Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 55
    Ruimsig
    Thanked: 44950
    Default Jaffel Irons: Stop Sticking
    Right, had I tried a Jaffel iron pre-1994, I am convinced that my citizenship would have been revoked.
    I bought a Jaffel iron, circa 2020, the 3 Jaffel type. Used it once and swore never again. I didnt burn the Jaffels, but the bread stuck to the iron itself and created a hang of a mess. I buttered the outside of the bread as one might for a toasted. So what is the best method for preventing Jaffels from sticking. I want to give it a go again today.
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
    Thanked: 598
    Default Re: Jaffel Irons: Stop Sticking
    With mine I just use Spray&Cook, bit of butter on outside of sarmie, turn frequently.
    Sometimes the edges burn, where bits of the sarmie sticks out. if gas flame is to high, then they stick, just use a knife to pry the bread loose.
  3. The Following 4 Users Say Thank You to Fred56 For This Useful Post:
    Mar 2013
    Boksburg
    Thanked: 51
    I would also like to know what cause the sticking. No sticking with the cast iron one that we have. We tried a friend’s aluminium one over the holiday and had endless sticking problems. We eventually stopped using the aluminium one.
    The breads seem to burn black immediately. Bread was buttered on the outside. Also oiled the pan with olive oil. Played with the heat and still no success.
    My lorrie: 2014 Toyota Hilux 4x4 D4D
    2006 Isuzu 250 Fleetside
    Vrou se platkar: 2023 VW T-Cross
    4x4 Trailer: Bushlapa Kewer 2155
    EX: Amarok BTDI DC
    Echo 4
    Jul 2017
    Paulshof
    Thanked: 1018
    Get it hot first, then a bit of spray and cook, then place sarmies inside and toast.
    2018 VW Amarok V6 Auto 4Motion
  6. The Following 7 Users Say Thank You to Ooba For This Useful Post:
    Thanked: 4894
    Aluminium ones get hot much faster than cast ones. So you to hold back on the heat with Aluminium. Spray and cook with butter outside. Preferably not light margarine.
    The more you use the iron the better it gets. Wash with soap and water only. No scouring.
  8. The Following 5 Users Say Thank You to LandyLove For This Useful Post:
  9. #6
    4 Ways
    Thanked: 104
    Quote Originally Posted by Ooba View Post
    Do not use low fat butter or margarine
    Who Dares Wins
    Logic will take you from A to B
    Imagination will take you everywhere
  10. The Following 4 Users Say Thank You to eagle eye For This Useful Post:
  11. #7
    Thanked: 2860
    Quote Originally Posted by LandyLove View Post
    Sounds like it gets seasoned over time the same as a good potjie (well the cast iron ones any way).
    '13 Audi Q7 3.0 TDi quattro - stock standard
    '12 Audi Q5 3.0 TDi quattro, 255-65R17 AT tires - Sold
  12. The Following 2 Users Say Thank You to Commander For This Useful Post:
  13. #8
    May 2016
    Thanked: 9456
    Try lower temperature (over and above tips already posted).
    2003 Mitsubishi Pajero 3.2 Di-d LWB
  14. The Following User Says Thank You to 4ePajero For This Useful Post:
  15. #9
    Oct 2006
    Pretoria (Rietvalleirand)
    Thanked: 196
    Very true. I also spray some Spray&Cook every third Jaffle or so.
    Hate the Aluminium ones though. Can't come right with them.
    VW Amarok V6 Canyon - Grondpad
    VW Tiguan 2.0TDi - Teerpad
    Bushlapa Boabab 4.2 in tow
  16. #10
    Ruimsig
    Thanked: 44950
    Okay, maybe its the aluminium.
    Thanks for all the replies gents
  17. #11
    Thanked: 622
    I am sure I do not have to school anybody here, in the making of Braaibroodjies.
    Well I use toeknyp roosters when braaing. And you can identify a rookie braaier by the way his braaibroodjies sticks to the grid.
    You never close a toeknyp rooster on braaibroodjies and lock the handles with the bracket. That is a sure way to make it stick to the grid.
    You only close it lightly and keep it lightly closed with your hands only. You turn the braaibroodjies regularly to keep it from
    burning and always open the top grid, every time after turning, to keep the braaibroodjie from sticking to the grid. And this work well for me. And I very seldom put butter on the outside of the braaibroodjies.
    Now I suspect it is the same with Jaffels.
    Obviousely, you have to clamp it firmly the first time in order to seal the Jaffel, but thereafter, it might help to open it on a regular bases to help prevent sticking. And sommer inspecting how far the are from ready.
    I have notice that my wise old mother as well as my wife, opens the Jaffel pan regularly to inspect the condition of the Jaffel in order not to burn them. And I am suspecting that this helps a lot for preventing them from sticking.
    I suspect that it is the high moisture content in loafs of bread these days that are the cause for this stickiness to the Jaffel pan or braai grid. Even more so when you clamp them too tight.
    But then, I might have it tatally wrong.
  18. The Following 5 Users Say Thank You to Viertrek For This Useful Post:
  19. #12
    Thanked: 5040
    Just in case you were wondering (and to protect your citizenship.. ), the Afrikaans for a Jaffle is a Knypkoek. Direct translation: Pinch cake.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
  20. The Following 4 Users Say Thank You to Uys For This Useful Post:
  21. #13
    Gaborone, Botswana
    Thanked: 3179
    I do not open it until it is light brown. Little bit of practice/experience and you will get it right. It is like trying to turn over a pannekoek or plaatkoekie before it is slightly brown - it sicks to the pan.
    To burn it in I will do the following. Few slices of bread without filling. Butter outside. Into Jaffel Iron at low/medium heat. Leave it in there for a few minutes. Do not open until the end of the few minutes. (If the smoke comes out it was too long ). Turn over and do the other side. Open. You want a dark brown crust. If there is no crust, it will stick. (Soos 'n rou pannekoek.) Repeat a few times. It will also give you the chance to get to know the timing and heat settings for the best results. Now do the same with the filling inside. Shorten the time for the brownness of your liking.
    Kobus
  22. #14
    Gaborone, Botswana
    Thanked: 3179
    .... the Afrikaans for a Jaffle is a Knypkoek.....
    Dit is debatteerbaar.
    https://www.4x4community.co.za/forum...-vir-‘n-Jaffle
    Kobus
  23. #15
    Tshwanetoria
    Thanked: 3400
    Ken 'n paar. Voorbankers by die kerk en vrouefederasie
  24. The Following 3 Users Say Thank You to hatjohan For This Useful Post:
  25. #16
    Jul 2014
    Thanked: 3849
    Have a practically ancient jaffel maker here, probably exceedng 50 years old. Its actually made from cast aluminium, but comparing it to these modern aluminium ones, the quality of aluminium used today is nasty, probably a low % aluminium and the rest is whatever other bits & bobs of metal sommer mixed it, obviously to make it cheaper.
    I lightly butter the bread on the outside, then spray & cook the jaffel maker, then put it on gas stove to warm up properly for the first one. Then, leave on a side for about 4 or 5 minutes, turning it then slowly open one side and see if it sticks and obvioulsy to see how brown the bread has become. Too much heat and the bread burns easily. It gets easier from number 2 onwards, as the machine is nice and warm, then I dont use spray and cook no more.
    I guess practice makes perfect, I have had many f...ups before, so it happens.
    Willem
    (workshop whore)
    Toyotota Rav4 4 door - rooi gevaar
  26. The Following User Says Thank You to WAJ For This Useful Post:
  27. #17
    Aug 2014
    edenvale
    Thanked: 104
    Season it properly, just like you would with cast iron, and it'll work like a bomb...
  28. The Following 2 Users Say Thank You to Xtreme 4x4 For This Useful Post:
  29. #18
    Aug 2014
    edenvale
    Thanked: 104
    Never try washing the coating off.
  30. The Following 2 Users Say Thank You to Xtreme 4x4 For This Useful Post:
  31. #19
    Thanked: 4894
    @estee So are we going to see the jaffel iron on a trade thread today or you making some more?
  32. The Following User Says Thank You to LandyLove For This Useful Post:
  33. #20
    Ruimsig
    Thanked: 44950
    The First Wife, in her infinite wisdom, decided that we should have Banjara instead, so who was I to argue (she probably remembered the last time I tried Jaffels in this disting)
    Even the hoond took off and cowered under the table.
    But....................... this evening is another day
    So, maybe tomorrow; ''Jaffel Iron, used twice'', along with a Fly Fishing Net I bought 30 odd years ago and have never had to use. Maybe, buy the Net and get a free Jaffel Iron
    Thanks again guys, for all the tips and pointers. My daughter, Attila The Honey, suggests Mayo on the outside
