2008 Nissan Patrol 3.0 TDi GL with front Lokka (Use it mainly for Safari business)
    2. 1998 Nissan Patrol 4.5 GRX - stock (Will use it for Safari business)
    3. Wife - 2021 Renault Duster 1.5Dci 4x4
    Sold: 2010 Nissan Pathfinder 2,5 CDi LE Manual (with front Lokka) -
    Sold: 1999 Nissan Terrano 2.7 TDi
    Sold: 1995 Nissan Patrol GQ 4.2i Auto
    Sold: 1988 Nissan Patrol 2.8 with 5 speed conversion
    Sold: 1995 Nissan Sani 3.0 V6 Exec
    Thanked: 2840
    Duplicate
