Results 1 to 10 of 10
Thread: Chip cutter
    Mar 2011
    Walker Bay
    Thanked: 2179
    Default Chip cutter
    Any recommendations on a chip cutter.
    Looking for something under R600.
    Ruimsig
    Thanked: 44950
    Default Re: Chip cutter
    Paul, I think your best bet will be an imdustrial/commercial unit. I have bought a few domestic type chip cutters and they jave been dissapointing to say the least.
    Try goggling used catering equipment first, often industrial strength stuff available at very reasonable prices.
    If I might ask, do you do a lot of chips? I just found that for the quantity I do (4 to 5 people), its quicker and easier with a knife overall, and the right technique. Setting up, dismantling and cleaning a chipper takes longer than just using a knife.
    I get between 12 and 20 chips per spud, depending on the size and its, pardon the pun, chop chop.
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  3. The Following 4 Users Say Thank You to Estee For This Useful Post:
    Dec 2010
    Saudi / Limpopo
    Thanked: 55
    I have this one and it works a charm. It is a bit bulky when it comes to storage.
    https://www.amazon.com/Panghuhu88-Co...0-4513d670b6bc
    EDIT: Ignore. I missed you R600 limit. As Estee said the cheaper ones are frustrating. Had 2 others before I bought this one...
    Carl
    2014 Toyota Sequoia 5.7L Limited Edition 4x4 - Mine.
    2017 Pajero 3.5 - SWAMBO
  5. The Following 2 Users Say Thank You to GROENIEdieDRAAK For This Useful Post:
    Thanked: 4894
    Gelmar used to sell a cheap one. I threw it in the bin halfway through my first potato. Cheap ones are crap. As Estee said, cleaning also a mission for a few potatoes.
    I want one of those potato on a stick squirly cutter thingies. Although it wont do my midsection any favours.
  7. The Following User Says Thank You to LandyLove For This Useful Post:
  8. #5
    Gaborone, Botswana
    Thanked: 3179
    Do not waste your money on a cheap one like in the pic.
    It will frustrate you.
    Kobus
  9. The Following User Says Thank You to KobusDJ For This Useful Post:
  10. #6
    Nov 2017
    Thanked: 487
    Agreed, on these types you have to cut the potatoes in half.
    The flexing of the frame and the excess potato gets jammed in there otherwise.
    Everything should be made as simple as possible, but no simpler.
  11. The Following User Says Thank You to HobieDave For This Useful Post:
  12. #7
    May 2016
    Thanked: 9456
    For "family" use, a good peeler and knife.
    Cleaning the chipper for only a few spuds is a schlepp.
    (this holds for most vegetable preparation).
    For large quantities, go catering grade (as per the example posted earlier).
    2003 Mitsubishi Pajero 3.2 Di-d LWB
  13. The Following User Says Thank You to 4ePajero For This Useful Post:
  14. #8
    Vryheid
    Thanked: 38
    The spiral cutter is a nice one to have too.
    HiLUXURIOUS
  15. The Following 2 Users Say Thank You to pclouwrens For This Useful Post:
  16. #9
    Jul 2022
    Alton
    Thanked: 31
    So what make and model is the one you suggest?
    Wall mounted?
    Thanks. Only want a good one.
  17. #10
    Feb 2016
    Thanked: 12
    Any accessories to simply add to a food processor like the graters and cutters for veggies?
    Also OP see
    https://popularkitchenking.co.za/pro...oaAjulEALw_wcB
