Results 1 to 4 of 4
    Sep 2012
    Strand
    Default 2004 BMW R1200GS Fuel Pump leak
    Hi All
    My bike developed a fuel leak at the fuel pump quick connector - seems to be a common issue.
    I know overseas the guys have brass coated replacements as attached -was wondering if anyone has fitted them -any issues and where the were sourced? Does anyone locally stock them?
Name:	Fuel connector kit.jpg
    2010 Jimny - EFS suspension lift , bash plate , radial arm cup protectors , ARB bumper , Rocksliders, Diff protector, CAT removed , Freeflow ,Unichip and ARB difflock (rear)
    2013 Grand Vitara Summit A/T - Standard for now.
    Aug 2016
    Brakpan
    Thanked: 72
    Default Re: 2004 BMW R1200GS Fuel Pump leak
    Quote Originally Posted by Jellybean View Post
    Hi All
    There was a recall on the air cooled R1200 BMW's.
    Check with your local dealer if yours was done.
    In fact I'd just take it in and ask them to fix. If the workshop foreman is any worth he should be able to claim it - this is a known problem on all those models.
    I acquired a 2006 HP2 Enduro last year with a similar problem, took it to East Rand BMW and they fixed it. Even replaced the fuel pump FOC.
    Jul 2018
    Kathu
    Thanked: 388
    the recall was for a leak on the pump iirc.
    This looks like you need a fuel quick coupling. The right one has some specific code. I am trying to search what it is....then possible via online shopping to source
    Jul 2018
    Kathu
    Thanked: 388
    there you go...search for this
    Parker Rectus T21 Brass fittings
