Page 3 of 3 FirstFirst 1 2 3
Results 41 to 49 of 49
  1. #41
    Thanked: 720
    Default Re: Best tool for the job?
    Make sure you get the Brushless model. and spare batteries.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  2. #42
    Gaborone, Botswana
    Thanked: 3334
    Quote Originally Posted by Robbief View Post
    This one is brushless. It comes with 2 x 4Ah batteries.
    Kobus
  3. The Following User Says Thank You to KobusDJ For This Useful Post:
  4. #43
    Jan 2022
    Kempton park
    Thanked: 453
    That’s mine but I paid R3000 for mine 9 months ago from my electrical wholesaler also selling Total tools.
    2 x4ah batteries, Charger,grinder and bag.
  5. #44
    Sep 2018
    Not too far from Pofadder
    Thanked: 3613
    A chainsaw is sure to reduce turn around time for woodfetching, but as it was mentioned before, trying to cut loose pieces of wood with a chainsaw or other handheld equipment might result in a woodfetching event with no return, ever.
    Jors Malan
    Old Wheeler
    Website https://www.gama4x4trails.com/home
    Youtube channel https://www.youtube.com/c/JorsMalan
  6. The Following 3 Users Say Thank You to Bex For This Useful Post:
  7. #45
    Apr 2012
    Thanked: 1084
    Quote Originally Posted by Bex View Post
    A chainsaw is sure to reduce turn around time for woodfetching, but as it was mentioned before, trying to cut loose pieces of wood with a chainsaw or other hamdheld equipment might result in a woodfetching even with no return, ever.
    That can be costly.
    RechardT
    Old Wheeler
    Die hard Toyota Hilux fan.
    Hilux V6 D/C 4X4 Auto
    You can go anywhere you want in life as long as its in a 4x4.
  8. #46
    Friemersheim, Southern Cape
    Thanked: 8335
    Now after all this info, are you busy shopping for the correct tool?
    Gone quiet here.....
    Robert van den Berg
    Old Wheeler
    “The truth will set you free, but first it will piss you off."
  9. #47
    Thanked: 8277
    Fetching wood...
    Ettienne de Kock
    2000 Disco Td5
    2018 Honda Accord 2.2 diesel burner
  10. The Following 2 Users Say Thank You to EttiennedK For This Useful Post:
  11. #48
    Sep 2018
    Thanked: 3613
    Fetching wood...
    It seems to be a recurring theme.
    Jors Malan
    Old Wheeler
  12. #49
    Dec 2023
    Thanked: 8
    I ended up going for a cheapo entry level 45cc Ryobi chainsaw for R2k that had fairly decent reviews. I've already been able to help my parents get rid of a few large overhanging branches from a tree in their garden and managed to chop up a decently sized pile of braaiwood two days ago. It takes a bit of prepping to fasten the wingerd stompies down but then the saw just falls through them like a hot knife through butter. So far I'm very happy with the performance of the little machine.
    However, 2 days ago the throttle started sticking when released which is just about the most dangerous defect I can imagine on a chainsaw. Not the actual throttle trigger so I assumed it had something to do with the throttle cable connecting to the carb. However I did not want to mess with anything unnecessarily as the item is obviously under warranty. Instead I removed the clutch cover and cleaned the area out which was quite mucky with chain oil and wood dust. After that the chainsaw worked fine again.
    Is this normal? Can dirt around the clutch area cause this?
