Results 1 to 10 of 10
    Thanked: 1922
    Default Using Brickettes in a Pizza / Wood Fired oven
    A query came up regarding how to keep a constant heat as close as possible for slow cooking and smoking. Some ideas were mentioned and one was using a Webber Kettle Braai basket loaded with Brickettes. I gave this some thought, and the following is the direction I am taking. I will give feedback on my findings, once I have successfully slow cooked at a fairly even temperature. This should be good for overnight Ham Hocks, Briskets and short rib or even Chicken or a lamb leg roast or lamb shanks.
    I made 2 basket type holders from a drum I had. Its galvanized so I had to wash of the nickel with acid then burn it before constructing the basket holder. I have designed it so that I have the following options.
    • Make half size fire in W/F oven - This is to initially heat up the oven for slow cooking. Push coals aside and add two basket holders primed with Brickettes. Light brickettes from each edge so you get a slow long burn (Webber Snake Method)
      or
    • Make half size fire in W/F oven - This is to initially heat up the oven for slow cooking. Instead of pushing coals aside, fill basket holder with one layer of coals, stack brickettes on top and they will start a slow burn. I will be experimenting with both and give you feed back.
      Please note these basket holders can be move closer to or further away from the meat. they are curved nearly matching oven curve.
Name:	1 Holder design.jpg
ID:	711779   Click image for larger version.
Name:	2 Brickettes in holder.jpg
ID:	711780   Click image for larger version.
Name:	3 Oven with brickettes.jpg
    MikevR
  2. The Following 3 Users Say Thank You to MikevR For This Useful Post:
    Nov 2006
    Thanked: 922
    Default Re: Using Brickettes in a Pizza / Wood Fired oven
    This is brilliant.
  4. The Following User Says Thank You to Damdan For This Useful Post:
  5. #3
    Oct 2021
    Thanked: 4565
    Mike please stop, you making us all look bad
    2020 Isuzu D-Max 250 X-Rider D/C 4x4
    Ex: 2017 Jimny & F800gs Adventure
    A man who lacks purpose distracts himself with pleasure.
  6. The Following 3 Users Say Thank You to PJ SA For This Useful Post:
  7. #4
    Ruimsig
    Thanked: 45290
    Awesome Mike.
    Us WSM guys stack the briquettes like dominoes, on the narrow end, leaning towards the ignition point, like the pic below. I am not sure if it makes a material difference but you will be assured that if the preceding coal is lit, then it will definitely ignite the following one. I have seen them stacked like in your photo but I have never tried them like that although I am sure they will burn uninterrupted.
    Looking forward to the results of this project
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  8. #5
    Thanked: 1922
    Thanks Folks - with this idea I may have turned my Wood Fired oven into a Webber in Big Green Egg. Who knows
    MikevR
  9. #6
    Apr 2017
    Joburg
    Thanked: 948
    By opening and closing the bottom of the Weber one controls the temperature of the oven inside and essentially the rate at which the coals burn.
    If you donít mind me asking, how are you going to control the temperature inside the oven for an overnight cook with a pizza door either open or closed?
  10. #7
    Thanked: 1922
    Quote Originally Posted by Therackermann View Post
    Very good question. Thats why I will be doing trials. I can adjust door opening to regulate burn. trials will tell me how long the burn will be and what will the temp variable will be. I try between 2 level snake to 3 level snake and trials can take place during the day without cooking anything but just monitoring performance. Even Weber performance is reliant on experience for controlling temp. If I get it right, I will add adjustable air flow in and out on slots on the door.
    MikevR
  11. The Following User Says Thank You to MikevR For This Useful Post:
  12. #8
    Apr 2011
    Thanked: 1635
    Magic is to get the bottom part warm first ...
    Flames is just extra magic ...
    Hou op om almal altyd gelukkig te probeer hou, Jy is nie n braaibroodjie nie
  13. #9
    Apr 2011
    Thanked: 1635
    Like so ...
ID:	711801   Click image for larger version.
ID:	711802   Click image for larger version.
ID:	711803   Click image for larger version.
ID:	711804   Click image for larger version.
ID:	711805   Click image for larger version.
  14. The Following 2 Users Say Thank You to spicydave For This Useful Post:
  15. #10
    Ruimsig
    Thanked: 45290
    Quote Originally Posted by MikevR View Post
    57 Weber, single level snake, two wide, I get approx. 8+hrs from a 2/3rds around the grate, charcoal brand dependent. Chaka I have found to be the most consistent and longest burning. I aim for a temp in the 120 to 160 range and I can maintain this with some adjustment to the bottom and top vent.
    The WSM has a large water bowl which acts as a hunidifier but also a heat sink for temp stability, but does require topping up, something you might want to consider.
  16. The Following User Says Thank You to Estee For This Useful Post:
