Results 1 to 14 of 14
    Sep 2019
    Pretoria East
    Thanked: 5127
    Default Lamskenkels met lensies| lamb shanks with lentils
    I have been meaning to post this recipe for a long time and I keep forgetting, but I stumbled across it now when I wanted to reprint a fresh copy of one of my other recipes.
    The meat is not enough in the original recipe. I usually just add at least one piece of meat per person or alternatively as many as will cover the surface area of the casserole I'm making it in. I like to make in my squarish/ ovalish corningware with the see through lid (the later white stripy kind, not the earlier blue flower kind) and laugh about space ships while I put it together in honour of my friend from whom I got the recipe. It came from one of those strange magazinelike thin cookbooks that Woolworths used to sell many many moons ago.
    [In 1953 S. Donald Stookey of the Corning Research and Development Division accidentally discovered Pyroceram, a white glass-ceramic material capable of withstanding a thermal shock of up to 450 K (840 F). He was working with photosensitive glass and placed a piece in a furnace, planning on heating it to 600 degrees Fahrenheit. When he checked on his sample, the furnace was at 900 degrees and the glass had turned milky white. He reached into the furnace with tongs to discard the sample, and it slipped and hit the floor without shattering. Pyroceram was originally used in the ballistic missile program as a heat-resistant material for nose cones. Pyroceram was used to protect space shuttles form extreme temperature changes. ... now you know why everyone has a pyrex dish but no lids anymore. Borosilicate glass doesn't bounce quite like pyroceram can. ]
    I think this is very suitable for camping because it's a one pot dish. You assemble all the ingredients in layers and as it cooks it imbues the flavour from layer to layer. It's pretty foolproof. The only thing you can effectively do wrong is cook the lentils until they are mush. It will still be edible, just not as nice obviously. It's not strongly flavoured so if you are part of the 30% that are non-tasters you will definitely want to zhoosh it up. Medium tasters, give it a go first and see if you enjoy the more subtle version.
    I often substitute the meat out and have made it with everything from lamb chops to ribs to whatever was at hand. It's one of my favourite winter meals.
    Aristotle wrote; ''Excellence is never an accident. It is always the result of high intention, sincere effort, and intelligent execution. It represents the wise choice of many alternatives. Choice, not chance, determines your destiny''
  2. The Following 4 Users Say Thank You to Emmie L For This Useful Post:
    Sep 2019
    Pretoria East
    Thanked: 5127
    Default Re: amskenkels met lensies| lamb shanks with lentils
    Lamb shanks with lentils
    1 Cup 250g Red lentils
    Teaspoon Salt
    1 Onion Diced
    2 Celery sticks Diced
    1 Green Capsicum Diced
    2 Cloves Garlic Finely chopped
    4 Small Lamb shanks
    2 Cans 800g Crushed tomatoes
    3 Bay leaves
    3 Teaspoons Fresh marjoram Chopped
    3 Teaspoons Thyme Chopped
    1. Preheat the oven to moderate 180C/ 350F/ Gas 4.
    2. Spread the lentils in the base of a large ovenproof casserole dish and sprinkle with salt.
    3. Add the celery, capsicum, garlic and onion.
    4. Layer the lamb shanks over the top.
    5. Then pour over the tomatoes.
    6. Add the salt, bay leaves, marjoram and thyme.
    7. Cover the dish (with foil if you dont have a lid) and bake for 2 hours.
    8. Skim off any fat which may have formed on the surface. (I don't remember usually doing this, even though it's in the original recipe.)
    9. Remove the bay leaves and stir together the lentils, meat and vegetables before serving.
    Note
    - Red lentils are smaller and softer than green or brown lentils and so do not need to be soaked before cooking.
    - Make sure the oven is not hotter than 180C as it will dry out the ingredients and turn the lentils to mush. Err on slightly under rather than slightly over.
    Variation
    Lamb shanks are a very economical cut of meat use chump chops if shanks are not available.
