Howzit,I have a D2 TD5, also on a budget. Also tackled the 3 amigos more than once. The (very) cheap code readers are actually only reading the ECU (engine control unit) but there multiple controllers on the car so that code you are getting is related to the engine sensors. In this case, you want to the SLS module (ABS and Suspension module). Only more advanced readers can speak to these other modules. The cheapest way is to get a code reader (as you already know). I have a Delphi DS150 code reader clone that does the job (although it swops left and right sensors in its reporting but easy to work around). Has easily paid for itself in saved time and frustration.The wheel speed sensors can have the correct resistance but still be faulty. The way I confirmed this was connecting it up to an oscilloscope: it is meant to generate about a 2v sine wave but was making a triangle waveform. This was a new yet faulty sensor.Second (very common) issue was the ground circuit fault on the PCB of the ABS module. I brought the repair kit, cheap and easy to install just a bit awkward. I think it would be easy enough to repair without the kit. Error code from the code reader pointed me directly to this.Good luck!