  4. The Following 6 Users Say Thank You to Emmie L For This Useful Post:
  5. #3
    Ruimsig
    Thanked: 44950
    Do you have to Emmie. I am trying to get my weight down to pre-Christmas level
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
    Sep 2019
    Pretoria East
    Thanked: 5127
    This is very healthy Sean. I can eat it even on the most restricted version of my diet and not have any negative effects. I don't think it will affect your weight in the negative direction. I usually only make it after the season has turned in the direction of winter though. But I put off posting it again the gold fish memory might forget it exists.
    Oct 2017
    Rustenburg
    Thanked: 15436
    Default Re: Lamskenkels met lensies| lamb shanks with lentils
    This will do nicely, thanks Emmie!
    Andrew van Staden
    Old Wheeler
    Aug 2016
    Brakpan
    Thanked: 72
    Thanks Emmie,
    I tried your recipe as it sounded delicious.
    I threw everything in the slow cooker and ran it for 6 hours at the low settings.
    After I removed the bones, I stirred everything and then added "penne pasta".
    The dish was delicious and very tasty.
    I am however of the opinion that the tomato flavor was somewhat overwhelming, so will add less tomato next time and probably more garlic.
    I have to admit I had to google some of the ingredients - never new a green pepper's fancy name was a Capsicum. Also never had, knowingly, eaten marjoram.
    Anyhow thanks for the recipe, it is/was a winner.
    Gaborone, Botswana
    Thanked: 3179
    Wat betaal julle nou vir Lam Skenkels daar in Gauteng ?
    Kobus
    May 2016
    Thanked: 9456
    Te veel!
    R125 - R170 /kg (en 50% is been)
    2003 Mitsubishi Pajero 3.2 Di-d LWB
    Gaborone, Botswana
    Thanked: 3179
    Te veel!
    Dit is wat ons betaal in BWP
    Kobus
    Sep 2019
    Pretoria East
    Thanked: 5127
    Quote Originally Posted by Kalahari Leo View Post
    Thanks Emmie,
    I can imagine that the tomato is too much if you leave out the lentils as the tomato liquid is what rehydrates the lentils and so is leached off to an extent.
    And now you are part of the exclusive group that has eaten marjoram knowingly.
    Marjoram is one of those herbs that pair well with lamb and you will often find it along with rosemary in lamb dishes.
    I would not recommend adding the lentils if you are doing it in the slow cooker though. They will turn to an unappealing mush. I sadly don't eat pasta often and reserve it for rare occasions, so have not made it with penne. I'm sure it was yummy.
  13. The Following 2 Users Say Thank You to Emmie L For This Useful Post:
  14. #11
    Linden
    Thanked: 6526
    Quote Originally Posted by Emmie L View Post
    Sies
  15. #12
    Sep 2019
    Pretoria East
    Thanked: 5127
    Sies
    Daar het jy nou die antwoord vir jou roosmaryn probleem. Vervang dit net in resepte met marjolein. So maklik opgelos.
  16. The Following User Says Thank You to Emmie L For This Useful Post:
  17. #13
    Jul 2010
    Pinetown
    Thanked: 4948
    Thumbs up Re: amskenkels met lensies| lamb shanks with lentils
    Ja ST, the lentils are a bit high carb ... but I guess I can dare it now given my major weight loss.
    A good one for the cooler months methinks.
    Peter Hutchison
    Answering the call of the wild is just so much better than answering the mobile.
    Waking up in the morning is a good start. Then remember never ever to cross off the last item on your "bucket list" before first adding at least one more !!
    Isuzu KB 280DT D/C 1998 (WIP) Heading for 500 000 Km shortly.
    Platkar = 2010 Chevy Spark 1.2 (60 000 Km in 13+ years - town kar)
  18. #14
    Sep 2019
    Pretoria East
    Thanked: 5127
    Quote Originally Posted by Peter1949 View Post
    Peter I find the little red ones in this recipe are not as robust as the others. Also, in winter the body naturally craves more carbs so this is the lesser of the evils to satisfy that and keep on the lower carb side. I mainly make this dish in winter time.
  19. The Following User Says Thank You to Emmie L For This Useful Post:
